Old 06-14-2010, 01:38 PM
stingray911 stingray911 is offline
Mein Auto: 2005 X3 BMW
2005 X3 front brake replacement
I HAVE CHANGED HUNDREDS OF SETS OF BRAKES ON MANY DIFFERENT CAR TYPES... HOWEVER I JUST BOUGHT A 2005 X3 AND IT NEEDS THE FRONT PADS CHANGED.
ANY TIPS FOR ME TO AVOID A NIGHTMARE?
THANKS!!
aL
Old 06-14-2010, 02:54 PM
John320 John320 is offline
Mein Auto: 2017 X1
Look at the Sticky above - FAQ & DIY - Front Brake Job
X3-terrestrial has the write up on the 2005 X3
Old 06-15-2010, 06:52 AM
Evlengr's Avatar
Evlengr Evlengr is offline
Ukemi - that's how I roll
Look into "Hawk" brake pads for more stopping power and less dust.
2007 AT X3 RIPOS
2005 GC
2000 Jeep Cherokee
1997 Twin Turbo RX-7
Old 06-15-2010, 10:18 AM
ex-tech ex-tech is offline
Mein Auto: BMW 745i
Very simple brake setup. You shouldn't have any problems with replacing the brakes. Just remember to put anti-seize on the back of the pads and ears to reduce squeaking. Measure out the rotors since your there. BMW rotors are replaced if under spec not turned on a lathe.
Old 08-10-2012, 12:47 PM
IEX3 IEX3 is offline
Mein Auto: 2005 X3 3.0
metalic or ceramic
Are the OE pads ceramic? I've always had so much brake dust on the rims, that I have a hard time believing the pads were ceramic. However we bought the car used, so no telling what previous owner did. Thanks!
Old 08-10-2012, 01:26 PM
Mein Auto: 2004 X3 2.5i
Don't have to be one or the other (ceramic or metallic) - BMW pads could be categorized as organic.
Any metallic component is less than what would be called a semi-metallic pad, but enough to wear down the relatively soft rotors somewhat more than many other vehicles.
The BMW engineers probably feel they have just the right pairing (pad composition to rotor hardness) for them to work symbiotically.
So if going with ceramics, I would expect it best to select a rotor better suited to that pad composition than the O.E. rotors might be.
x3 ft brake replacement
