Old 08-15-2012, 12:45 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
What new tools can we use today to measure toe in at home for the BMW E39?
In another thread, we listed a handful of home alignment DIYs for measuring toe:
- Which of the dozen alignment specs are adjustable on the BMW E39?
I'm considering purchasing a tool to check my toe.
Googling, there are so many to choose from that I'd like someone with experience to help narrow down the choices to a manageable few.
Q: What toe measurement tool do you recommend?
EDIT: Let's keep the discussion focused on the tools that do the job.
(Later, in a different thread, we can add up the costs and run a comparison of whether the tools are worth it over a lifetime of alignments.)
Old 08-15-2012, 01:01 AM
Deathdeelr Deathdeelr is offline
Mein Auto: 1999 528i 5spd
We use a Tool Aid TA61600 at the job for quickie set-the-toe-and-let-it-go alignments. You'll need a flat surface to roll the car forward and back to get your measurements. The leveling chains are adjustable. I would think you'd have to cut them down to two or three links for it to work with the E39. With a little practice it's accurate enough to get a car set up for the drive to the alignment shop but I wouldn't use it as a substitute for a good laser alignment machine.
Old 08-15-2012, 07:13 AM
bluebee's Avatar
I wasn't sure what you meant by 'chain links' until I saw the picture; apparently they hang down from the tire centerline for measurement purposes.
Googling, I find it for less than $100 here. It seems to have a range of 39"-60" between wheels.
Do you know if it gives 'individual' toe (for just one wheel) or just the combined toe between both wheels?
Old 08-15-2012, 08:23 AM
Only total toe.
Old 08-15-2012, 09:40 AM
Topaz540i's Avatar
Topaz540i Topaz540i is offline
Agnostic Priest
Mein Auto: 2001 540i/6
The hardest part about it is you will be surprised how impossible it is to find a flat and level location at home or on the street. Most people's garages if poured correctly are tilted towards the door for drainage.
ESS Tuning m60 version software
m60 intake manifold
a.f.e. c.a.i.
3" obx catback
full powerflex urethane setup
545 ssk
cdv delete
m5 rear sway bar
M5 chassis rods
M5 3.15 lsd
Bc-r coilovers w/ swift springs
Akebono=suck
ss braided brake lines
coming soon:
Jb lwfw
Old 08-15-2012, 11:06 AM
dvsgene dvsgene is offline
Search, Read, THEN Ask
Mein Auto: 98 540i M62 3.15
For those who for whatever reason would rather spend a few hours DIY vs less than one hour with a competent Hunter tech, here are two great articles on DIY and tools:
http://www.renntrack.com/forums/show...ent-Basics-DIY
http://www.hotrod.com/techarticles/c...e/viewall.html
There are simple too many variables to make it worthwhile for most DIYers doing it the analog way.
Old 08-15-2012, 12:12 PM
bluebee's Avatar
Originally Posted by dvsgene View Post
There are simple too many variables to make it worthwhile ...
I understand that argument... but we really can't even begin to make that argument until/unless we scope out two things:
a) The cost of 'lifetime' alignments for any particular tool owner (i.e., multiple vehicles)
b) The cost of 'adequate' tools (i.e., tools with enough accuracy to be useful)
This thread is about the latter, not the former (although, I agree, the comparison needs to be made eventually before the tool-buying decision is made).
here are two great articles on ... tools:
Nice find!
The first Home Alignment Basics DIY lists these $60 toe plates:
And, it also lists this "Smartstrings 4-wheel alignment kit" for $400 (which seems to measure more than just toe):
The second referenced wheel alignment DIY used only string, electrical conduit, and a ruler for what they called "very accurate toe measurements"! I'll assume that cost at about $25 for our later comparisons.
This is a great start.
Key questions are:
Q: What 'accuracy' do we typically need in our toe-checking tools?
Q: Do we need single-wheel measurements ... or can combined wheel-to-wheel measurements suffice?
See also:
- Which of the dozen alignment specs are adjustable on the BMW E39 (1) (pdf) & cn90's front alignment DIY (1) (2) and cn90's rear wheel alignment DIY (1) & what tools measure rear camber at home (1) (2) and what tools measure front/rear toe at home (1) & what tools lock the steering wheel & brake pedal at home (1) & why does BMW recommend weights to set the normal ride height (aka nominal suspension position) prior to any alignment (1) & how to diagnose uneven tire wear on the inside edge due to camber and toe alignment issues (1) (2) & how to select a replacement tire strictly by the numbers (1) & what are the most common bimmerfest user's tire recommendations (1) & where do people buy their tyres anyway (1) & how many miles do you get for every 100 UTQG points (1) & what are the recommended tire pressures for front and rear (1) & what are the claimed benefits of nitrogen gas (1) what tire mounting tools do you need to change your own tyres at home (1) (2) (3) & where are the match mounting marks on the wheel and on the tire for precise tire mounting based on radial runout and heavy spot considerations (1) & what tools do you need to balance a wheel at home to eliminate shimmy or vibration at speed (1) & how do you properly dispose of your old worn out car tires (1) & how to measure bent wheel dimensions such as rim runout and wheel eccentricity at home (1) & where to get bent or damaged wheel rims repaired (1) (2) & what winter driving ice and snow tire chains to use (1) & what are the most recommended products for cleaning BMW BBS wheels (1) & where to buy E39 wheels online (1) & what are the main causes of vibration while highway driving (1) & vibration while highway braking (1) & how to diagnose a violent shudder while slow speed braking on bumps (1)
ID:	336968   Click image for larger version
ID:	336971   Click image for larger version
alignment, alignment diy, home alignment, toe, toe-in
