E39 M5 (1998-2003)
Help
Hello... I'm new here.. I need to know what ripe of power steering fluid I need for 01 m5...I have a leak ..
...tipe *
It uses ATF. Automatic transmission fluid.
I'll bet it was never serviced. Sad. m5board dot com, much written about this. You have multiple hoses that can leak- low pressure (cheap) and high pressure ($$$)...oh, and if you are lucky like me a pump which grenaded and cost $400, plus $400 for hoses, a new reservour, and a very messy 3 hours. At the very least, find out what is leaking, Buy the part and replace it, get as much old fluid out as you can, then add fluid, run and top off. I had so much metal in my system (ie the only part that wasnt replaced was the steering biox) that I had to run a few quarts through to flush the debris properly... GL A
Keep it as simple as possible...but no simpler. |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
