E36 (1991 - 1999)
Old 11-16-2016, 08:37 AM
rlee94 rlee94 is offline
Mein Auto: 94 E36 325i Sedan
Widest tire/wheel combo?
The wheels that came on my bimmer are scratched and chipped from the PO so I'm looking to buy new wheels and tires. I've been looking at a set of 17x8 ET40 and I wasn't sure if they'd clear in the front. I was planning on going with 245/40r17 tires (still deciding on a brand, maybe Nitto Invo?) and wanted to make sure they'd work with the offset and width all the way around.
I appreciate any help! Also, any tire suggestions for daily driver and weekend fun-car?
1994 E36 325i
Old 11-16-2016, 12:21 PM
Moeman10's Avatar
Moeman10 Moeman10 is offline
hookersandblow
Send a message via AIM to Moeman10
Mein Auto: '99 M3
Should be okay at anything other than slammed.
I'm pretty low with staggered contours.
8mm spacer up front with 225's
No spacer in back with 245's
I don't rub hardly ever.
Originally Posted by petriej View Post
You can sleep in your car, but you can't race your house!
Old 11-16-2016, 04:50 PM
318tiMD 318tiMD is offline
Mein Auto: X5M, M4, M3
I ran 225/40/18 Front and 255/35/18 rears on OZ Ultraleggeras 18x8 Front ET40 and 18x9 ET40 rear
Very light rubbing on bumps and hard corners, fixed with light fender roll on the inside lip.
My car sits on H&R Sport Springs
Old 11-16-2016, 06:22 PM
Nickco43's Avatar
Nickco43 Nickco43 is offline
The E36 Beginner
Mein Auto: 1998 BMW 323is
I run a set of staggered 17's off a Z3 (17x7.5 and 17x8.5).They're wrapped in Continental DWS06 all seasons; 225/45-17 front and 245/40-17 rear. I have 5mm spacers up front and the rear fender is hammered back just a little . They don't rub at all. I have H&R O.E Sport springs with Koni sport shocks.
Don't buy cheap aftermarket wheels, you will bend them. I wouldn't put bigger than a 17 on a e36 but you can make bigger wheels fit. A lot of people run the kosei k1 racing wheel on there E36. If your on a budget I would just buy some used Z3 or M3 wheels. Make sure you have them tested to see if their bent before you buy used. When I had my wheels tested before I bought them, one of the rears was bent and I got a good chunk of money off the purchase price.
For tires if you want all seasons I really like the DWS06. There miles better then the falken tires that the PO installed.
1998 323iS
Now Emissions Exempt
Old 11-17-2016, 06:22 AM
I appreciate all the information, guys. I think I'll go with a staggered 245 in the rear with 225 up front. I've been looking and for the price I think I'll go with the Hankook V12 EVO for summer tires and use my current wheels for the winter.
I plan on going with the Niche Misano M116 for the summer.
Any suggestions on winter tires? I've never purchased dedicated winter tires, I've always had an SUV for the winter with ATs on it. I've heard the Blizzak are a great studless but I'd like your opinions!
Again, thanks for all the information!
1994 E36 325i
Old 11-17-2016, 06:30 AM
Nickco43's Avatar
The E36 Beginner
Are those wheels low pressure cast or gravity cast? If they are not low pressure cast they will bend.
Old 11-17-2016, 08:14 AM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x2,E30x1, F150
That's an awfully broad statement. ANY wheel will bend given enough abuse.
FYI: Niche wheels are forged, not cast. They are plenty tough.
Quotes to live by:
Ken Kanne, Silverhill, AL, E36 & New Member Intro Forum Mod/Bimmerfest Misplaced-Posting Tow Truck
BMW-CCA #441426 Which is worse, ignorance or apathy? I don't know, and I don't care!
1995 318is "Bebe"; 1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette"
Old 11-17-2016, 08:57 AM
Nickco43's Avatar
The E36 Beginner
If there forged then they are good. I don't know to much about aftermarket brands. But I see bent, cheap aftermarket wheels all of the time.
Old 11-17-2016, 12:41 PM
Brake_L8's Avatar
Brake_L8 Brake_L8 is offline
Ambitious But Rubbish
Mein Auto: 97 M3 | 96 328iC
You can fit 9's up front if you really want, but it takes some pulling/rolling of fenders and proper offset + spacers to do it.
Shouldn't have any issue with an 8" wheel and 235 or 245 tire. Based on the wheel offset and how "fat" the tire is (width of tire is relative based on brand, so not all 245's are the same) you may need a 5 or 10 mm spacer to clear the strut housing. If you get a 10mm, make sure you get a spacer with a lip, or a hub extender. Bimmerworld sells 'em.
- Jake
Now:
11 Ford F-150 FX4 | 97 BMW M3 | 06 BMW M3 Convertible
Then:
87 BMW 325e | 91 BMW 535i | 96 BMW 328i | 95 BMW 325i |95 Mazda Miata | 13 Ford Focus ST | 09 BMW 128i | 00 Pontiac Firebird | 05 GMC Yukon Denali | 96 BMW 328iC
Old 11-17-2016, 07:54 PM
I've done some more looking (I'm never satisfied, I own a Jeep and a Bimmer lol) and I think I may stick with my 16s. Not sure what style they are (if they're even BMW wheels) but they don't look bad and I'll probably just repaint them. Can anyone identify them? The RR is a bit bent and they're all a little scuffed from a PO. The last PO claims they're BBS isn't 100% sure.
http://i.imgur.com/hNeK9X7.jpg
1994 E36 325i
Old 11-17-2016, 07:59 PM
Moeman10's Avatar
hookersandblow
Mein Auto: '99 M3
http://www.bmwstylewheels.com/bmw/43
You have those guys installed. Most common on base E46's here in the states.
Old 11-17-2016, 08:12 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Eh, many of the OEM E36 wheels bend pretty easily. And my el cheapo cast Kosei K1s have been doing great after 5-6 years of mixed street & track use. Anything will bend, but I'd argue that it's less of a factor when you run 17s or smaller since you usually have a decent amount of sidewall at that diameter. Once you get into 18s and larger, the sidewall is just too thin on an E36 to provide adequate protection to the wheel. Usually the problem with cheap aftermarket wheels is weight, not susceptibility to bending.
1998 BMW 328is
1966 Pontiac GTO
Old 11-17-2016, 08:19 PM
Nickco43's Avatar
The E36 Beginner
Kosei wheels are low pressure cast and are just fine. Gravity cast wheels are your pepboys special wheels.
Old 11-19-2016, 01:20 AM
jason_recliner's Avatar
jason_recliner jason_recliner is offline
Don't ask me, I'm a sofa.
Mein Auto: Bostongrün 1995 320i
+1000
I will never understand why people will take perfectly good cars and modify them to look like hell.
Aesthetic displeasure aside, most metals are heavier than rubber. So before increasing the wheel size and reducing tyre profiles to mere elastic bands, you should learn all about "unsprung mass".
"The Wheelie Bin" - 1995 320i Boston Green
A word on our sponsors: Iridium sparks thanks to NGK. #42 wheels are lovingly dressed by Yokohama C-Drive. The dark road ahead is turned into daylight by Eagle-Eye 6000K HID, supplemented by 7000K CCFL Angel eyes. HB/Fog have selected to go with Philips 4000K BlueVision. Engine parts choose to slip and slide with Castrol's finest 20-50 GTX genuine dinosaur slime, renewed every 10,000km.
Old 11-19-2016, 06:44 AM
Originally Posted by jason_recliner View Post
+1000
I know about un/sprung mass. I'm an avid offroader as well. I've actually decided to stick with my current Style 43s and just paint them white. I'm super happy with how the first turned out using just plastidip. I like how it actually looks almost like a plastic wheel.
1994 E36 325i
Old 11-19-2016, 07:36 AM
Moeman10's Avatar
hookersandblow
Mein Auto: '99 M3
Wow that looks really good. Been debating doing the same thing to my contours. I think it would look great with the contrast between a powdery white and any dark color.
Old 11-19-2016, 07:55 AM
Like I said, I'm stoked with how it actually came out. I'm going to repaint the lug bolts flat black and clean up (maybe repaint) the calipers (they're red). The paint on the car is going from the schwartz II to satin black.
1994 E36 325i
