E34 (1989 - 1995)
Old 08-16-2012, 10:31 AM
gfsys530isrcute gfsys530isrcute is offline
Mein Auto: 1995 BMW 530i
I guess I should of posted this here??
I posted in the DIY section but I was getting no response. Another member told me I should put it in here.
http://www.bimmerfest.com/forums/sho...d.php?t=634166
What do you guys think about my little starting problem?
Old 08-16-2012, 03:23 PM
supertech777's Avatar
supertech777 supertech777 is offline
Mein Auto: 1995 525i
What's the condition of your fuel filter ? Has it been replaced at all to your knowledge ?
Sent from my Desire HD using Bimmer App
Old 08-17-2012, 05:26 PM
Update...I replaced the CKS. No change...thrilled. As for the fuel filters I believe so. But now that I think about it I was pretty low on fuel when all my issues started happening but I quickly filled up thinking I was just running out of gas. Now if I let the car sit for a few minutes it will fire up and then die right away. Could a fuel filter cause this issue??
Old 08-17-2012, 05:32 PM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
You need to check your fuel pump. Don't forget to check your fuel pump fuse also.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 08-17-2012, 05:35 PM
Checked the fuse it good. The car will fire up and run for a few seconds so I thought the fuel pump was ruled out?
Old 08-17-2012, 07:06 PM
BMR_LVR's Avatar
Humble E34 lover
Yeah, I see your point, but, sometimes that is the way a failing pump manifests itself. You need to check it per the Bentley manual. Jump terminals 30 and 87 of the fuel pump relay sockets. The pump should run when jumped.
It is obvoiusly fuel delivery related. Check the fuel pressure regulator as well.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 08-18-2012, 02:11 PM
Alright, so I have seen these nice pictures of 3 relays in a row and it indicates which is the fuel relay. BUT what if I dont have whats in the picture? My relays are under the big maxi fuse at the bottom and horrible to get to. I have no idea whats what or which one to replace or even run a fuel pump test. Oh and there are 4 relays under there not 3.
Old 08-18-2012, 04:24 PM
Nevermind I figured it out. Ill keep all interested parties in the loop.
Old 08-21-2012, 08:32 AM
Hmm..
Alrighty,
So I replaced the Crank Position Sensor, Fuel Pump Relay. Same symptoms, it will fire up then immediately stall . I am now setting my sights on the fuel pump. As far as I can tell its got to be the last possible thing. (in case any of you want me to do the stomp test, my car wont do it? not sure why.) What do you think? When I replace the fuel pump and fuel filters is there anything I should know before hand?
Thanks,
Destry
Old 08-21-2012, 10:31 AM
I would replace the fuel filter , before anything else like I suggested early in your thread ...
Old 08-21-2012, 10:33 AM
I always start with the #1 and cheapest suspect , in your case the fuel filter .
Old 08-21-2012, 11:37 AM
goosefoot33's Avatar
goosefoot33 goosefoot33 is offline
Manualaholic
Mein Auto: 01 330Ci/02 525iT
Have you tried unplugging your MAF while the car is running (if you can get it to run for a few minutes)?
Can you verify that the fuel filters are new? Three cheap things to do:
1) Clean MAF (after testing it to verify its operational)
2) Clean ICV
3) Replace fuel filters
BONUS: replace/clean air filter
Doing all this will be under $50, the most expensive are the filters @ $15 apiece. Carb cleaner is $5 a can.
Sent from my Droid Incredible
BMWCCA Member# 451235
(Summer) 2001 330Ci - ZSP
(Winter) 1994 530i "Greenie" - PARTING OUT! (PM for details)
(Grocery Getter) 2002 525iT
Old 08-21-2012, 11:38 AM
Manualaholic
+1
I reiterated your point in my post above. I think that is the most important thing to check.
Old 08-21-2012, 12:00 PM
BMR_LVR's Avatar
Humble E34 lover
So far, I think I am the only one that suggested he check the parts (fuel pump, fuel pressure regulator). I haven't suggested replacement of anything yet. I agree with those above that it could be the fuel filters (inexpensive replacment), but he still needs to properly check the function of the fuel pump first. As we all know, it is a common fail item.
OP, keep us updated please. We hope you resolve it soon.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 09-06-2012, 02:18 PM
Alright fellas,
I replaced the fuel filters. The car fired up and ran for about 3 minuted. Then puttered and died. I am assuming the fuel pump is getting worn out. So when there is a bit of pressure in the lines it over heats and stops pumping fuel. Thoughts? I also think that rules out the maf and the fuel pressure regulator.
Old 09-06-2012, 02:19 PM
Oh and I already ordered a new fuel pump. Should be here soon.
Old 09-06-2012, 07:14 PM
TemporarySanity's Avatar
TemporarySanity TemporarySanity is offline
Mein Auto: 02 530, 02 540, 07 525
Sounds like the pump to me.
I discovered I scream the same way whether I'm about to be eaten by a great white shark or if a piece of seaweed touches my foot.
Old 09-07-2012, 05:53 AM
Pump arrived this morning, I will be putting it in within the next few hours. I will keep everybody posted...heck I am feeling ambitious...maybe ill post a few working pics as well. Good Morning BIMMERFEST!!
Old 09-08-2012, 01:02 PM
Its Alive! Feels like its been forever. Changing the pump in this car was super easy. Thanks for everyone's help. Another DIY solved.
Old 09-08-2012, 01:48 PM
BMR_LVR's Avatar
Humble E34 lover
Glad you got it fixed
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
