I like my style 71s. 18" staggered. Going to be refinishing them this winter and adding a bit of color.
Very clean look. Definately post a pic when you add the color. Im interested in what they will look like.
Team M6s
2003 ///M5. ~ Jet Black/ Le Mans Blue Supersprint Headers, AFE intake, Evolve Alpha N Tune, ST coilovers, Eibach Rear Sway bar, Beast Power Brackets, Drilled slotted Rotors, Akebono Euro pads, Brake Duct's Grill, Magnaflow 14816 Mufflers ![]() _____________________________ |
Srry u have a 530i I read it to fast--wrong hub size--u would need hub rings to take up the space
Sent from my SGH-T959 using Bimmer App Last edited by cdawg246; 08-15-2012 at 01:30 PM. |
^ ALL E39s have the same 74.1 hub size
![]() 01 Anthracite 525i Sport, with 01 E53 3.0 and 91 Z32TT |
@AnotherGeezer Those are the rims I have. Definately a clean look, but I guess im just tired of them. Thanks for your post tho... clean e39 for sure.
Saw your car in a different thread and was definately impressed by the rim choice. Thanks for the post. These will definately be taken into consideration.
Hi Jpenn05.
Are you 100% sure you wish to go to 20's? if so, please do keep in mind you'll need to *REALLY* buckle down and research hard as running 20's on an E39 isn't a case of choosing wheels and throwing them on! You'll need to choose the right kind of wheel design that lends itself to the E39 shape and styling well, I'd HIGHLY recommend going with some high end and strong wheels as the tyre profiles you'll need to run are very small - get this wrong and weaker wheels are much more likely to crack. In order to visually look right along with the style/design of the wheel, you also need to significantly lower the car, most likely using coilovers. Here's an example of how to get running 20's on an E39, correct! ![]() ![]() ![]() Notice how the deep lip lends itself to making the wheel size 'blend' into the aesthetics of the car very well, it's bit of a visual trick there. There's examples of other wheels with no lip or much less of one and the wheel 'looks' bigger and doesn't flow with the shape of the car. The offsets of the wheels have been very carefully chosen and it's running slightly less wide tyres for a minimal stretched look in order to fit under the arches without fouling. That's where the suspension considerations come in. Get these bits wrong, and you'll likely rub and catch the tyres etc when driving. There's no 'best wheel' for the E39, you'll get every answer and suggestion under the sun! some people prefer oem, others prefer much rarer and exclusive ones. To help you choose what you like here's the link I always provide http://www.m5board.com/vbulletin/e39...et-wheels.html Lots of wheel choices there and pictured on actual cars, book the evening off, it's currently 157 pages ! 19 inch is a popular choice as well and you don't have to be quite so aggressive with the lowering amounts to pull the look off well as a result. Cheers, Dennis! |
19" M Pars
The e39 M5 wheels are my personal favorite....obviously
Understand that aside from giving up ride quality, you will sacrifice acceleration and gas mileage when going to 20" rims.
My Choice... 18" BBS CK's
Want to learn about your E39 5 Series? Click Me Albo's Official Upgrade Thread: http://www.bimmerfest.com/forums/sho...d.php?t=532572 ![]() 2003 530iA - Mumbo Jumbo |
19s m6
19s mpars 19s m5
00 BMW 528ia Sport M5 F+R Bumpers, M5 Mirrors with OEM setup, M5 rear sway bar, Cluster Rings, 03 Business player with AUX input, HID fogs slim, OEM 01+ Hella headlights, EAC Aluminum Adjusters, FX-R low beam retrofit, Umnitza VXX 10w LED Halos, Hella Euro Celis Retrofit Kit, Koni yellow shocks adjustable, 19" M6 Reps, Full LEDs. ![]() |
Yes...absolutely...without a doubt.
We have a few options that have been popular with many of our E39 customers! Here are a couple pics!
19" M6 Reps ![]() ![]() Avant Garde M310 in 19" ![]() 19" MM6 Mesh Reps:
ELLIOTT GOODMAN | Elliott@ModBargains.com| (714) 582-3330 ext. 8009 Hours: Monday - Friday 8:00am-7:00pm | Saturday 8:00am-5:00pm (PST) We Specialize In: BMW Accessories | BMW Exhaust | BMW Angel Eyes | Avant Garde Wheels | VMR Wheels | KW Suspension
ugh... ite welp looks like i need buy some 17inch style 66s for racing then
![]() Quote:
18" staggered style 5s for the E39. Hands down best look. Had them on my E46.
#25
Look up rotational mass and how reducing the weight and keeping a decent diameter (16-18") on wheels is one of the single best, instant-feel performance "mods" you can do for ANY car. OP, If you care about performance, you know that stuffing 20's under an E39 will leave you with little room for tires with a decent sidewall. If straight line acceleration and standing launches are in your plans, then you want more sidewall so it will flex. Softer sidewalls will act as additional springs functioning in series with your rear chassis mounted coil springs and will soften the overall spring rate in the rear. This then aids in weight transfer to the rear adding to mechanical grip and therefore more rear traction and a more comfy ride.
| Bookmarks |
| Tags |
| 2003 530i, 530i, bbs, e39, rims |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
