E34 (1989 - 1995)
New to me 530i
Hey guys! I was on in the e36 forums for a little bit in anticipation of getting a 328i but I ended up getting an 1994 530i instead. I'm looking forward to owning this car for a long time! It's got 97K miles on it, the cooling system looks like it was recently replace and it drives smooth. I'm going to need to put new suspension in it soon and get one of the window regulators fixed but other than that it drives great! Here's a little teaser pic
![]() Updated with new pics ![]() ![]() ![]() ![]() ![]()
Nice find! Good luck with it, let us know when you do your suspension, I've done it a few times alon with other 'festers. We'll be able to guide you probably.
![]() 1995 525iA 250k mi Shifted Performance E34 2006 325i/6 48k mi 2003 350Z 87k mi Shifted Performance 350Z Garden State Euros |
Nice! Thanks for offer. I've done a few suspensions myself but any advice would be extremely helpful! What do you guys suggest for shock/spring combo or coilovers?? I want it to be comfortable for a DD but a little lower than stock.
Very nice. Welcome to the wonderful world of E34 ownership
Steve Calypso Red 1992 525i with 170K miles 1991 735i - Sold 1992 525i - Sold 1995 325is - Sold 2000 528i - Sold
Welcome, shock and springs are better for a dd, and easier to install and cheaper than coilovers. Is that your infinity in the back ground?
Beautiful car. Kudos on only 97k miles too.
I have bilstein and vogtland which I daily drive but I'm a kid so I like it lower and stiffer. A popular combo is bilstein and h&r which seems to be the magical combo.
Buy a ball joint separator and replace the mounts are my words to the wise, meyle mounts are the best, get those. You should also do upper and lower control arms, get the ones with the bushings already in it unless you have a press. Lemforder is tops but $$$; meyle again for these - bang for your buck. When you do the control arms, e in touch, I'll give you my number if you like, prelaoding is a bit annoying but easily done with ramps. Wheels, if you so choose, just go with a 17" oem style you like, they are abundant and affordable. The only trick with these are that 3 series have high offsets and would require large spacers, stay to the 5ers, and E39s require hubcentric rings (74-72.5mm). Before mods like wheels and upgraded suspension, double check that the cooling system is fresh, and make sure all vacuum lines and oil gaskets are good, which can be a fun afternoon of simple work. Best of luck!! We're here for you, the finest forum on the web for a reason.
It's lowered on Tanabe coilovers with WedsSport wheels. It's only lightly modified at this point. Only short ram intakes. The coilovers are super comfy for street driving. I've got a world of Euro parts to learn about lol. I've heard of Bilstein in my mustang days and Koni's are available for the G37 so I've heard of them as well. What kind of suspension do these cars have? In my Infiniti, the rears are a separate spring/shock but the fronts are a coilover system. |
They are a MacPhearson type system. Coil over gas shock at all 4...
I'll look in the forums for reviews on coilover sets as well as spring/shock combos. I prefer a coilover but if they're all to stiff, then a spring/shock set up will do.I've pressed ball joints in and out before on my mustang that I used to own (a long time ago). That was a b1tch of a chore haha. The guy I bought it from told me it'd be a good idea to change out the ball joints soon so that'll happen most likely at the same time I do the suspension. Wheels will come at a later point. I actually like the smaller diameter. I'll keep an eye out but you can't beat the classic look of the car ![]() I really appreciate the support. I've been part of a few other forums myself and it's super rewarding being able to provide advice for those that are new like me. I hope I can pay back the dividends one day. I'm sure you'll be seeing a lot of questions from me! |
Awesome. That'll make life a little easier.
I want to get some coilovers too. Here's review on the coilover systems by one our members look towards the middle of the thread, http://www.bimmerfest.com/forums/sho...1970&highlight=
Gotcha. I guess I'd have to take a look to see what the set up is like. The car is still on the lot so I haven't had a change to get too intimate with it. I'm having the guy look at the window regulator and motor to get it working again. I've also DIY'd windows on the mustang but it was a pain. He quoted me about $100 to get the repair done...something I'm willing to pay him for. I'll take a look at the meyle products you listed. My aim is to bring to tip top driving condition. I'm no balla!
I just quickly looked at a DIY for the rear suspension....it looks like a mutha!!! The rear shock mounts are located on the rear seat deck?? Did I see that right?
Good thing I have a second car! |
you can do it in a weekend. its just a little overwhelming at first... the rear seats are very easy to remove and the rear parcel shelf just slides out . Mounts are under the sound deadening, justl it back and yourre solid.
I strongly recommend buying a bently manual or downloading it from somewhere on the interwebz
Actually the rear shocks are pretty easy. I had to change my rear shock mount. Just have to remove the rear seat.
Pull up your the bottom of your back seat. Pry off the covers on the seat belt,be careful they can break if you're not careful. There' two bolts behind the armrest and then there are two more bolts on the drivers side and passenger side towards the bottom of the seat of the seat back. Then pull out the back seat. There a 22mm bolt at the bottom of the strut assembly,take it out first. Then get a jack a support the trailing arm, and remove the three 13mm bolts on the rear deck. Then pull the whole assembly out. Get some spring compressors and compress the spring and disassemble the shock assembly. Takes more time to take out the back seat but it took me about 1hr.
Thanks for the tips fellas! I'm thinking about going with Eibach/Koni combo. I've read that this is a good compromise between comfort and handling. The rear seat is surprisingly easy to take out. I didn't realize there was actually stuff under there!! I'll have to buy pieces at a time though. Do you recommend replacing both the front and rear shock mounts also? Any particular brand I should go with?
yes. all four. meyle.
Thanks!!
I also updated the first post with new pics
the low mileage really shows on that car. its a dime for sure
Sent from my SPH-M910
I'm in Madison, WI, which is about 2 hours south of LaCrosse. I've never really been to LaCrosse, only have driven through it to get to St. Paul, MN. It's a college town so there's gotta be something other than cows and beer there
#25
Definitely is! I'm so happy with the purchase. It so nice.
