E36 (1991 - 1999)
Old 08-09-2012, 09:20 AM
krisse84 krisse84 is offline
Mein Auto: bmw 3 1.8i
Angry overheating still!!!
so car started overheating last week, putting water in and it was pouring out just as fast. Upon an inspection the water pump had cracked, replaced water pump and head gasket seals due to milky residue in top rocker, drained oil and coolant system, new oil filter. filled up with new oil and water, still overheating, and still has milky residue on inside of rocker. stumped please help!!!
Old 08-09-2012, 09:26 AM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
1. Leak down test.
2. Compression test.
3. 9 for 10 you have pooched your head gasket and it will cost you ~$1200.
The Evolution of a Lady
“This is the fast lane, folks...and some of us like it here.”
--Hunter S. Thompson
Member of the Non-M Bumper By Choice Club
Old 08-09-2012, 11:27 AM
sigh
compression test done cylinders fine, have been reading something about a pcv valve?????
Old 08-09-2012, 11:33 AM
bmw-mania bmw-mania is offline
Mein Auto: BMW
Slow down.. you're doing E,F,G without doing A, B, & C, FIRST.
Did you bleed the cooling system properly?
its rather tricky on the E36.
Condensation may be giving you the "milky" residue..
Bleed cooling system.
HINT: get nose of car higher than engine
Originally Posted by cj.surr View Post
I don't have to read the username on these posts to know who wrote it.
Bmw-Mania, Ladies and Gentlemen.
Old 08-09-2012, 11:44 AM
have spent hours releasing and unreleasing the bleeding screw and watching and hearing steam coming out where abouts is the bleed valve on the engine block?
have flushed out cooling system, only thing not checked is rad.
Old 08-09-2012, 11:57 AM
Mein Auto: BMW
You mean, tightening, and loosening, or releasing.. there is no "unreleasing".
The bleed screw is here:
DIY here:
http://www.bimmerdiy.com/diy/e36coolingsystem/
AFAIK.. there isnt a "bleed" screw on the block.
There is a drain plug.
Where are you "hearing" steam escaping ?
Old 08-09-2012, 12:07 PM
lol
yes tightening then loosening and the steam is coming from bleed screw once it is loosened, and engine has run for a while.
Old 08-09-2012, 12:11 PM
E36 Phantom's Avatar
E36 Phantom E36 Phantom is online now
King of the Ballers
Mein Auto: Dreier, Fünfer & Siebener
Park on ramps in your driveway, nose up. Let the car idle for a few minutes, loosen the bleed screw until you get fluid coming out for a while. Steam just means you still have air in the system.
Sent from my LG Revolution 4G using BimmerApp
Chad // 2001 BMW 740i M-Sport // 2000 BMW 540i Sport // 1997 BMW 328i Premium //
E38 16" Style 5 Basketweaves, M52 Parts, and New Gaskets/Seals for Sale!! PM for info. .
Originally Posted by SlimKlim View Post
You're a derbanana
Old 08-09-2012, 12:18 PM
EnserioJose's Avatar
EnserioJose EnserioJose is offline
e36 aint noise pollution
Mein Auto: 1996 328is
Be sure to have your a/c turned to high and on heat setting.
96 328is preceded by 09 G8 GT... RIP 7/15/2011
Originally Posted by E36 Phantom View Post
We've tried this before and it never has really worked, but good luck bro.
Old 08-09-2012, 12:24 PM
Mein Auto: BMW
There is a echo in here..
Keep repeating me.. its a nice form of flattery.
NO, you should not have "FLUID COMING OUT FOR A WHILE"..
WTF?
Act like you're NOT a polluter..
Little bubbles.. not streaming fluid.
Old 08-09-2012, 06:03 PM
drivinfaster's Avatar
bimmerfest Supporting Member
Mein Auto: rescued bmw's
well, i think that you may have a warped or cracked head. did you have a machine shop look at it?? if not, then stop right now and take a combustion gas leak test. you can get the kit from almost any parts house and it's simple to use and confirms the presence of co2 in the coolant. (this can only happen when combustion chamber gasses leak past the combustion chamber via headgasket or cracked head)
if it comes back positive, then bleeding will not do anything. take it apart. again. send the head out to get checked.
go from there.
the type of kit is like this one in the link below.
http://www.arrowheadradiator.com/hea..._leak_test.htm
good luck.
df
Old 11-27-2012, 07:07 AM
josephroberts75 josephroberts75 is offline
Mein Auto: e36 bmw
start the car leave the tank cap off and see if large bubbles rise if so then a gauranteed cracked head! aluminum does not take heat very well!!! also white smoke out the exhaust after the car is warmed up to temp
Old 11-27-2012, 09:08 AM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Old thread...................
1998 BMW 328is
1966 Pontiac GTO
Old 11-27-2012, 09:13 AM
hornhospital's Avatar
hornhospital hornhospital is online now
D'oh, You kids!
Mein Auto: 1995 318is / 1993 325is
He's going back 2-3 months and replying to every dead thread on the forum. Why? I mean, his advice is good, but a little late to be useful.
Quotes to live by:
Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff
BMW-CCA #441426
1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia"
I NEED A NAP, DANG IT!
