Do-It-Yourself H.Q.
Share your DIY projects or ask questions about how to fix something on your own. Help fellow Bimmerfest members improve your wrench turning skills! All BMW DIY tips, tales, and projects discussed inside. Learn to work on your car and know the right BMW parts you will need! |
Hey guys...
I want to remove the airbag stickers from my visors.... I know that people have removed the stickers form their visors by using Goof-off and the whole deal with all that.... I searched, but only found this info from most people's vinyl visor label removals... ![]() BUT..... My visors are FABRIC Is Goof-Off fabric safe? When the label shrinks, I'm afraid it might end up ripping the "mouse-fur" off.... Anyone with an M3 who has done this got any tips?
Nobody's done this on mousefur visors before?
![]() Anyone? Bueller? |
I did the same process on the "mouse fur" in my 540 as I did on the vinyl in the 330. Works even better on the fur, no residue.
Thanks!
Having used Goof-Off to remove the airbag stickers on my vinyl visors, I have this bit of advice FWIW:
You want to use as little Goof-Off as possible since it is a nasty chemical and if left on your visor, could damage it. So I would suggest applying it with something slightly rough, like a garden variety paper towel. The DIY instructions I followed had me applying it with cotton balls. The problem is that (at least on vinyl) once the GoofOff gets in there, you still need to "pull" the label off. Cotton balls don't pull squat. A paper towel would be grippy enough to pull the sticker off. Be sure to have soapy water or whatever other mild cleansers you use on hand so you can get any Goof Off residue off as soon as possible. Maybe this doesn't really apply on the mouse-fur visors. Just thought I'd add it into the mix. -CMOS
![]() Maybe if I feel daring I'll try some in a small inconspicous area somewhere and see what happens...
DIY removing sticker |
Thanks guys for the suggestions! If any other tips come to mind, I welcome them! ![]() I already removed the driver side sticker... no goof-off or anything... one of the corners was a little loose so with my pinky fingernail, I dug at it till enough came loose. Then I carefully peeled the sticker off very slowly.... it did pull some mousefur off, but very little, and the visor looks perfectly fine. Only noticable thing is a line of adhesive or whatever it is that was along the bottom edge of the sticker but the rest of it came off with a lot of patience and slow peeling.... the passenger side one seems to be more stubborn as I can't get my nail under any of the corners.... so I'll probably need some goof-off to help it loosen up if I can't get underneath that one... |
Whew! Done!
Ugh... I just spent about 45 minutes sitting in my garage figuring out how to get the last airbag sticker off the passenger side visor.
Interesting part was I did it without using any Goof-Off As I expected, the passenger side was more stubborn than the driver side.... after I removed them, I compared the two labels and the passenger side label was way thinner and fragile than the driver side one was.... (probably explained why I was able to get my fingernail under the first one with relative ease as opposed to this one which took me twice as long) Eventually I got one corner to come up a little, then I pinched the edge and started to tug at it lightly. This label was on there pretty good, so the label began to stretch as I tugged. I had to keep tugging one little bit at a time while being careful not to rip the label.... it's like a shrinky-dink piece of plastic/rubber... I came close to ripping this one twice.... the driver side one was almost like a card.... I guess they didn't heat it enough to get it on the visor... ![]() Well... it's done at least... and now I have stickerless mousefur anthracite visors.... Thanks again to all who replied with their tips even though I ended up getting around using any solvents for mine...
Re: Whew! Done!
Serious picking is for noses. |
Re: Re: Whew! Done!
I wonder if there's a nose picking emoticon anywhere... I was bored and didn't have any Goof-Off handy at the moment... hehe... I took small breaks in between tugs on the label to mess with my radio and set the presets and junk...I'll check for any leftover residue when the light is better, but I didn't see much at all when I removed them...
Got it all off, but there's a bit of adhesive residue. What to do? Did I wait too long (is this a downside of ED?)
F30 Sun Visor Airbag Warning Sticker
Just removed the warning stickers on my F30 2012 335i. I have one with black headliner and the stickers really stood out. They may have changed the sticker material. I tried alcohol first, that did not work. Goof off does work but it is messy. The sticker dissolves like paint and I needed lots of goof off to remove the sticky mess. I have black vinyl visors and after half a can of goof off, the vinyl was really loose and wrinkled. Was ready to buy new visors but the next morning they had stretched again and now it looks perfect. The solvent smell stays for a few days. My experience with the F30 was that removing the stickers is a messy process. Be prepared to spend some time... I still think it was worth it.
