Welcome to Bimmerfest -- The #1 Online Community for BMW related information! Please enjoy the discussion forums below and share your experiences with the 100,000 current, new and past BMW owners. The forums are broken out by car model and into other special interest sections such as BMW European Delivery and a special forum to voice your questions to the many BMW dealers on the site to assist our members!
You are currently viewing the forum as a guest which does not give you access to all the great features at Bimmerfest including the ability to search, interact with existing members and the option to turn off contextual advertising in posts. Registration is fast, simple and absolutely free so please, join our community today! |
5 Series DIY
Knowledge Is Power! ~ The place for do-it-yourself threads on a variety of topics. Start a thread describing a particular job (oil change, cooling system overhaul, brakes, shocks and springs, etc.) or search for one you need help with! |
newbie valve cover question
My valave cover gasket is leaking onto the manifold, my question is (I dont have a service manual) is what is the torque pattern and torque specs when replacing the valve cover, thanks for the help. -Andrew
clockwise from the center 4 bolts. The TIS does not give a torque spec so I assume it is very light, just enough to slightly compress the gasket. Just the same, I'd use a torque wrench to make them all the same. Probably between 5 and 15 ft-lbs.
Sands (aka Ian) 2000 M Coupe Cosmo Black and no moon roof IE Bushings all around, IE toe and camber kit SS clutch line VPD cooler cap & and a real Setrab cooler Racetech pilot seat, schroth harnesses Obey your Noodly Master! Ramen. |
Also, go to www.bmwtips.com for some better instructions. There are spots where you need to apply a high temp silicon sealant.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
