Old 08-16-2012, 12:17 PM
the wrench the wrench is offline
Mein Auto: 2002 745i
2002 745 e-brake light reset???
Hi there i have a lil issue here, i have a 02 745i that had the gear in the e-brake asy go bad, i replaced the gear and can only get the brake to set while rolling forward or reverse very slowly, it will not actuate in park and the yellow parking brake light will not go off, im stuck here, any help would be much appreciated...
Old 08-16-2012, 12:42 PM
alpinaman24's Avatar
alpinaman24 alpinaman24 is offline
what amg?
Mein Auto: 07 B7,91 735i , 91e30sold
when i do those
i use autologic to "learn stop and start position's"
ive heard if you press the e brake button 3 times within 5 seconds between each press
Old 08-16-2012, 12:44 PM
ill try it, thanks...
Old 08-16-2012, 06:55 PM
Didn't work :-/
Old 08-17-2012, 10:30 AM
what amg?
you will need a scaner for that if you want you can make the drive out to canoga park area and ill take care of it
