Old 03-16-2011, 06:22 PM
Swanicyouth's Avatar
Swanicyouth Swanicyouth is offline
Mein Auto: M Roadster
Z4 M Need Brake Pad Advice
I'm so tired of the dust that comes with the OE brakes on my 08 M Roadster! On my previous Zs I just replaced the pads with the Axxis Deluxe pads. I think they are non metal organics and I did notice more fading. I'm a little leery of putting these on the M because of there lack of bite compared to OEs - but I'm not totally against it. How are the Akebono ceramics with dust?
Anyone experience them against the Axxis Deluxe concerning dust? They advertise as low, but are they extremely low dust compared to OE? Basically this is a highway only car and is driven fairly normally, so I'm not looking for extreme performance. Just performance similar to OE with much less dust. Thanks!
Old 03-16-2011, 07:05 PM
Bucko521 Bucko521 is offline
Mein Auto: 2006 BMW Z4 3.0i
Wanting much the same, street/road car/no track, but also tired of the dust. Any pads that can help reduce or eliminate the dust, I would be interested as well.
2006 BMW Z4 3.0i Black/Tan/Black
Old 03-16-2011, 08:43 PM
jodale jodale is offline
Mein Auto: 2004 Z4
I'm with you on the dust so I'm watching for an answer to be posted. It seems all I do is clean the wheels. Do dust shields work ?
Old 03-16-2011, 09:02 PM
SUNZOUT SUNZOUT is offline
Mein Auto: '00 M Roadster
Do they still do Axxis ultimate's ? Perfect for mild street and autocross. Did find they started to fade if you did a long twisty drive but a good compromise to OEM dusty pads
TC Kline S/A Coilovers | Sharked | Turner Slotted Rotors | Axxis Ultimate Pads | SS Front Strut | IE Subframe Bushings | IE Rear Toe/Camber Kit
Whalen Shift Machine | Stygar Clutch Pedal | CDV Delete | LeatherZ Armrest | Whalen seat bushings | Z3Solutions Windblocker | Shift Pin fix
Old 03-16-2011, 10:20 PM
jmillet's Avatar
jmillet jmillet is offline
Mein Auto: E86 Z4 M Coupe 7LM08376
Thumbs up PF Z-rated
I prefer the Performance Friction Z-rated pad for daily driver/street use. Good cold bite and relatively little dust.
I've also used the Axxis ULT (FKA Ultimate) and they are low dusting but are very grabby when cold; difficult to modulate.
Jim Millet
2007 Imola Red Z4 M Coupe'
Premium Package, Nav, HD Radio, Heated Seats, CDV Delete, RPI Scoop, Strong-Strut fire wall braces, TCK DA Coil Over Suspension with Camber/Caster plates.
Old 03-17-2011, 02:19 AM
I did a little more research and found out Axxis Deluxe aren't as absurd as I thought on a street only M. Apparently a lot of people run them and they work out OK, you just loose some bite. I can attest to that, as I had them on my old 2.5i. I also remember them making hardly any dust at all and lasting a while. They are dirt cheap. Anyone know how the dust level on these compares to Akebono ceramics?
Old 03-17-2011, 07:55 AM
chickdr chickdr is offline
Mein Auto: '06 M Roadster Imola/Blk
I put Hawk Performance Ceramics on mine last August. No dust to speak of anymore. They are a bit noisier as I brake(not squealing, but I can hear them against the drilled rotor where I could not hear the OEM pads). The part numbers are:
HB464Z.764(front)
HB518Z.642(rear)
I paid $80 for each set so not bad at all IMO. I had UUC do the install for me.
Old 03-17-2011, 09:52 AM
DashingDaryl DashingDaryl is offline
Mein Auto: 2005 E85 Z4
I was reading up on the difference between Ceramic and Semi Metallic pads. It turns out the ceramics are good for Brake Dust in two ways. One, there is less of it. Two, the Dust is generally a light color, so it tends to blend in more and be less apparent on rims. This is where I found a summary of the difference between Ceramic and Semi Metallic http://wiki.answers.com/Q/What_is_be...mic_brake_pads
Old 03-17-2011, 10:47 AM
Incompatible Incompatible is offline
Mein Auto: 2007 Z4 3.0Si Coupe
Jim, How's the pedel feel on the Friction Z pads? I'm trying to find something with a firmer feel to them then the oe pads. TIA
If you can't take the time to teach a kid something good, someone will take the time to teach them something bad.
Old 03-17-2011, 05:37 PM
jmillet's Avatar
After trying several aftermarket brake pads I've gone with PF Z-rated pads on my former E36 Z3MC as well as my current Z4MC. They have a firm feel without any severe initial bite. They modulate extremely well. They dust far less than the OE Textar/Jurid/Ate but do dust more than the Axxis ULT.
I'm sold on Performance Friction pads and use the PF-01 as my track pad.
Jim Millet
Old 03-20-2011, 08:02 AM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
I use Mintex red box or Axxix Ultimates.
The Ultimates dust more, but work very well.
The Mintex dust very little and also work well.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 03-20-2011, 10:37 AM
I decided to go with the Axxis Deluxe. I had them before and can attest they make the least dust of any pads I tried. They do fade and lack bite a little, but I drive on the street only. I did have the Mintex from Bav Auto before and thought they mas too much dust for what they where. I know from experience that dust will ruin Yr wheels over time
Old 03-21-2011, 10:16 AM
Old 08-09-2012, 11:30 AM
jehsautosalon jehsautosalon is offline
Mein Auto: Zed 4 M Roadster
Do you really need to change the rotor when you change the brake pads?
Old 08-09-2012, 12:04 PM
Mikey48 Mikey48 is offline
Mein Auto: BMW Z4 3.0
I got tired of having to clean my front rims every other day. So I installed Ceramic pads all the way around. No more brake dust. I also installed some awesome cross drilled rotors while I was in there. If your rotors have a lot of mileage on them I would replace them. Your brakes are no place to skimp. Later.
Old 08-09-2012, 12:34 PM
Droptop85 Droptop85 is offline
Mein Auto: 03 Z4 3.0i
I may try these axxis ultimates you speak of. What site do you recommend ordering from?
Old 08-10-2012, 11:33 AM
barryb97 barryb97 is offline
Mein Auto: 06 M Coupe, 01 X5 4.4i
It's been a while but I think I got them here: http://www*****brakes.com/p-655-axxi...riantID=166721
CDV delete, clutch stop, strut bar, stainless brake lines, radiator hole cover, brake duct stop removal, Gunmetal M3 reps, RAD wheel locks, M strut caps, roundel under hood, Intravee II ipod adapter, Homelink garage opener, air bag sticker delete, first aid storage under seats, Bumper plugs keyhole cover, painted reflectors, Headlight washer disable, Mstache front lip, Autosolutions SSK,…
Old 08-10-2012, 12:17 PM
elerner61 elerner61 is offline
Mein Auto: '07 Z4M Roadster
The Axxis Ultimates are NOT a low dust pad. I thought they were (didn't do enough research) and I chose them to replace my OEM pads after I had my M for 3 months. To be honest, they dusted about equally to my OEM pads. I swapped them out for Axxis Deluxe pads and all is good. The Deluxe's are definitely a street only pad, but that's what I do, and they are fine for spirited country road driving. They were a little hard to find, and from the second bit of research I did I would have gone withe the Hawk Ceramics as a second choice.
Old 08-21-2012, 03:01 PM
fahrhaus fahrhaus is offline
Mein Auto: 2002tii, 540iA, Z4M Rdstr
The old EBC Green Stuff pads worked really well for me on my other BMWs, but I've not changed the pads on my Z4M from OEM so I don't know if they're availablee for this car. Worth checking out though, those guys make good stuff.
Old 08-22-2012, 06:34 AM
Pinecone's Avatar
M Mad
BTW, I understand Axxis is no more. So if you like their pads, buy some.
We have Axxis Metal Masters on our M Roadster. Nice pads, but a tiny bit of squeal at times.
I have run Axxis Deluxe on a number of cars over the years (back to when Axxis was Repco, before they were PBR) , and are still my favorite street pad. OK, for autocross, but not for track.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
