Hot start issue and something else while youre here - Page 2 - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 08-14-2012, 06:12 PM
TheFinanceGuy's Avatar
TheFinanceGuy TheFinanceGuy is offline
still learnin'
Mein Auto: 1998 328i / 99 540iA
I think the second part...
Patrick ///04 330i ZHP///BMWCCA#465139
99 540i TiAg
98 328i hellrot (sold)
96 318iC black (sold)
Old 08-14-2012, 06:25 PM
bigugly fab bigugly fab is offline
Dr.BMW
Mein Auto: 2015 M4
put the cap on your dresser and go drive it for a day or two. see if it changes the issue.
thats the most simplistic way i can explain it lol
Old 08-14-2012, 06:33 PM
BMRfanatic's Avatar
BMRfanatic BMRfanatic is offline
Mein Auto: Bad Luck 46
oh.
what would that diagnose though?
-Dino
Old 08-14-2012, 06:38 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
Originally Posted by Dino1394 View Post
Lol I just drove it with the cap off nothing changed
What I understood was.
Take gas cap off, start car, drive it
When I 1st took the cap off there was pressure
unless you mean leave cap on, drive car , wait till i know the problem exposes itself then take off gas cap and see if theres pressure?
when you drive your car, and have a return line to the fuel tank, then the returning fuel tends to warm up the fuel in the tank.
this is where pressure builds up, as fuel likes to evaporate. fuel vapors compress, fuel liquid does not.
i fail to see how the pressure build up in the tank relates to a hard start when hot, unless it's vapor lock, but then i have never actually come across a case of this.
in 15 years of wrenching.
but i doubt this is the case since apparently the condition still presents when the fuel cap is not present.
i'm still feeling a crank sensor, or some other major input that poops out at a specific temp.
did you ohm out the crank sensor when it is hot?? this is the best time to do it (i know, it's *hot*...)
especially since this is when it presents.
now if you had a power graphing meter, you could hook it to the crank sensor, 'see' the signal, and compare it to the signal (or lack thereof) wen it gets hot.
can you force replicate this condition without actually driving?? i'm thinking if you were to have said meter hooked up when cold, allow it to get to temp, shut it off and wait, keeping the meter hooked, you could then simply see the crank sensor signal yeah or nay and either rule it out or confirm it as the culprit.
or you could play musical parts.
df
Old 08-14-2012, 06:42 PM
BMRfanatic's Avatar
yeah the 638ohm was taken while it was hot and giving the not start condition
based off what ive read and from experience anything under 500ohms it doesnt work and the dme wont allow the engine to start
( my good the OFH was not my friend at that moment)
-Dino
Old 08-15-2012, 06:34 AM
Dr.BMW
Mein Auto: 2015 M4
Drivinfaster hit it on the head. I was seeing if fuel tank pressure was forcing vapors into the engine, causing it to "flood".....
I have seen vapor lock, tank pressure and charcoal canisters force fuel/vapors into the intake and create a long crank due to excessive fuel during start up.
Also, does this have the original style m52 crank sensor, or the updated (with harness) m54 crank sensor?
Old 08-15-2012, 08:08 AM
BMRfanatic's Avatar
nope m50 crank sensor ( i have a m50tu)
How would one know if the charcoal canister is junk?
-Dino
Old 08-15-2012, 08:27 AM
still learnin'
by smell I think...
From what I read a while go (iirc), you would be able to smell gas outside the car, but not find any leaks.
I think they can become plugged too. So, in theory- if driving with the gas cap off works, one might be able to think the charcoal canister is bad?
Old 08-19-2012, 09:49 AM
BMRfanatic's Avatar
Ok went to go remove the fpr off the other car but theres no bolt or anything and google and the bentley are no help on to remove the thing
all i can do is turn the regulator I didnt try pulling or prying it cause i didnt want to break the fuel rail
how does it come off?
-Dino
Old 08-19-2012, 10:15 AM
dc_wright's Avatar
dc_wright dc_wright is offline
bimmerfest Supporting Member
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
BMWfans.info shows there's a clamp that holds it in place on the fuel rail.
Edit - crap the site is blocking the link. Here's the diagram from bmwfans.info
Edit 2 - The M52 FPR has a different mount and there's a clamp spring that holds it in place.....
ID:	337739   Click image for larger version
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
Old 08-19-2012, 10:39 AM
BMRfanatic's Avatar
thats weird the fuel rail from the parts car only has 6 , and that almost complete circle shaped clamp looking thing
but yet my car has everything in the diagram
Maybe messing with the wrong thing? , the parts car is a 94
-Dino
Old 08-19-2012, 10:50 AM
dc_wright's Avatar
Items 7, 8, and 9 will be hidden from view until you remove the clamp. If they're missing maybe someone already did a swap out on the FPR that's in the parts car and didn't bother to replace any of the seals?
Old 08-19-2012, 11:01 AM
BMRfanatic's Avatar
Heres what was there
As you can see I tried prying the fpr
but no luck
Sent from my SPH-D710 using Bimmer App
ID:	337746   Click image for larger version
-Dino
Old 08-19-2012, 11:19 AM
dc_wright's Avatar
Maybe it's corroded in place? Try some PB Blaster and a strap wrench?
Old 08-19-2012, 12:39 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x1,E30x1, F150
You aren't trying to pry the center part out of the FPR are you? The entire FPR comes out of the fuel rail. It's not supposed to come apart where that snap ring was. It's just stuck in the rail.
Never mind....that type DOES come apart. The cup is part of the fuel rail. Never seen one like that before.
Quotes to live by:
Ken Kanne, Silverhill, AL, E36 Forum & New Member Intro Forum Mod-
Bimmerfest Misplaced-Posting Tow Truck
BMW-CCA #441426
1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette"
Old 08-21-2012, 04:24 PM
BMRfanatic's Avatar
heres a vid I took while testing fuel pressure
First fuel pump was jumped at the relay
Then I put the relay back in and started the car
I gotta watch the other video I found But I guess the FPR isnt working?
What you guys think?
Edit: Fuel pressure is about 7 PSI over what it should be (vid says it should be about 50-51 but that may be high cause of the fuel filter I guess (replaced last summer) However the video is from a 95 with a blue top. I have a white top with the vacuum line going into the second gas tank
50 PSI idle which is normal
Pressure goes up and down When blipping the throttle which seems normal
so that means the FPR is working
HOWEVER i noticed that in his vid he still gets pressure after he shuts the pump off. there is no pressure at all when my pump is off
but yet my pump is pushing enough pressure.. (100psi when i kinked the line)
And there are no fuel line leaks so only 2 causes left is the check valve on the pump or leaky injectors from what he says unno:
-Dino
Old 08-21-2012, 04:50 PM
BMRfanatic's Avatar
Ok after what was said at the end of the vid. Im Leaning towards a bad check valve on the pump
-Dino
Old 08-21-2012, 10:56 PM
jayjaya29's Avatar
jayjaya29 jayjaya29 is offline
Come at ///M3
Send a message via AIM to jayjaya29
Mein Auto: 97 M3
Those videos were INVALUABLE when troubleshooting a hard start issue on my M3. Ended up that the check valve in my fuel pump broke. Got that kit with the new check valve and solved the problem immediately.
Old 08-27-2012, 12:24 PM
peels'bimmer's Avatar
peels'bimmer peels'bimmer is offline
LSD = yum yum
Send a message via MSN to peels'bimmer
Mein Auto: '95 332IS
Any luck yet?!?!
Originally Posted by TRaV MaNN View Post
you never notice how ugly something is until you get rid of it
Originally Posted by hornhospital View Post
That's what my first wife said.
Old 08-27-2012, 04:25 PM
BMRfanatic's Avatar
nah, Havent gotten the check valve yet
-Dino
Old 09-09-2012, 03:39 PM
LSD = yum yum
How bout now?
Old 09-09-2012, 05:04 PM
BMRfanatic's Avatar
Sorry my bad college move craziness
I switched out my fuel pump with the one from my parts car and all starting issues are gone
I still do believe it was the check valve since my pump was putting the right amount of pressure and the FPR was doing its job
It was just easier this way since i didnt have to drive to the dealer to order the part then go back to get it cause I had a confirmed new pump sitting in a gas tank
-Dino
Old 09-09-2012, 05:07 PM
that is good to hear. cause teh college ladies don't want to hear about a 'no start' while out on teh townz...
df
Old 09-09-2012, 05:22 PM
BMRfanatic's Avatar
df
yeah i had a lady friend get nervous when i was continuously cranking my car after the movies lol
-Dino
Old 10-17-2012, 10:12 AM
jwrape jwrape is offline
Mein Auto: 96 Z3M (M S52 conversion)
I have this same issue with my Z3 with a S52 engine. Where is the Fuel Pump Check valve located? Picture???
