BMW Coding and Programming
Discuss coding options and features on your BMW here. |
#126
Hi, i'm new here..
how can i see which version i've on my car ? thanks for help |
#127
After your upgrade, if you have any problems coding your car, PM me.
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickrŪ |
#128
Go into E-Sys, VCM, and read your I-Steps, and tell me what I-Step Current is.
#129
sorry i'me new here, what's E-Sys, VCM, I-Steps ??
#130
E-Sys = BMW Factory Floor Software for Coding and Flashing vehicle Electronic Control Units (ECU's)
VCM = E-Sys contains a VCM (Vehicle Configuration Management) Module for managing the Vehicle Order (FA) and Vehicle Profile (FP) I-Steps = Integration Steps - E-Sys' VCM Module will show the I-Step (Integration Level) that the car left the factory with, the I-Step it last had, and the current I-Step. I-Step can be cross-referenced to the ISTA/P Version used by BMW or the Dealer to program the vehicle (update the ECU's firmware). Read this thread: http://www.bimmerfest.com/forums/sho...d.php?t=631884
#131
Hi,
i am a very newbie. I have a F13 650i in Germany. BMW has updated my car, so i cant code the HUD_CIC, because some files arent in my pszdata, like "cafd_000000f9-007_003_067" Can some help me with the newest psdzdata. A link?? Many many thanks |
#132
For you HU_CIC, check your PM for solution.
#133
I only found to download the 2.46.3
Many thanks |
#134
Not good. You will undoubtedly have more problem then just HU_CIC. You need at least 47.4. Check your PM.
#135
Can you send me "cafd_0000000f.caf.005_024_220" "cafd_00000a3f.caf.005_001_008" "cafd_00000794.caf.004_122_077" please? Always thank you.
#136
PM Sent.
#137
My F25 is popping out error cafd_0000000f-005_024_222 file not found with my 47.4 data. Anyone have this to code the CAS features?
#138
I have sent you a PM for what you need. You need to keep a backup of this file as you will need to copy it into your CAFD folder every time you upgrade your PSdZData, at least until your car gets programmed again with something newer than 47.1.
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickrŪ Last edited by shawnsheridan; 09-22-2012 at 04:00 PM. |
#139
hello shawnsheridan I write from Italy and my name is Angel and I am a passionate bmw. I have read many many forums and post and I realized that the program Edys you can do many things on our bmw. I wanted to ask itself could iutarmi esys to download the program and everything you need to make sure that it works to run vim. thank you very much for your time good evening
#140
#141
Hi, I bough an 2011 F25 X3 and i need to retrofit CIC on it. I already have ENET cable, complete CIC kit, FSC code and ESYS installed but i can't find pszdata to work with it...
![]() Can i have a little help? ![]() Is there in the wild some tutorial to begin working with E-sys coding? ![]() Thanks! |
#142
For tutorial, please read this thread, at least Post #1: All BMWs ESYS Coding 101-Getting Started http://www.bimmerfest.com/forums/sho...d.php?t=624369
#143
Hi,
I uses 46.6 on my 2010 F10. After last weeks update from BMW I cannot access 9 files. Can someone help me out with 47.4 and 47.7??? Thanks for the help. I also got a new combox (coded to the cars VIN). In E-Sys the Combox doesn't have a VIN and the CAF File is not existant? Any help on this is appreciated. Cheers |
#144
I am expecting a new F10 in the 3rd week of October and want to mod it. I am in the UK but don't know where I can get an ENET cable in the UK. Also I don't seem to be able to succeed in finding an active set of links to download the files relevant to my car build...
Can anyone help me? All the best, Sam |
#145
How did you get a new combox? Did you have the combox also before or is it a retrofit?
2010 BMW 535d GT |
#146
Look here for cables: http://www.bimmerfest.com/forums/sho...ght=enet+cable Shipping to U.K. should not be an issue.
#147
For Combox, add 6VC to your VO, write VO to car, and then VO Code (Not FDL Code) CMB_MEDIA, and also CMB_ECALL if you Combox is Telematics version.
#148
Hi Cuorealfa01,
Getting the combox was not really hard. The BMW AG doesn't want to give out new Comboxes but my local dealer had no problems with this. You need the exact Part no from the TIS and you will then receive the coded (to your VIN) coded Combox after two days. No it is no retrofit. Original combox but imported from US to Germany, so I had problems with TMC and ECall Cheers |
#149
Thanks a lot Shawn, I am downloading the PSDZDATA at the moment but have to go on a businesstrip next week. Will try everything when I come back end of next week. One thing is unclear so. Do I need to save the VO with the old Combox and save to the car with 6VC when I install the new one or is it possible to enter 6VC by itself in the VO. Do I need a checksum or anything like that to verify it??? Thanks again and a nice weekend to all you coders. I'm off to the Oktoberfest - hard work as well ![]()
#150
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickrŪ Last edited by shawnsheridan; 09-28-2012 at 12:45 AM. |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
