E36 (1991 - 1999)
Old 05-10-2013, 08:53 PM
BIGAAUTOS BIGAAUTOS is offline
Mein Auto: 1998 323IC
E36 323i Convertible 1998 abs and traction lights on.
I have a 1998 323i convertible.
The abs light and traction light is on in the dash. So far I replaced the ABS control module behind the glove box, the Ground Module just to be safe, the red "ABS" relay 5 times with 5 confirmed good relays, The orange relay, all fuses in the under the hood fuse box test good with a test light and also look good,
I pulled the plug on the ABS module behind the glovebox and checked the voltage on pins 2,16,33,35,51 --- WITH THE RELAY IN I only get voltage on pins 35 and 51 (the fuses),,,,, with the ABS relay REMOVED I get 12 volts on every listed pin.....
My next step is replacing the ABS unit under the hood entirely. Any more things that I should check before doing this? Thanks!
Old 05-10-2013, 09:01 PM
SCJon's Avatar
SCJon SCJon is offline
bimmerfest Supporting Member
Mein Auto: 1997 BMW 328is
Have you checked where the ABS and ASC vac lines book into the intake boot? It's a common thing to have a tear there. It's under the MAF intake boot, a small little separate plug that goes into the vac line underneath. If you have had the MAF boot off recently its easy to tear there (ask me how I know ) and if not seated properly will set off both lights.
"It doesn't do any good for me to know more than you if you aren't going to listen to me"
Originally Posted by petriej View Post
So let it be written, so let it be done.
Old 05-10-2013, 11:59 PM
jbomz3's Avatar
jbomz3 jbomz3 is offline
Mein Auto: 323 convertible
Have you changed any wheel sensors ? I had both my ABS and ASC lights on in late 2009 , coming on on start up not motion , it turned out to be 1 front sensor and 1 rear sensor at the same time . I was told by my main dealer (as mine is a '98 model) it's change over year here in Uk , so some systems are "kind of hybrid between E36's and E46's" . Cheers JJ .
Originally Posted by PhilipWOT View Post
Yeah, our M3's are a bit watered down under the hood too.
Old 05-20-2013, 12:30 PM
Thanks for the info, it was the ABS unit.. Changed out the entire unit and the lights went out. Thanks for the info
