Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Do-It-Yourself H.Q.
Do-It-Yourself H.Q.
Share your DIY projects or ask questions about how to fix something on your own. Help fellow Bimmerfest members improve your wrench turning skills! All BMW DIY tips, tales, and projects discussed inside. Learn to work on your car and know the right BMW parts you will need!
Old 08-16-2012, 06:14 AM
BMW78 BMW78 is offline
Mein Auto: 99 BMW 328i
Fuel pressure regulator
I changed my fuel pressure regulator, and now I have problems starting my car, I will have to pump gas with gas pedal a couple times to be able to start the vehicle. I own a 99 BMW 328i. Any ideas what is happening?
Old 09-22-2012, 03:46 AM
BMWFatherFigure's Avatar
Old School
Pumping the gas pedal has no effect WHAT SO EVER if the engine is not running. I guess you have a new faulty regulator. What is the fuel rail pressure? If it reads low (I guess it will) clamp off the return and see if the pressure goes up. If it does the reg is faulty. If not I'd be checking fuel filter then fuel pump.
Current:
Previous:
