Old 08-08-2012, 01:31 PM
MCDz3 MCDz3 is offline
McDuck
Mein Auto: 2005 Z4 2.5
1998 Z3 suspension recommendations please
Hey folks, I've been trying to solve a problem with the ride of my 1998 2.8 roadster. Initially it seemed to be getting kid of sloppy and the steering wheel was vibrating at 58 mph, so based on recommendation of a mechanic I replaced the lower control arms and bushings. This made some improvement but still not what it should be. Steering wheel still vibrated. Next I replaced my tires, nothing great but very affordable. They balanced everything but I still have pretty much the same issue, shaking steering wheel and just an uncomfortable ride over all. Had a local mechanic who has had some experience with the same car as mine, take it for a drive. His recommendation now is struts and shocks based on handling and roll of the car in turns.
First off does this sound like it could solve the problems I'm having? If so, with out breaking my bank, can someone recommend an affordable strut and shock? And with the struts i see on the web, is that all I need to replace or are there other associated components required?
Sorry for the long post but this is my situation. My budget is very tight and I'll have a friend help me in replacement.
Thanks in advance,
MCDz3
Old 08-08-2012, 02:59 PM
Justin A Justin A is offline
Mein Auto: 2004 Jeep TJ, 1997 Z3 2.8
my 97 2.8 has bitstein shocks/struts & b/G lowering springs and handles like its on rails
Old 08-08-2012, 03:04 PM
if you look around online you cant get the parts for 800-1000$ easy! def not bad for a sick suspension that will last 100k
Old 08-08-2012, 05:11 PM
smayo964 smayo964 is offline
Mein Auto: 1999 Z3 Roadster
Like Justin mentioned, surf around, there are many options to do. When i got my 99, it was still on original struts/shocks at almost 100K miles. Changed front struts for little over mid 200s with Bilstein touring and changed the rears for under 200 with Bilstein touring and Ireland mounts. put a couple rubber spring spacers in the rear and it drives really nice as a daily driver. If I need a little more in the front, i'll add the blocks there. Just a cheap way of getting more out of the stock springs vs. new. Good luck on quest.
S. Maykowski, Columbus MS.
My '99 Z3 Alpine White 2.8L Speed Buggy
Old 08-09-2012, 04:59 AM
dougmcintyre dougmcintyre is offline
formerly updmst
Mein Auto: 2000 M Coupe, 1997 318ti
It all depends on your budget and needs.
Many people on this forum like the TC Kline SA and DA coilovers. For larger budgets, ASTs can be a good choice (especially if you track your car).
For smaller budgets, Konis, Bilsteins, and KYB replacement shocks (and, IMHO, basically in that order) are good. See
http://www.tcklineracing.com/index.c...y&Category=285
and
http://www.tirerack.com
for prices and options.
Old 08-09-2012, 10:16 AM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
First thing I would check is if you have a bent wheel.
For high end, TC Kline makes VERY nice suspensions.
For more stock like and less expensive, Bilstein HD or Koni single adjustables will do the job. Always replace the rear upper shock mounts with better ones. Rogue Engineering are one of the best these day.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 08-09-2012, 10:40 AM
amancuso's Avatar
amancuso amancuso is offline
Send a message via AIM to amancuso
Mein Auto: Z3 2.3iA/5MT 528iA VW GTI
I had a steering wheel shake/vibration in my e36 cabrio, it was solved with new struts/mounts.
1999 528iA
2000 Z3 2.3
2003 M5
Old 08-09-2012, 12:55 PM
john@eac john@eac is offline
Past Sponsor
Mein Auto: Many
You might take a look at the prices on the bilsteins that we have at eaceuroparts.
Old 09-11-2012, 09:43 PM
McDuck
So I want to thank every one for their suggestions, but before I invest in struts and shocks, is it really feasible bad struts and shocks can be causing the shakiness and vibration i feel at 58 mph and higher? Are there other things that can cause this problem? t's really taking a lot of the fun out of driving this car... Oh and one more question are their struts only on the from or on the back too, or shocks on the back? I seem to hear conflicting descriptions..
Old 09-11-2012, 10:39 PM
dmytroa@telus.n dmytroa@telus.n is offline
Dmytro
Mein Auto: 1998 z3
1
Last edited by dmytroa@telus.n; 09-11-2012 at 10:40 PM. Reason: didn't read post carefully
Old 09-12-2012, 06:24 AM
formerly updmst
Yes and yes. Bad struts and shocks could cause your problem. A bent wheel, an out of balance wheel, and a defective tire could be the source of your problem. But, assuming you are dealing with an experienced mechanic, he looked at and has driven your car, he is in the best situation to give you good advice. Even if the problem is not caused by your shocks, based on the mechanic's assessment of the handling, your shocks are shot and need replacing.
Also, the suspension is a system. When one part has a problem, the other parts are worked harder and can prematurely fail - bad shocks cause the bushing to wear more quickly or an out of balance tire causes more work for the shocks. I.E., delaying on replacing the shocks will cost you more money.
Technically, struts are on the front, shocks are on the back. But as you have noticed, these terms are used rather loosely. If you check the links I previously posted, the fronts are MOSTLY described as struts, and the rears MOSTLY described as shocks.
Old 09-12-2012, 12:22 PM
Pinecone's Avatar
M Mad
Struts front, shocks rear.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Old 09-12-2012, 12:31 PM
McDuck
Thanks those who have responder so quickly. I am going to have the place that installed the new ires check the balancing again. And go from there to struts and shocks. Someone asked If I had changed the lower control arm bushings when I changed the control arms, the answer is yes.
Old 09-13-2012, 05:01 AM
formerly updmst
OK, I can't remember the tire sizes on all the different models. But, assuming the same size is used front and rear, have the tire place exchange the front and rear wheel/tires. If the problem is a single bad tire or single bent wheel, the problem should move to the rear.
Old 09-13-2012, 06:36 PM
Z3Papa Z3Papa is offline
Mein Auto: 2002 Z3 3.0
Does anyone else hate the phrase "it handles like it is on rails?". To answer your question, your problem could be bad dampers, a wheel with tire weights that have come off, bad LCAB's, but if your car has more than 50,000 miles, it can't hurt to upgrade your suspension. If you were nearby, I'd be more than willing to diagnose by elimination.
2011 BMW M3 ZCP in Melbourne Red, Apex wheels (ARC-8 and EC-7's) with Bridgestone RE-71R's.
Old 02-26-2013, 07:23 AM
McDuck
Ok folks thanks again for the input. I finally have the struts in hand! Are there any other part required in order to change the struts out?
Mcdz3
Old 02-26-2013, 07:44 AM
formerly updmst
Not required, but do this:
Old 02-26-2013, 07:57 AM
McDuck
Thanks, got it. Rears will come shortly. More specifically nothing required on the front struts, just the struts right?
Old 02-26-2013, 08:15 AM
amancuso's Avatar
You should probably replace the strut mounts as well. I'm going to be doing this job late next month. Already have the parts in the garage.
1999 528iA
2000 Z3 2.3
2003 M5
Old 02-26-2013, 11:14 AM
formerly updmst
To help prevent shock tower cracking, I would add strut tower reinforcement plates - http://www.turnermotorsport.com/p-19...ates-pair.aspx
Old 02-26-2013, 04:57 PM
vintage42's Avatar
vintage42 vintage42 is online now
BMW CCA 1405
Mein Auto: 1997 BMW Z3 1.9 5MT
... I finally have the struts in hand! Are there any other part required in order to change the struts out?
You don't say what struts you bought. Unless you bought Bilstein, which have their own internal bump valving and external corrugated bellows dust cover, I think all other struts need the BMW soft yellow foam rubber bump stops and plastic dust covers that attach to the stops. The dust covers are reusable, but the old soft bump stops will be deteriorated and must be replaced.
http://i49.photobucket.com/albums/f2...umpercover.jpg
Old 02-27-2013, 06:23 AM
Dheilman Dheilman is online now
Dave
Mein Auto: 1998 Z3 Roadster 2.8 5spd
Originally Posted by vintage42 View Post
You don't say what struts you bought. Unless you bought Bilstein, which have their own internal bump valving and external corrugated bellows dust cover[/url]
All Bisteins EXCEPT Touring. They are similar to OEM.
http://www.bimmerfest.com/forums/image.php?type=sigpic&userid=299148&dateline=1349724030
Old 02-27-2013, 08:10 AM
dadmog dadmog is offline
Mein Auto: 98 MZ3
Replaced my OEM shocks with Bilstein Sport. VERY hard riding; so for street use, I would consider Touring.
Old 02-27-2013, 08:16 AM
Wertles Wertles is offline
Yoda with a library card
Mein Auto: 1999 M Coupe
Might be too late for the OP since he has already bought his, but for a daily driver on a budget, I put Monroe shocks and struts on the 2.5 convertable. It was about $350 for all 4 corners and has a great ride. The M Coupe has the H&R/Bilstein combo and definitely rides FIRM.
1999 Boston Green M Coupe
2002 Z3 2.5 Automatic Roadster
2013 Ram 3500 Crew Cab Dually, 850 ft/lbs torque, stock and staying that way
1995 318i spray paint red, 170,000 miles and climbing
Old 03-07-2013, 04:39 PM
HANSONCLN HANSONCLN is offline
Mein Auto: 99 m Roadster
Find someone that has a road force wheel balancer and that would defiantly point to or away from wheels or shocks
