Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > The Detail Department
Detailing tips, tricks to keep your bimmer in showroom condition.
Old 06-19-2004, 11:54 PM
Nick T.'s Avatar
Nick T. Nick T. is offline
+ Recovering Zainoholic +
Mein Auto: '02 Z3 & '04 MCS & '05 xB
Brake dust revisited
Brake dust and its removal/prevention seems to be an ongoing problem for many detailers. Replacing your OEM brake pads with low-dust after market pads will reduce the dust problem, but so far as I know there are no pads that will eliminate brake dust. This still leaves us with the problem of dealing the dust.
There are many special wheel cleaner products on the market, each with its own hype and its loyal band of followers. I don’t endorse nor recommend any of the special wheel cleaner products because I don’t think that they are needed and I haven’t used them for a long, long time.
I use a secret wheel treatment that allows me to clean off the brake dust usually using nothing more than a cotton towel and a spritz of distilled water - - only occasionally do I need to add a little car shampoo to the water - - and heavier pressure than lightly wiping is never needed.
A year or two ago all of the wildly differing suggestions/recommendations on this and other detailing forums led me to do some comparative experimenting. I started by doing a thorough cleaning and polishing of all four wheels, then applied one recommended product to the left side wheels and another product to the right side wheels. After driving for awhile I would then compare the dust accumulation on each side and the ease (or difficulty) of removal. Another thorough cleaning, the winning product on the opposite side and a new product on the other side.
It didn’t take long to realize that all of the carnauba waxes attracted a lot of dust and were difficult to clean without using a special cleaning product and/or a lot of scrubbing. Closer examination and a little experimenting showed that with even fairly light braking the wheels heated enough to soften even the best carnauba. The heat softened wax retains a great deal more dust than an unwaxed area! Quite a bit of the retained brake dust is trapped under the surface of the wax and cannot be removed without removing the wax.
Progressing on to the synthetic protectants showed a marked improvement - - much less dust retention and much easier cleaning. The “combination” synthetics such as Blackfire and Platinum UPP did not do as well as the “pure” synthetics such as Klasse and Zaino. Zaino attracted/retained slightly less dust than Klasse, but IMO Klasse was the product of choice because of its ease of application.
Recently I decided that it was time to compare my winners to some of the new (to me) products. As expected the carnaubas were poor perfomers, and the combination synthetics such as NXT and Wolfgang did not come up to the level of the pure synthetics. Menzerna was as good or maybe slightly better that Klasse for dust retention, and was easier to clean that either Klasse or Zaino.
I think that I will continue to use Klasse on my wheels and not switch to Menzerna because if you’re not very careful when applying Menzerna it’s easy to leave too much product on the wheels - - and this can lead to pink stains that are very difficult to remove.
OCD sufferer and charter member of the
Anal Retentive Z3 Owners Association
Old 06-20-2004, 04:27 AM
KP's Avatar
KP KP is offline
Buyakasha!
Send a message via AIM to KP Send a message via MSN to KP
Mein Auto: MY01.5 325Ci/93 Miata
Hmmm, Klasse was going to be my next experiment after Zaino. Thanks for the post
Sponsored by: WheelExperts/ModBargains
My Photo Album
Old 06-20-2004, 08:15 AM
RKT BMR's Avatar
RKT BMR RKT BMR is offline
Banned
Mein Auto: 5/01 production 330Cic
While this will come as a surprise to many of you who know what an OCD detailing fanatic I am, I waxed my wheels yesterday for the first time ever, after an intensive cleaning, in the expectation that it would make them more resistant to brakedust.
I put Griots Best of Show (carnauba) on them. GRRRRRRRRRR!
Old 06-20-2004, 08:57 AM
Nick T.'s Avatar
Don't despair - a good coating of carnauba on your wheels is probably better than leaving them unprotected - - but then again, it may be worse than leaving them unprotected.
As many of you know, brake dust will eventually eat its way into the clear-coat, chrome, or aluminum if left on your wheels for an extended period of time. If you wash your unprotected wheels on a regular basis the dust will most likely not have an opportunity to do any damage. If you have a good coating of carnauba on your wheels the wax may hold some of the brake dust trapped against the surface of the wheel, and if the wax isn't removed during washing, then the trapped brake dust may be in contact with the wheel surface long enough to start etching its way into the finish.
Old 06-20-2004, 12:23 PM
rruiter rruiter is offline
Mein Auto: 04 M3 Coupe SMG, 98 ZX9R
There are many special wheel cleaner products on the market, each with its own hype and its loyal band of followers. I don?t endorse nor recommend any of the special wheel cleaner products because I don?t think that they are needed and I haven?t used them for a long, long time.
It didn?t take long to realize that all of the carnauba waxes attracted a lot of dust and were difficult to clean without using a special cleaning product and/or a lot of scrubbing. Closer examination and a little experimenting showed that with even fairly light braking the wheels heated enough to soften even the best carnauba. The heat softened wax retains a great deal more dust than an unwaxed area! Quite a bit of the retained brake dust is trapped under the surface of the wax and cannot be removed without removing the wax.
Progressing on to the synthetic protectants showed a marked improvement - - much less dust retention and much easier cleaning. The ?combination? synthetics such as Blackfire and Platinum UPP did not do as well as the ?pure? synthetics such as Klasse and Zaino. Zaino attracted/retained slightly less dust than Klasse, but IMO Klasse was the product of choice because of its ease of application.
I think that I will continue to use Klasse on my wheels and not switch to Menzerna because if you?re not very careful when applying Menzerna it?s easy to leave too much product on the wheels - - and this can lead to pink stains that are very difficult to remove.
I doubt dust can get get UNDER the wax unless you don't wax it out.
Other than that I think it's a good compare.
I think if you clean the wheels on a regular basis, and are not sloppy with it, you won't have a problem. Wheels get ugly when you take it to a carwash and only part of the wheel get cleaned.
just keeping up with the wheels keeps them nice, and it's easy. putting some wax on extends that even more. You STILL have to clean them.
Old 06-20-2004, 01:21 PM
fuz fuz is offline
non sequitur
Mein Auto: 325i | 2002
The thing I like about AIO is that it has cleaners too, so it has a mild polishing action to get rid of some contaminates. With pure waxes, you need to seperately polish wheels to get the same effect. I tend not to use sealant glaze since I seem to get clouding/haze with it easily...
If the hot pink color of menzerna fmj is actually making stains, I may stay away from it until they change the color to something sensible.
Old 06-20-2004, 03:19 PM
Nick T.'s Avatar
Originally Posted by rruiter
I doubt dust can get get UNDER the wax unless you don't wax it out. Other than that I think it's a good compare.
rruiter - - -
Carnauba on your wheels or your paint is NOT like a protective layer of impermeable plastic. Brake dust will NOT get UNDER the wax. When the wheels get heated from the braking energy the wax softens to the point of becoming almost a liquid. Any dust that contacts the wax will be trapped and disbursed throughout the wax. Since the dust particles are generally larger in diameter than the thickness of the wax layer, a large percentage of the dust particles will be held in contact with the wheel’s surface.
Old 06-20-2004, 03:25 PM
Nick T.'s Avatar
On the “normal” painted surfaces on a car I don’t think that the “staining” of the FMJ is a problem. You have better access and a better view than on the wheels. I put a couple of coats of FMJ on my xB with no problems and am quite happy with it.
I no longer have my white Suburban (The Miata Masher), but it would be interesting to see if continued use of FMJ on white paint would start to give a pinkish cast to the paint.
Old 06-20-2004, 08:11 PM
mjames's Avatar
mjames mjames is offline
Dragon Slayer
Mein Auto: 2004 M3
I have a bunch of Zaino products, what is the best one to use on my wheels to add a layer of protection? Also, what is the best way to apply the product?
Or should I just use something like Meguiar's Hot Rims?
2004 ///M3 - Carbon Black/Cinnamon
Follow me on Twitter: @mnjames
Old 07-01-2004, 08:57 AM
cantona7's Avatar
cantona7 cantona7 is offline
Mein Auto: 2003 Imola M3
Which Klasse product are you guys referring to? Is this the regular "All in One" or is there some specific Klasse wheel cleaning/protecting stuff?
Old 07-01-2004, 05:25 PM
318-Bmw 318-Bmw is offline
Mein Auto: 97' 318i
Where can i purchase Klasse SG the cheapest?
Old 07-01-2004, 08:06 PM
KP's Avatar
KP KP is offline
Buyakasha!
Yeah that's the one.
My Photo Album
Old 07-02-2004, 06:14 AM
Artslinger's Avatar
Artslinger Artslinger is offline
BMW + twisty road = fun
Mein Auto: Car
After I started using the Klasse AIO on the wheels I've noticed that the brake dust comes off much easier.
Old 07-02-2004, 08:01 AM
Nick T.'s Avatar
Either Z-2 or Z-5 is okay. I’d recommend using three layers. If you use Z-1, then you’ll need to wait a full day between layers - but if you use ZFX you can do two layers one day and another the next day. Apply and remove just as you do on your paint.
Old 07-07-2004, 01:14 PM
CAETravlr CAETravlr is offline
Mein Auto: 2004 325i
Ok, this is going to sound ignorant, but I was wondering if Windex will do any damage to my wheels? On my last vehicle, a Jeep Grand Cherokee, I had pure chrome wheels, and since Windex worked so well on Chrome in the kitchen, I tried it on the wheels, and it took the brake dust right off and left them with a MAJOR shine. No scrubbing at all. I used it yesterday on the wheels on my Beemer, and it took the dust right off, just as easily. I was just wondering if there was something in it that might eventually cause some sort of deterioration on my wheels if I continue to do this. It is certainly the easiest way so far to get it off.
Old 07-07-2004, 01:21 PM
It probably removes any form of protection (wax) for the wheels also.
Old 07-08-2004, 04:22 PM
Mein Auto: 97' 318i
Where can I find Klasse SG for the cheapest price??
Old 07-21-2004, 01:30 PM
jetstream23 jetstream23 is offline
Mein Auto: 330i, Toyota Land Cruiser
So it sounds like Klasse All-In-One is the way to go on the wheels. Can you guys give your tips and tricks on applying it to wheels? How many coats do you use? Do you use similar applicator pads, terry cloth or MF towels, etc? Also, what QD spray do you use and how often? Details, details....
Much thanks. Great thread!
Old 07-23-2004, 12:05 PM
CWolfey CWolfey is offline
Mein Auto: 2004 325CiC
I usually use the griots for the wheels, but I ordered the SG today curious to see the difference. I dont think that I will ever have a problem with stained wheels or baked on brake dust since I have the easiest BMW wheels to clean and I take them off the car every month to clean them inside and out.
Gave it 1 more griots shine today before I trying the new stuff and took some pics also.
ID:	34749   Click image for larger version
ID:	34750   Click image for larger version
Old 08-07-2004, 08:28 PM
dwm's Avatar
dwm dwm is offline
Send a message via AIM to dwm Send a message via Yahoo to dwm
Mein Auto: 2002 M roadster
This year I started using RejeX on my wheels. Pros: sheds brake dust easily (slow running water), easy to apply and buff, lasts a good while, respectable shine for stock roadstars. Cons: 12 hour cure time on first application, 8 hours between coats.
I also use it on things that get pelted with bugs: headlight lenses, mirrors and front bumper cover. I don't use it on sheet metal body panels (old habits die hard, I'm still using carnauba).
Daniel
2002 M roadster
Old 08-16-2004, 10:11 AM
grigia42 grigia42 is offline
Mein Auto: 745li
Klasse
Where can I buy Klasse products. Auto supply does not carry it any ideas?
Old 10-09-2004, 01:39 PM
Jesh66 Jesh66 is offline
Mein Auto: 2002 530i
Getting yellow oil stains off the alloy rims
Well living in South Florida and dealing with 4 hurricanes within 6 weeks hasn't prompted me to wash my garage kept 530i. So today i decided to give it a cleaning. When i cleaned the rims i noticed that after washing away the break dust there was a yellowish stain/residue that i can't seem to remove from the spots where the break dust had sat for the last month. The rims had gotten wet over the course of the hurricane month but i didn't think the dust could have done such lasting damage.
Anyone know of a fix besides having to buy new ones? :-)
thanks
Jeff
Old 02-10-2005, 09:16 PM
Spy021 Spy021 is offline
Mein Auto: 2007 328i (Jet Blk/BLk
Pardon my ignorance, but I've heard several people say Klasse All-in-one and several say Klasse SG. I thought these were (2) separate products. Should both be used when treating the wheels (i.e. AIO follwed by SG) or is only one specific product used?
Old 02-21-2005, 11:51 PM
I only used AIO. Not sure if there is an upside or downside to using the SG as well. I did a detailed cleaning on the wheels and then patiently did a single AIO application to each wheel. I have noticed that cleaning the wheels since the AIO application has been very easy and never requires more than some light wheel brushing.
The biggest challenge is that the M135 wheels have some intricate spokes. I have followed someone else's advice and use one of those foam paint brushes ($0.49 at Home Depot) for cleaning between the spokes.
ID:	45182   Click image for larger version
2005 330i | ZHP, Xenons, Jet Black/Natural Brown (Black Cube)
Old 03-01-2005, 10:56 AM
wheelguy wheelguy is offline
Mein Auto: 2005 Suburban, 1998 SLK,
Something else to evaluate
Nick,
great job on the post. In 1997, I bought a 1995 840 added the M-style dual spoke wheels and ended up with a bad brake dust problem. I went to ceramic pads and lost some performance along with the dust and went back to soft pads because stopping is important sometimes. I then worked with a chemist to develop WheelWax (acutally a polymer, not a wax) and have been marketing it for 3 years now to fellow BMW drivers. I would be glad to send you a jar for your evaluation and you can find more information at www.wheelwax.com where you will also find my phone number for questions.
You are right about waxes melting and making matters worse. The polymers bond to the wheels, last longer and help protect the wheel surface. We combined three elements in our formula. A cleaner to remove old brake dust that is baked onto the wheel, amino functional silicones to seal the painted surface and an anti static element to help repel the dust. The rule of thumb these days is don't use anything to clean your wheels that you wouldn't use on your fenders. They are both covered with clear coats and can be damaged by acidic formulas. There is nothing in WheelWax that can harm paint or wheels. You can use it in the sun, leave it on for days and it comes off just as easily.
Send me an e-mail or call me and I will send you a jar for your evaluation. Hope this helps.
All the best,
Bruce
