Welcome to Bimmerfest -- The #1 Online Community for BMW related information! Please enjoy the discussion forums below and share your experiences with the 100,000 current, new and past BMW owners. The forums are broken out by car model and into other special interest sections such as BMW European Delivery and a special forum to voice your questions to the many BMW dealers on the site to assist our members!
You are currently viewing the forum as a guest which does not give you access to all the great features at Bimmerfest including the ability to search, interact with existing members and the option to turn off contextual advertising in posts. Registration is fast, simple and absolutely free so please, join our community today! |
Do-It-Yourself H.Q. Sponsored by Bimmertools.com
Share your DIY projects or ask questions about how to fix something on your own. Help fellow Bimmerfest members improve your wrench turning skills! All BMW DIY tips, tales, and projects discussed inside. Learn to work on your car and know the right BMW parts you will need! Sponsored by Bimmertools.com |
Tie rod adjustment questions
Please refer to the attached picture for these questions:
-To loosen tie-rod lock nut (#1 in picture), do I turn it in the green arrow or red arrow direction? -To loosen this nut, do I have to hold the tie rod (#2) in place with another wrench. Currently, when I try turning the nut, the tie rod and steering boot (blue arrow) turn with it-- and I can turn it in either direction w/ similar resistance. Is this normal? Is there a technique for holding the steering rack boot still while adjusting the tie rod? -To short the tie rod length (and increase toe-in), do I turn the tie rod (#2) in the green arrow or red arrow direction? -How do you measure tightening torque on the lock nut (#1)? A regular torque wrench and socket obviously won't work in this situation-- so what type of tool do you use? I was just going to use a regular adjustable wrench with an open end and tighten it as tightly as I could -What is the proper wrench size for the lock nut (#1) and the tie rod (#2)? Thanks.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Shock & Spring Write-up | Ågent99 | 5 Series DIY | 14 | 10-13-2007 08:28 PM |
| Greetings from Germany and questions | mbr129 | 3 Series | 20 | 05-30-2003 04:32 AM |
| A few questions about the '04 330i Sedan... | RandyB | 3 Series | 12 | 03-05-2003 12:29 PM |
| Anyone know the size of the tie rod nut and tie rod adjuster? | bmw325 | General BMW | 0 | 05-05-2002 01:22 PM |
| anyone know how much longer/shorter each full turn of the tie rod adjuster makes it? | bmw325 | 3 Series | 10 | 04-06-2002 10:14 PM |
