week vacation = dead battery
Came back from Vaca and my E39 was dead again. 2nd time it's happened to me. Batt is new, alt works fine. It's only if the car sits for more than 3 days. What are the most likely culprits here? the AC sampling fan?
DD: 2003 530i 5spd manual sport package. Conti DWS's, Llumar ATR, White LED lighting. TLC on-going. Garage queen: '07 335i Sedan, base pkg, 6spd Manual, Procede 3 V5 w/NLS, staggered 18" 313's w/Conti DWS's, HKS Exhaust, OS Giken TCD LSD, VAC Street Diff Cover, Akebono Euro Pads, CDV Removed, Black BMW Grilles, Interior & Exterior white LED lighting, LUX Angel Eyes, Debadged, Llumar ATR Tint. |
naahhh....not the ac sampling fan.that one shuts off after 16-17 mins. as does the orange P led at the shift selector lever.
you have an electrical leak somewhere.or maybe one of the lights are not shutting off when it shud.check: glove box light,trunk lights and cabin lights. google to find elect leak trouble shooting/elimination process |
Could be the FSU bringing on the aircon fan, that will kill a battery quicktime. It can come on when the car is asleep and the keys are out of the ignition. Next time the car sits for 3 days disconnect the battery at the start. If OK after 3 days that will at least tell you the battery is not the culprit
Fsu
Battery is new, and load tested perfect. I am 200% certain there is a drain. Watched some FSU vids on YouTube. I can't believe this box turns the blower motor on when the car is off. That's new. weird. And the next question .... how much $$.
DD: 2003 530i 5spd manual sport package. Conti DWS's, Llumar ATR, White LED lighting. TLC on-going. Garage queen: '07 335i Sedan, base pkg, 6spd Manual, Procede 3 V5 w/NLS, staggered 18" 313's w/Conti DWS's, HKS Exhaust, OS Giken TCD LSD, VAC Street Diff Cover, Akebono Euro Pads, CDV Removed, Black BMW Grilles, Interior & Exterior white LED lighting, LUX Angel Eyes, Debadged, Llumar ATR Tint. Last edited by FLE39; 05-20-2013 at 02:25 PM. |
Having been a victim of the FSU battery killer I continue to be puzzled as to why BMW engineers decided that the aircon fan system had to be live at all times. From this and other forums it is obvious that the FSU failure has and will affect all E39 owners some time. It would seem to be much more sensible to have that circuit only live at the accessory and above settings of the ignition switch. Cannot help you with the price info as we get hammered for such items in NZ, (cost me $300+ to have mine replaced), only advice is to insist on genuine OEM replacement.
$50 at autohausaz
Back when I bought mine, I had just joined Bimmerfest (found it looking for the FSU answer) and didn't know any better, so I bought it at the dealer for $120.
![]() https://www.autohausaz.com/search/pr...d=1370988@540I&year=2001&cid=24@AC %26 Heat - Climate Control&gid=6557@Blower Motor Resistor/Regulator www.autohausaz.com is the website 64116923204 is the part number you want BUT, before ordering, I would recommend confirming the problem. Just shut the car off, and sit patiently in the car, and after 10 or 15 minutes you should start hearing the heater fan motor in the dash cycling on and off. If not, then you may have a drain somewhere else. Instructions for replacement is on this forum, just do a search. The Behr part you get from autohausaz will be the upgraded part, so this should be the last time you ever replace it. (BMW revised the part several times between 1997 and 2003 or 2004, due to all the failures)
Factory M-Sport with factory installed M-tech bumpers, factory Bluetooth, factory M-Audio 10" dual voice coil subs, homelink, M5 rear stabilizer bar, Bilstein B14 PSS coil overs, stop tech ss brake lines, Akebono Euro Ceramic brake pads, oem Brembo and Zimmerman rotors, Dinan Stage 1 software, strong strut front upper stress bar. Last edited by 540 M-Sport; 05-20-2013 at 04:40 PM. |
Factory M-Sport with factory installed M-tech bumpers, factory Bluetooth, factory M-Audio 10" dual voice coil subs, homelink, M5 rear stabilizer bar, Bilstein B14 PSS coil overs, stop tech ss brake lines, Akebono Euro Ceramic brake pads, oem Brembo and Zimmerman rotors, Dinan Stage 1 software, strong strut front upper stress bar. |
Thanks guys. Appreciate all the help. I'll do the easy test first. Sit in the car and play on my iphone and listen for the fan for about 20 minutes. If nothing I'll do the amp-meter off the battery and pull fuses until I find the circuit.
