Old 08-12-2012, 11:10 AM
kevins950 kevins950 is offline
Mein Auto: Lexus
MY 2013 335i Exhaust Carbon Build Up
Now that I've got 700 km on the odometer, I've noticed a difference in the color of the two exhaust tips. The drivers side inside exhaust is clean with no carbon build up. You can actually see the clean metal inside the exhaust tip. The passenger side inside exhaust is coated and layered with obvious black carbon build up. Is anyone experiencing one sided carbon build up on the exhaust?
ID:	336497   Click image for larger version
Old 08-12-2012, 12:05 PM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is offline
Flying monkey herder
Mein Auto: Daihatsu Terrios
normal. bmw has a flapper valve in one exhaust tip to control noise and prevent droning at low rpm. the other is always open. thats why one tip is "cleaner".
this has been present on bmws since the E46.
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Present: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL
Old 08-12-2012, 12:07 PM
its the part near #7 and 8. part #7 is the actuator the opens and closes it.
Old 08-12-2012, 02:01 PM
vern vern is offline
Send a message via AIM to vern
Mein Auto: 01 330ci 05 530i 06 X3
I know what you are saying is true, thats what the dealer told me when I had it on my 2010 535i but how do you explain not having it on my 2005 530i or do I have it on my 2012 F30 335i Sport with 5,500 + miles on it and all cars have the flapper valve as a matter of fact my 2006 X3 with over 55,000 miles has the flapper and no build up.
cheers
vern
2012 335iA Blk. Sapphire- Sport-Blk. Dakota Leather/Red-Brushed Alum.Trim-DAP-PP-CWP Rear View Camera-BMW Asst w/Enhanced BT&USB-High Gloss Blk.Trim Hghight-PSP-Speed Limit Info-Tech. Pkg-PDC-Rear Manual Sun Shades-SAT-Variable Sport Steering-Wheel Locks- Rubber Mats-Euro Del 5/14/12-Redelivery 7/16/12 2006 X3 3.0iA 4/6 Silver Gray Metallic-Black Leather-Nav-PP-SP-Xenon Headlights-PDC-Heated Front Seats-Privacy Glass-Servotronic Steering-Premium Sound System-R R R- Wheel Locks- Rubber Mats
Old 08-12-2012, 03:11 PM
tturedraider's Avatar
Freedom isn't free!!
cheers
vern
Typically it is much more evident on cars that have split dual exhaust pipes. I don't know why you don't have it on your F30 335i. Just lucky.
www.bmwcca.org
Old 08-12-2012, 04:35 PM
SuperTerp SuperTerp is offline
Mein Auto: R8, M4, M5. M3, 550, 335i
Borla 21461 Exhaust Cleaner and Polish very good stuff very expensive for 8oz. Also one of the green and yellow sponges, and some random exhaust/metal cleaner and a strong arm will do a good job.. But the Borla would clean it up real nice
Old 08-12-2012, 05:13 PM
We are talking about the inside of the exhaust not the outside.
cheers
vern
Old 08-12-2012, 05:35 PM
cheers
vern
I assumed since he was so concerned with the buildup he'd want something to get rid of it.
Old 08-12-2012, 05:42 PM
Elk Elk is offline
Mein Auto: ~
There is no harm in cleaning the inside if you choose to do so. I am insufficiently anal to pay much attention to the outside of the pipes, much less the inside (cheers for black chrome) but I know those that polish both inside and out.
Old 08-12-2012, 06:57 PM
wchast wchast is offline
bucket list man
Mein Auto: 335I
cheers
vern
Vern:
Start your car up( cold engine) and immediately walk to the rear of your car and observe the right rear exhaust pipe. Place your hand in front of the left exhaust pipe. You should not feel any exhaust coming out of the left pipe. Within 15 -20 seconds the actuator will open the left exhaust pipe and you will see the pipe starting to heat up very quickly. Just an observation I noticed on my F-30 335i about a week ago. Initially, the right exhaust has a very deep tone until the actuator opens the left exhaust pipe.
Old 08-13-2012, 10:26 AM
Mein Auto: Lexus
Appreciate the diagram. Helps to know and understand how it works.
cheers
vern
Thanks for sharing your experience.
Yes. Eventually I will clean it. But I'm bothered by the amount of carbon build up.
Originally Posted by wchast View Post
Vern:
What is the mileage and are you having any carbon build up?
I understand that some carbon build up is normal. But I only have about 800 km and the carbon build up is thickly layered, mucky/caked, and seeping or oozing out of one side of the tail pipe. You can see the surface metal on the inside of the other pipe. I would think that this is somewhat indicative or related to the amount of oil burning from the cylinders.
Maybe I'll clean out the inside of the caked tail pipe and observe it over time to see if it continues to get caked with carbon. I dunno.
Old 08-13-2012, 12:13 PM
are you city driving? or highway? if its city, you're probably getting a heavier deposit from the initial moisture coming off the engine giving the soot something to stick to.
Old 08-13-2012, 02:50 PM
The 2010 535 i doesn't have" split dual exhaust pipes".
cheers
vern
Old 08-13-2012, 08:21 PM
Mein Auto: Lexus
I'm doing mostly city driving between work and home.
Old 12-20-2012, 03:02 PM
AntBabeee AntBabeee is offline
Mein Auto: 2013 F30 335i
mine is black like that also.
F30 BMW 335i M-Sport: Estoril Blue II, 19" Rims, Sports Auto, Premium, Technology, Harmon Kardon, Heated Front Seats, Driver Assistance...
Old 12-20-2012, 03:33 PM
SD ///M4's Avatar
SD ///M4 SD ///M4 is offline
(prev. SD335is & SDZ4MR)
Mein Auto: 2016 M4 Coupe | 2006 Z4MR
Maybe on some BMWs, but my 2006 Z4 M Roadster (with an E46 M3 S54 engine and dual mufflers) doesn't have a flapper valve. I installed a Strömung exhaust last month and no flapper valves to be found!
(Sorry, kind of late on that reply!)
- Tom
His: 2016 M4 Coupe | Sakhir Orange Metallic | Black Full Merino Leather | CF Trim | M DCT | Adaptive M Suspension | 19" Black Alloy Wheels | ZEC | ZLP | ZDB | MPE | ED 5/13/16
Hers: 2011 335is Couipe | Le Mans Blue Metallic | Black Dakota Leather | Dark Glacier Aluminum | 6MT | ED 5/12/11
Also His: 2006 Z4 Roadster (E85) | Interlagos Blue Metallic | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12
Old 12-20-2012, 03:41 PM
johnofcross's Avatar
johnofcross johnofcross is offline
Mein Auto: F30 335i Superman M Sport
I think the flap closing has more to do with warming up the catalytic converter. It covers one of the exhaust tips to increase cat temperature.
And vern, your F30 335i sport has black tips so it probably isn't as noticeable. My M Sport gets super black tips, even darker than the OPs. I just leave it alone, it doesn't hurt anyone. I do have to maintain the bumper more often to clean up residue.
8/31/2012 ED - ED Report
11/8/2012 PCD
2013 BMW 335i Sedan Estoril Blue II M Sport 2PF|6MT|ZDH|ZTP|Coral Red Leather|688|508
2007 Nissan Sentra SE-R
Old 12-20-2012, 04:08 PM
Yeah my 335i sport is super black also. I just removed the spring and did the golf-tee mod earlier today. Wiped both exhaust tips. Going to see how they dirty up now.
Old 12-20-2012, 06:04 PM
its noise reduction as a consequence of heating up the cat. on cold start, the intake/exhaust valve (in the engine) opening is programmed to heat up the cat quickly. i forget, but i believe that the exhaust valves are kept open longer to dump more hot gas into the cat quickly. this can be loud. my car (which has no flapper valve, bmw performance exhaust) is loud enough to set off car alarms in my garage on a cold start, the noise drops off as soon as the cat gets lit off. thats about the same time as the flap would open. the flap itself does nothing for emissions.
Old 12-20-2012, 07:55 PM
-=Hot|Ice=-'s Avatar
-=Hot|Ice=- -=Hot|Ice=- is offline
Been there, Done that.
Mein Auto: Does it matter?
Bingo.
Originally Posted by CaptainAudio
In the words of one of Bimmerfest's greatest minds:"Been there, done that"
Originally Posted by boltjaM3s View Post
Half the fun of succeeding in life is fighting the fight and making it.
