all of a sudden - no power anywhere - Bimmerfest - BMW Forums
Old 08-11-2012, 11:59 AM
tresk tresk is offline
Mein Auto: 2001 BMW 740iL
Just like the title says. Got in my car:
  • the dash computer wouldn't come on
  • No door lights
  • Not a single noise when I turn the key in the ignition
  • No headlights
  • No break lights
  • No inner lights
  • Key fob does nothing
No nothing.
I drive this car maybe once or twice a week. Nothing looked weird last time I drove it. The only thing was the air wasn't blowing too strong but nothing out of the ordinary. Don't think it is related.
I have a voltmeter. I checked the battery and I see 12V.
Where do I start troubleshooting?
Old 08-11-2012, 12:33 PM
UPDATE: I messed up while using my voltmeter. The battery actually reads about 2 volts. Something must have drained it completely. It's a relatively new battery. What's the best course of action? Get a battery charger? Replace it completely? Jump the car and drive around hope that it charges?
Old 08-11-2012, 01:35 PM
I just ordered a battery tender jr from Amazon. Hopefully this will be my solution. Anything I should watch out for?
Old 08-11-2012, 01:58 PM
joyism5's Avatar
joyism5 joyism5 is offline
Mein Auto: '99 740IL, K75RT
The E38 (and not only) is known for battery drain issues. Could be several things, like alternator, amplifier, navigation, general module, and the list goes on. Nice DIY: http://www.meeknet.co.uk/E38/E38_Battery_Drain.htm
JOY = BMW
Old 08-11-2012, 02:48 PM
setconstr setconstr is offline
Mein Auto: 2001 740i spt 2008 cl550
re
Take the Battery out and have a slow charge put on it see what happens after that !
Old 08-11-2012, 07:48 PM
Written for the E39, but it contains extensive information on how to test the battery & alternator which should apply as well to the E38:
- DIY how to test a BMW E39 battery & alternator
Old 08-11-2012, 08:47 PM
BMWFatherFigure's Avatar
Old School
When you use a battery minder or floating charger you may find it sets off the alarm all the time. I can explain why, just take my word for it. As for discharge other posts seem to have covered it..
Old 08-12-2012, 08:44 PM
My battery tender jr will arrive tomorrow. How long would it take to charge assuming it is fully drained?
Old 08-14-2012, 12:55 PM
Hey guys,
So I hooked up the Battery Tender Jr but I feel like it's not charging at all. Red light keeps blinking (it's been 16 hours or so). In the manual it says this may happen if the voltage is less than 3Volts. Does this mean it will never charge it or do I have to wait extra long because voltage was so low?
Old 08-14-2012, 01:52 PM
Old School
Use a standard charger to 'get things going' then revert to the floating charger Worked for me.
Old 08-20-2012, 09:33 PM
I ended up taking the battery to AutoZone. They tested the battery and said it was charging fine but it was closing time so they kicked me out. Once I took the battery home Battery Tender Jr started showing a solid red light instead of blinking so that was good. After a full day of charging it was still solid red but I decided to give it a try anyways. Engine turned the first try and everything seems to work fine. Drove the car all weekend w/o connecting to charger and still works.
Old 08-21-2012, 01:57 AM
Old School
Keep using the Bat Tender all the time. i suspect the battery is well under 'par' at the moment..
battery, electrical, power
