lens replacement for headlight for facelift mod - Bimmerfest - BMW Forums
Old 10-30-2013, 07:27 AM
rabies rabies is offline
97 740i
Mein Auto: 97 740i
could one swap out this 99+ headlight lens
http://www.ebay.com/itm/BMW-E-38-Hea...#ht_547wt_1127
to the 98- headlights and use the bottom plastic trim. would this all fit.
and leave the 98- corner lights and fenders alone..
kind of a half facelight. i was hoping to get the facelight trim for under the headlights without swapping fenders and blah blah
Old 10-30-2013, 09:06 AM
White Rhino White Rhino is offline
Mein Auto: 2001 530i
Here is pics of my lens restore. 30 min per lens if they are just cloudy. Cracked then that is a different story.
ID:	404867   Click image for larger version
Old 10-30-2013, 09:27 AM
97 740i
Mein Auto: 97 740i
^thats a 5series. plastic lens.
i was referring to the facelift peices.
in simple terms...could some1 with a preface light car(97) swap out headlight lens and use the bottom facelift headlight trim....would that fit? has anyone ever done that?
Old 10-30-2013, 11:55 AM
Hartge 635 Hartge 635 is offline
Mein Auto: 740il/X5/635csi Euro
You'd need to change the fenders too because of thinner turn signals
Old 10-31-2013, 03:18 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
You can't use the bottom trim that is below the lens between pre & post facelift...totally different designs. The pre face lift is straight...the post facelift is scalloped.
I do believe you can insert some of the innards of the post facelift inside the glass lens of the pre face lift...but you will need to use the lower trim and the fenders from your pre-99...as stated above, the turn signal lens is slimmer on the 99-up thus there will be a gap if you install 99-up lenses into a 95-98 E38.
The 99-01 exterior lens won't fit on the 95-98 headlamp assembly correctly...again, due to the "scalloped" lower edge isn't the same size as the straight trim piece...and where this trim piece meets the fender will be off because the 99-01 turn signal is slimmer than the 95-98. Also, the 95-98 turn signal lens is not only bigger...but also ends at the line in the hood. The 99-01 turn indicator continues from the side and goes about 1" towards the headlight lens (past the cut/line of the hood) to meet up with the curved edge of the face lift lens.
This stuff should be will documented in DIYs on e38.org. Look through any DIY about headlights and you can see the difference between the two.
99-01 scalloped lens...note how much bigger the scalloped trim piece is vs the straight 95-98 trim piece
(image by Edwin)
95-98 lens...note how narrower the straight trim piece is and how it meets the fender is also not as big as the face lift
(image by ScottyK)
Q {BMW CCA Member #191509}
(SOLD)
