Old 08-09-2012, 09:02 AM
Kevingovro Kevingovro is offline
Mein Auto: 2004 X3
Expansion tank and hose parts help....
Hello,
I am wanting to replace my expansion tank and some hoses on my cooling system on my 2004 X3 2.5l
I am not exactly sure what parts i will need besides the tank and hoses (ie. clamps, plugs, sensors, ect.) what can be used still and what do i need to replace?
here are the parts diagrams... any help is truly appreciated I want to do this myself as the dealer charges so much ....
ID:	336063   Click image for larger version
Name:	Screen Shot 2012-08-09 at 10.00.09 AM.png
ID:	336064   Click image for larger version
ID:	336065   Click image for larger version
Name:	Screen Shot 2012-08-09 at 10.00.41 AM.png
Old 08-10-2012, 07:47 AM
Mein Auto: 2004 X3
Can anyone help me out??? I'm trying to buy these parts today...
Old 08-10-2012, 08:59 AM
bluskye bluskye is offline
Mein Auto: 2006 330i / 2007 X3
When i had my mechanic do the expansion tank swap years on my E46 (same engine), I simply bought the tank. If you are buying new hoses that go to/from the tank, you should be good. The old clamps can be used.
Old 08-10-2012, 09:28 AM
Mein Auto: 2004 X3 2.5i
On the expansion tank, from what I read, the thermostat for A/T models often breaks when the tank is pulled out.
If you are careful and luck out, it can be re-used, but it's one of those things that can hold the job up if you need one and don't have it on hand.
It controls flow through the A/T cooler which is located nearby. Don't think they wear out, just fragile.
Might be a non-returnable item, so difficult to call.
Old 08-10-2012, 04:47 PM
-jay- -jay- is offline
Mein Auto: 2006 X3 3.0i
i had just replaced my thermostat a couple months ago after it had failed. i replaced the expansion tank while i was at it and a couple of the hoses.
Kevin, most of the clamps are reusable. at least i reused all of mine. You should replace your A/T thermostat (Part #11 in the first diagram) since you'll be replacing your expansion tank.
i also recommend you replace your bleeder screw to the brass ones if you haven't already.
Old 08-10-2012, 09:56 PM
Mein Auto: 2004 X3
Thanks for the help the dealer didn't have all the parts in stock so had to order some going to change it all next week.... If anyone has any advice on the steps necessary to complete this job let me know
Old 08-20-2012, 05:45 PM
mlukas161's Avatar
mlukas161 mlukas161 is offline
Mein Auto: 03 330i, 04 X3
I would search changing the cooling system in the e46 forum. There are a ton of DIY pages and the m54 engine is exactly the same. So a 2004-2006 x3 has an identical cooling system as the 330i of those years.
Sent from my PC36100 using Bimmer App
Old 08-20-2012, 11:56 PM
yep i know
i had 2 e46's before the X3 and i'm pretty familiar with the M46 engine.
unless you were talking to OP, then yes i agree. search the e46 forums. check the DIY section of e46fanatics.com too.
Old 08-21-2012, 06:00 AM
mlukas161's Avatar
yep i know
Oops, my mistake. That was for the OP and I accidentally quoted your post for some reason. Sorry.
Old 08-21-2012, 12:31 PM
it's all good
oh and i meant to type M54 engine not M46, lol
Old 08-21-2012, 05:51 PM
Mein Auto: 2004 X3
Thanks for all the help got the new tank, upper hose, coolant sensor, and thermostat replace and old coolant out and new coolant in...
Old 08-25-2012, 10:53 PM
fivepointnine fivepointnine is offline
Mein Auto: BMW X3, Hyundai Genesis
was it pretty easy to do? I am doing my waterpump, expansion tank and thermostat this winter
Old 08-26-2012, 08:12 AM
Mein Auto: 2004 X3
Yeah it was easy but I didn't do water pump and stuff
Old 09-04-2012, 03:57 PM
manvee1 manvee1 is offline
Mein Auto: 2008 528i spt pkg
I have the same problem on my 2008 X3 Mtec 41k miles.
What do you think is a reasonable quote for a Water pump , tstat, expansion tank replacement job at BMW in NYC.
I'm out of warrantee and being quoted 1.6k+
Old 09-05-2012, 08:50 AM
mlukas161's Avatar
That seems high to me. All parts for a cooling system over haul cost around 500.00.
Total time for a DIY is about 3 - 4 hours.
cooling, diy, expansion tank, parts, x3
