BMW Coding and Programming
Discuss coding options and features on your BMW here. |
#76
![]() Which, CAFD is for your CAS Module? I'll presume it is the Red one. PM Sent.
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickrŪ Last edited by shawnsheridan; 09-08-2012 at 05:23 PM. |
#77
Hmmm - I'm not sure exactly - I was just following posts earlier in the thread where you indicated that 47.4 was missing some files (from 47.1). I'm having issues accessing the CAS module in a 2013 F10 with 47.4. Beyond that, I'm kinda stuck. See below.
Quote: Originally Posted by shawnsheridan Ok, good. You actually have 47.1 on your car, and for some inexplicable reason, 47.4 did not contain 6 CAFD files that were in 47.1, so if you need the other 5, let me know. Right Orphan Files (6) Size Modified ------------------------------------------------------------- cafd_0000000f.caf.005_024_220 1,006,395 6/14/2012 8:28:02 AM cafd_0000000f.caf.005_024_221 1,004,963 6/14/2012 8:08:18 AM cafd_0000000f.caf.005_024_222 1,005,095 6/14/2012 8:00:04 AM cafd_00000a3f.caf.005_001_008 142,521 6/14/2012 7:06:02 AM cafd_00000794.caf.002_020_029 6,060,497 6/14/2012 7:05:54 AM cafd_00000794.caf.004_122_077 6,468,403 6/14/2012 6:40:58 AM |
#78
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickrŪ |
#79
Shawn,
Thanks for that file - I copied it into my c:\ESysData\psdzdata\swe\cafd directory. I then tried to Read the Coding data for CAS and I received the following message: cafd_0000000f-005_024_222 Fehler: File for "cafd_0000000f-005_024_222" not found! [C012] It looks like the file you sent me is the right one, so I'm not sure why I'm getting this error message? Any thoughts? Thanks. |
#80
#81
cafd_0000000f.caf.005_024_222 just sent.
#82
That did it! Thank you so much for your assistance!
#83
#84
Shawn,
Can you send me 47.4 please? |
#85
#86
hi,
i am new here, and want to learn something about coding on F-Series. but i dont find a link to the newest data files (v47.4 i think ?) Can some one give me that? i only got the v46.1 files for E-Series, and i though there are also newer files. sorry for my bad english im form Germany
#87
#88
Hello
Same here, iam new and looking for the missing psdzdata files. I already have E-Sys 3.18.4 and an ENET Cable. I think the 47.4 files are the newest available for my F30 328i 9/2012 correct? The F10 files should be the same as F20/F30 or is this wrong? Thank you very much! Regards from Switzerland
#89
For F30, just use F20 Target when connecting. PM Sent.
#90
Thanks for the advice!
BMW F30 328i Estoril Blue |
#91
Hello
I'm also going to learn about coding. The threads here are very helpful. I've got the E-Sys already and should have now the PSdZData-files. Shawn, am i right that they are compatible with older versions in the car? Because I had my car by the dealer before 2 weeks and they did a whole software update. But I don't know which files I have to use now, because idon't know the version in my car. But if the new are compatible, then I would be really happy if you could also send me the DL links for the files. Thank you very much and looking forward to have success with my try. ;-)
2010 BMW 535d GT |
#92
#93
I suspect I'm having a related issue, and wondering if you can also steer me towards find the PTZ files I need to update my installation?
the error I specifically get, which is different that what others have posted here is readCPS o.k. cafd_00000909-004_000_033 Fehler: File for "cafd_00000909-004_000_033" not found! [C012] I created a "new" post for this as there was not a specific thread that discussed that error; just in case its different issue that PTZ files? Thanks in advance tk |
#94
#95
Shawn, can you send me teh link to download 47.4? Want to get the new HUD/Kombi features in the GT.
Thanks! |
#96
New PSdZData though will not allow FDL Coding of any new HU_CIC features, unless it is first used to flash the firmware of the HU_CIC ECU, a process not yet fully understood nor documented.
#97
Is that why I can code for HUD turnsignal, but they never show up?
2013 535i xDrive, Imperial Blue Metallic, Oyster and Black Nappa Leather, ZCW, ZDA, ZDH, ZLS, ZMP, ZPP, ZTP, 2TB, 323, 416, 4CE, 4U1, 5AC, 677, JB4 Tuner |
#98
1) HU_CIC / HUD_TURNSIGNAL = aktiv 2) KOMBI / BLINKER_HUD_ENABLE = aktiv 3) Go into CIC iDrive HUD Settings, and enable checkbox for Hud Turn Signals. Did you do all three things?
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickrŪ Last edited by shawnsheridan; 09-12-2012 at 08:12 PM. |
#99
Can I get a pm for the link to psdzdata 47.4? Thank you in advance
#100
I saw that i have firmware 47.4.1 Are the 47.4 still ok?
2010 BMW 535d GT |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
