Old 08-12-2012, 10:31 AM
wes1971 wes1971 is offline
Mein Auto: 95 740 il
95 740iL - Need Help with Serpentine Belt Tension?
I am new to this site and just purchased a 1995 740 IL. The serpentine belt was loose and trying to tighten it but it doesn't stay tightened. Any help would be appreciated. I have never worked on a configuration like this one. Thanks
Old 08-13-2012, 02:05 AM
BMWFatherFigure's Avatar
Old School
OK - bit out my depth here. Isn't the belt kept in tension by a spring loaded idler? If the belt is put on wrong it will not hold tension. Based on my M40 engine games.........
Old 08-14-2012, 11:37 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
From the E39 bestlinks, I'd suggest the OP read 'the answer to the question of adjusting the 540i hydraulic tensioners' belt tension' below since you have the same engine on the E38 ...
More details here ...
- How to tell if you have mechanical or hydraulic belt tensioners (1) & how to switch from mechanical to hydraulic (1) and what is the difference between the two types (1) (2) & how to rebuild your hydraulic tensioners (1) & how to re-grease your pulleys and rollers (1) & the answer to the question of adjusting the 540i hydraulic tensioners' belt tension (1) (2)
HTML code is Off
