Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Car Navigation, Audio & Electronics by BAVSOUND
BMW navigation, audio upgrades, XM Radio, Sirius, Bluetooth, and Radar Detector discussions here!
Sponsored by BAVSOUND
Old 05-07-2002, 03:16 PM
AK AK is offline
Button Pusher
Send a message via Yahoo to AK
Mein Auto: '10 C2S, '04 4Runner
Alpine MP3 CD changer in the car and working..
'99 540i, no DSP, lotsa aftermarket stuff (amp, MBQuarts, etc).
Alpine CHA-S634 CD/MP3 changer
Alpine KCA-130B Ai-Net/M-Bus adapter
Soundgate ABMW35V4 BMW/Alpine M-Bus adapter
CD Changer mounted in the stock/OEM location (perfect fit):
Soundgate adapter with Alpine KCA-130B cable
Lotsa tracks on this CD!
Yes, it works, and the sound quality is excellent, but navigating the discs will take some patience. For whatever reason the Soundgate adapter causes "lagtime" when pressing the track +/- buttons on the dash or steering wheel, so you can't hit the buttons really fast to go forward/backwards through the MP3s/tracks... In fact, if you push the + button too fast, the track numbers actually start going backwards?!?! But you can still go at a reasonable speed.
If you have >99 MP3 files on a CD, in order to get to #100, you have to go all the way up to #99, then hit + one more time and although the display will say "01" you're actually on 100. Or, you could start at the "real" 01, and hit the - button. In my case, this CD had 146 files on it, so if you hit "-" from track 01, the display says 47 (hope my math is right), and from there you can keep hitting "-" until you get to 01, at which point it wouldn't flip back to 99 unless I held down "-" to get manual seek.
Anyways, the interface is a little quirky and it's easy to get lost, but at least it works! At the very least it's still a 6CD changer just like before (though with the Soundgate-induced lagtime as I mentioned).
have fun,
AK
Old 05-07-2002, 03:45 PM
Kaz's Avatar
Kaz Kaz is offline
King of Rear Clunks
Mein Auto: 01 325iT, 88 M6
So the question now is if there's an AiNet jack somewhere where that 1667RF display unit can be plugged in without cutting signal and control to the Soundgate...
2001 325i Touring Alpinweiss/Anthracite cloth, Alpina Softline
1988 M6 Royalblau/Silbergrau Nappa
Old 05-07-2002, 04:06 PM
punkman79 punkman79 is offline
Mein Auto: '02 325ci Jetblk/Blk'ette
:thumb: :thumb: :thumb: :thumb:
is the adaptor and cd changer fairly easy to install? is the adaptor a simple plug in at the back of the changer or do you need to take out the dash to do that?
I have a '02 325ci w/ Nav and HK...
TIA
2002 325ci Jet Black/Black
HK, Nav
Old 05-07-2002, 04:20 PM
AK AK is offline
Button Pusher
TIA
All the wiring is plug and play. Super easy. Mechanically, the Alpine is identical to the OEM BMW CD changer and will mount in the same location using the same brackets.
It took me about 15 minutes to remove the OEM CD changer and install the new one.
AK
Old 05-07-2002, 05:14 PM
SONET's Avatar
SONET SONET is offline
Parking Spot Maven
Mein Auto: 2011 335i, 2013 M3
I ordered the Soundgate adapter last week but haven't received it yet.
Looking forward to adding this system to my car... thanks for the post, glad to hear it went without a hitch.
--SONET
Old 05-07-2002, 07:25 PM
JPinTO JPinTO is offline
2001 M3:Stick, what else?
Mein Auto: ///MMMmmm good
This is exactly what I've been waiting for. I can fit every CD I own and all the napster MP3's I've downloaded into 6 disks!
You list 2 adapters. Could you describe the purpose of the 2 in a little more detail and the details of how they plug together.
Thanks - JP
Old 05-07-2002, 09:51 PM
KP's Avatar
KP KP is offline
Buyakasha!
Send a message via AIM to KP Send a message via MSN to KP
Mein Auto: MY01.5 325Ci/93 Miata
Thanks for the update, I hope it works out for you . I hope to be giving this a try as well as soon money shows up
Old 05-07-2002, 10:41 PM
AK AK is offline
Button Pusher
Thanks - JP
The factory BMW harness uses something called Alpine I-Bus. The Soundgate box converts I-Bus to M-Bus. The KCA-130B cable converts M-Bus to Ai-Net (Alpine's latest bus standard). The CD changer has an Ai-Net connector on it.
AK
Old 05-13-2002, 04:50 PM
gray330 gray330 is offline
got a new job
Mein Auto: '01 330i
1. What was the cost?
2. Is there a direct I-bus to AINet-bus adapter?
3. Can you use the "random" feature?
Old 05-13-2002, 05:39 PM
SONET's Avatar
Parking Spot Maven
AK check your PM when you get a chance, I sent you a PM a few days ago...
--SONET
Old 05-14-2002, 07:58 AM
cenotaph cenotaph is offline
Mein Auto: '08 Mini Cooper, '89 325i
See this thread.
My only question is can you have the mp3s in directories on the CD?
I do not fear computers. I fear the lack of them.
-- Isaac Asimov
Pauca sed matura. [Few but excellent.]
-- Gauss
Old 05-15-2002, 11:59 AM
EugeneS EugeneS is offline
Send a message via ICQ to EugeneS Send a message via AIM to EugeneS
Mein Auto: 2002 - M3, 2000 - 323i
Sales for $252.45 shipped here
Old 05-15-2002, 01:39 PM
wyu wyu is offline
Mein Auto: 2001 330ci
I have a 2001 330ci with Harmon Kardon. I am wired for a cd changer. Will this alpine mp3 player setup work for me? This sounds to be the ultimate setup, seeing that it would be cheaper than the OEM setup[
Old 05-15-2002, 02:10 PM
got a new job
Mein Auto: '01 330i
Cool
See this thread.
Old 11-11-2005, 03:39 PM
Bearcat's Avatar
Bearcat Bearcat is offline
Mein Auto: 01 530ia Sport, 2010 Golf
Does this Alpine CD changer have the mounting bracket for my 01 530i without NAV?
Will you still be able to play the single CD on top of the head unit after the installation of the cd changer?
Old 11-16-2005, 06:53 PM
x54.4blue x54.4blue is offline
Mein Auto: 2008 E61
Get a IPOD
Why get a changer when you can get a IPOD.
With a Ice System simple install and good sound.
Old 11-17-2005, 12:13 PM
RichardP RichardP is offline
Mein Auto: BMW E39 M5
I use an Alpine CHA-S634 and an iPod using this. Works with almost any BMW head unit in cars with iBus (all but latest 3,5 and 7), functionality varies with head unit.
Looks like this on my Say Nav screen:
No other interface I know of can give you the MP3 track data from the Alpine AI-Net on a stock BMW head unit.
2003 M5, Carbon Black, Nav, Intravee II with Ipod + MP3 CD Changer + DAB + MD Changer, TV, Bluetooth Phone, the works.
2013 M6 Gran Coupe, Sakhir Orange, Competition Pack, Ceramic Brakes and lots of other options
Old 11-17-2005, 12:17 PM
James's Avatar
James James is offline
Mein Auto: E36 M3
That looks really great! Does the iPod charge while hooked up to the vehicle?
Old 11-17-2005, 12:56 PM
Yes, it interfaces to the iPod through the Alpine KCA-420i.
Old 12-03-2005, 01:02 PM
jvr826's Avatar
jvr826 jvr826 is offline
Is it Trackday yet?
Mein Auto: 05 330ci 6MT
I'm looking into this setup for my 2005 330ci. Logjam electronics shows that the adapters are only good up to MY 2004. Has anyone installed this setup in an '05 car? I have Nav and H/K if it matters.
tia,
Jeff R.
Old 12-03-2005, 07:22 PM
LDV330i LDV330i is online now
Mein Auto: 2014 335i M-Sport EB
tia,
Blitzsafe and the Soundgate adapters are good on all E46's, except if they have NAV. Blitzsafe for years promised an adapter that would work with NAV but have never come through.
Old 12-04-2005, 10:53 AM
jvr826's Avatar
Is it Trackday yet?
Glad I asked, I have Nav. Thanks LDV!
Jeff R.
Old 12-16-2005, 09:03 PM
mcolozzi mcolozzi is offline
Mein Auto: 2004 330i ZHP
Straigth answer please - CD changer for '04 330i
Will this setup work with my 2004 330i w/Business CD? I don't think the car has DSP because I was told that the 3-series doesn't have that option. Is that true? How would I tell if it does or doesn't have DSP?
Alpine 6-Disc MP3 CD Changer CHA-S634
Alpine Ai-Net to M-Bus Adapter KCA-130B
Soundgate Adapter ABMW35V5
My local installer is clueless and gives me a different answer everytime I ask. BTW, does anyone know of a GOOD car audio guy in Tucson?
Also, is there a way to install satellite and have it controlled through the stock head unit?
Old 12-17-2005, 07:45 AM
See my sig.
I still do not understant why people get the impression the E-46 3 series have DSP. This seems to be a recurring questions but I am not sure where this assumption is coming from as DSP has never been available on those cars. The speaker symbol in the center console activates the H/K spatializer.
There is no need to find an installer. The MP3 CD changer is an easy self install. There have been many illustrated installation instructions posted like this one.
The stock head unit is able to control either the BMW OEM Sirius tuner or and XM Direct tuner with a Blitzsafe adapter. Again all of these are a quick install that have been documented on this board.
Similar Threads
How to Save Money Doing Euro Delivery Nat Brown Ask-A-BMW-Dealer 142 11-07-2014 09:23 PM
BMW ConnectedDrive: ChrisTO General BMW Questions 12 11-08-2005 07:41 AM
WSJ comparison of sub $30K Luxury cars Spiderm0n General BMW Questions 13 02-08-2003 02:37 PM
spent my entire day working on car today ayn Off-Topic 4 02-17-2002 02:03 PM
Jag X-type gets REAMED by edmunds. jastevenson General BMW Questions 12 12-31-2001 10:21 AM
