Old 08-08-2012, 06:51 PM
bmw335ionnet bmw335ionnet is offline
Mein Auto: 335i
Exclamation Strange Engine noise in 335i
Hello,
I've noticed a strange noise from my 335i(2008, automatic). Its like there is another motor/engine running under the hood. When the engine is turned ON, noise suddenly starts and its like as if the AC motor(just for reference) is running under heavy load. This issue be recreated while in Park and in Drive gear.The noise increases as if the load is increased and calms down in couple minutes. Tried this without AC being ON, and no difference. Hope the gurus here has an answer! Its out of warranty :-(. Any help is appreciated. Thanks for reading this post.
Old 08-08-2012, 07:20 PM
jburke4689 jburke4689 is offline
Mein Auto: 2007 335i
There are two motors under the hood that you can hear. First is the cooling fan. That should be obvious. Open the hood and see if it is spinning. The other is the electric water pump. It is under the right hand side of the engine. It is pretty quiet but you can here it. If it is loud is may be about to fail.
Old 08-08-2012, 07:39 PM
galahad05's Avatar
galahad05 galahad05 is offline
Better with Butter
Mein Auto: 335i sedan 6MT
Well that sucks. The electric water pump is a fairly expensive little thing.
Don't resent growing old. Many are denied the privilege.
-- Irish Proverb
Old 08-08-2012, 09:52 PM
Mein Auto: 335i
Thanks for the reply. Any idea how much it would cost me to get it replaced? I'm out of warranty 3 months ago(54k miles now), is it worth getting the extended warranty now?
Old 08-09-2012, 07:03 AM
David1's Avatar
David1 David1 is offline
Mein Auto: 07 X3 and 335i
If it is your waterpump, the fans will run faster than normal and loud. BMW covered mine on my X5 out of warranty.
2017 M2 - Alpine White - Black/Blue Dakota | DCT | Executive Package
2009 335i Coupe - LBM - Black Dakota/Glacier aluminum - 6spd | Nav | M-Sport | Premium | Logic7 | Heated Seats | CA |BMW Performance Suspension/M3 control arms| Sold
2009 X5 3.0 - Sold
07 X3 - Sold
07 335 coupe - sold
Old 08-09-2012, 11:09 AM
Leekay07 Leekay07 is offline
Mein Auto: X5 35D, Former X1 and 335
The water puimp gives little warning of faliure and the fans only turn on faster when its dead in the water
Just take it to BMW if they said it needs a replacement and they dont offer to cover it call BMW NA
Old 08-10-2012, 10:08 AM
Mein Auto: 335i
Thanks for your replies guys--my car stopped on road yesterday afternoon due to overheat! Had to tow it to the dealership, and yes its a water pump failure. Need to be replaced--whopping $1000 with labor! Dealership is coverin 50%, so looking at 500 for this. Looks like there are few more issues as well--transmission sleeve is leaking, to need to replace trans gasket, drain plug and fluid. And power steering fluid flush---all in all $1600 damage!!! Now i Wish i bought the extended warranty!!
Old 08-10-2012, 10:15 AM
I wouldn't settle for paying anything out of pocket. Anything you pay out of pocket the dealer will pocket. Call BMW. Your allowed 10% outside your limited milage warranty because the mileometer is not always 100% accurate so unless you expired the 4 years your legally still covered under your 50,000 mile original warranty.
http://www.edmunds.com/auto-warranty...-warranty.html
Old 08-10-2012, 12:07 PM
Mein Auto: 335i
Thanks Leekay07, just called BMW and they said they will get back to me in 5 days. Hope they can cover it.
Old 08-10-2012, 08:03 PM
Leekay07 had an interesting point. If you have ever checked, you probably noticed that at 60mph indicated, your car is actually doing 56mph by GPS. That is a 7.1% difference indicated to actual. I does translate to the odomoeter as well. I means that when your odometer says 50,000 miles, you have actually only driven 46,540 miles. BMW knows this and will honor the warranty beyond 50,000 if you make a stink. I don't think you will get help beyond 4 years though.
Old 08-11-2012, 12:22 AM
I know about the mileage thing because back in 08 I was part of a Subaru class action law suit. Subaru cut us off at the mileage and offered no coverage beyond this. i paid for new caps for my wheels due to discoloring at 37,000 miles and was sent a check at the end of the class action for the amount paid. Now they will cover beyond the 36lk within the 3 year limit.
Old 08-13-2012, 08:13 PM
Mein Auto: 335i
Tried calling BMW as well, but they said the same thing--covered only 50%. Had to pay the rest :-(
Old 08-14-2012, 06:59 AM
David1's Avatar
The odometer is 100% correct. It gets its reading from the ECU which knows true road speed. What you see on the dash for MPH is intentionally made to read high by software.
2009 X5 3.0 - Sold
07 X3 - Sold
07 335 coupe - sold
Old 08-15-2012, 08:14 AM
Mein Auto: 335i
Guys, the exact same problem popped up ONE DAY after the repair. Engine overheating, fan running at high speed, and engine shut down! Cannot believe this!! Sent it to dealership, waiting for the diagnosis :-(
Old 08-15-2012, 01:56 PM
Did they change the thermostate when they changed the pump?
Old 08-16-2012, 09:04 PM
Mein Auto: 335i
No they did not change thermostat. First, they said its the connector pins that went bad and asked me to pay for it. Now they are saying its the water pump that went bad AGAIN! Doesn't sound right to me :-(
Old 08-16-2012, 09:11 PM
is it not fixed yet? If not have them change it.
Old 08-16-2012, 09:14 PM
And this cost outlay I wouldnt worry about the fact its failing so often someone somewhere is going to call a class action suit for them to deal with.
Old 08-16-2012, 10:37 PM
galahad05's Avatar
Better with Butter
Let them know that you are unhappy with the quality of their work. Let them know that your decision to come back with future work for them depends on how well they do here.
If they soak you with the cost, find yourself a reputable indy shop and never look back.
-- Irish Proverb
Old 08-17-2012, 12:44 PM
David1. Maybe on yours it is and that is what BMWNA told me. There was an easy way to check with a GPS so that is what I did. The odometer correlated exactly with the speedometer error. I dont' think I am the only one.
Old 08-17-2012, 12:47 PM
If you were paying 100% they would have replaced the thermostat. I have never heard of the dealer not replacing the thermostat with the pump. Unbelieveable!
Old 08-18-2012, 07:47 PM
David1's Avatar
What they told you is incorrect.
2009 X5 3.0 - Sold
07 X3 - Sold
07 335 coupe - sold
Old 08-21-2012, 02:22 PM
Mein Auto: 335i
It was indeed water pump failure-AGAIN!!!! So they've replaced it(all parts are under 2 year warranty), and the connector pins as well. Hope it wont trouble me again! Thanks for all your replies guys.
Old 08-21-2012, 02:55 PM
roadkillrob roadkillrob is offline
Mein Auto: 325CIC, 335CIC
Good luck, if the new one was faulty just really bad luck, it is also possible it was damaged during the install, either way it sucks to have to deal with it, but at least they have to cover the new faulty one 100%
Good Luck with it.
2008 335i Vert Montego/Saddle/Grey Poplar
2013 Mercedes C63 AMG Obsidian Black/Black
2016 X5 M-Sport Mineral White/Mocha Design Package/Fineline Oak
Old 08-31-2012, 08:04 AM
Mein Auto: 335i
Guys, its overheating AGAIN!!!!!!! Last time it shutdown itself, it was around temperature of 260 F. Now its 240F after like 30-45min drive around the town. I'm freaking out! Any clue what might've gone wrong?
335i, engine, noise
