Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series
6 Series
The BMW 6 Series builds on BMW's sporty heritage with aggressive lines and an incredible motor to back the design up. Available in coupe and convertible trims with a standard 4.8 liter engine producing 360 horsepower and 360 lb-ft of torque, the 6-series is a popular choice that exceeds expectations.
Old 08-17-2012, 09:13 AM
All-Or-Nothing's Avatar
All-Or-Nothing All-Or-Nothing is offline
Woo Hoo FREE Donuts
Mein Auto: 2004 645Ci Convertible
questions about offsets and rim widths
What is the highest numerical offset that will fit on our 6ers. I know that wheel widths will also affect how much offset we can go so anyone feel like giving me a lesson so I can order me some new rims.
Pretty please.
Old 08-17-2012, 01:13 PM
2modfast 2modfast is offline
Mein Auto: Cars
Are you trying to stay close to stock sizes (width/offsets) or looking for something MORE aggressive or REAL aggressive?
Old 08-17-2012, 11:26 PM
Yorgi's Avatar
Yorgi Yorgi is offline
It's not an exact science. Tell us what tire size and wheel widths you are thinking of and I can give you some ideas.
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
Old 08-19-2012, 07:25 PM
Woo Hoo FREE Donuts
Is there a rule of when it comes to rim widths and offsets. For example can skinnier rims (8.5) use a greater offset than say a wider rim (10.5). Or is it the other way around.
I have found 3 sets of rims that I really like. They are all 20" but three different widths.
The 8.5 wide rims have an offset of 15 (I know these will fit no problem)
The 9.5 wide rims have an offset or 25.
The 9.0 wide rims have an offset of 20 with rear 10.5 wide rims at 27 offset.
Old 08-21-2012, 12:40 AM
Yorgi's Avatar
Rule of thumb is to increase stock offset by half of the increase in wheel width. So if stock is 8.5" wide with 14mm offset and you increase wheel width to 9" - that is a 0.5" or 12 mm increase - so increase offset by 6mm to 20mm in this case.
This keeps the wider wheel centered over the hub the same as the OEM wheel.
But wheel fitment is not an exact science since you have a few issues to deal with. If you go with too high of an offset the inside of the rim will rub on the strut. Too low and the tire will rub on the fender.
The safest thing to do is go with a fitment someone else has used and is known to fit.
'04 M3 - track
Old 08-23-2012, 02:28 PM
Mein Auto: Cars
Maybe you should start a thread about offsets. Everyone could list what they run.
Old 08-24-2012, 01:27 AM
gmair gmair is offline
Mein Auto: 135i cabriolet
Re wheel & tire size
I just posted this on another thread.
For anyone looking to replace their stock wheel/tire setup this is a great tool to play around with.
All you need to know is what your stock setup is, wheel diameter, width, offset and tire size.
Once you plug in those parameters you can make the changes that your considering and see the effect it will make on the fitment.
It helped me zero in on the perfect fit for me,
http://www.jonathanrowny.com/page/offset-calculator
