E36 (1991 - 1999)
Old 08-20-2012, 06:09 AM
VEESERIES VEESERIES is offline
Mein Auto: 325i e36
Rattling
I have noticed that a lot of BMWs rattle at lot after a while, mine has started as well, noise comes from wheels area like loose brake pads or something, what causes that and how can i stop the irritating rattling?? Thanks guys in advance
Old 08-20-2012, 07:28 AM
ReillyM3's Avatar
ReillyM3 ReillyM3 is offline
Mein Auto: 1994 325i sedan
If it sounds like a beer can pinging around a dryer then it is likely a brake heat shield. They crack at the bolting points and start making noise. As far as a rattling noise (metal on metal) it would be best to get under there with a lever and start pushing things around a bit. Look for excessive play and you will likely find quite a few perished bushings (cracked, broken, dryed out). Go for a new poly set.
1994 325i (current)
2006 325i (current)
1995 525i
1990 325i
1988 Jetta 8v
1987 Gti 16v
1985 Jaguar Xj6
1984 Jaguar Xj6
1966 Mustang
1965 Falcon Wagon
1961 Buick Special
1962 Buick Special Wagon
1955 Pontiac Cheiftan
1961 Falcon Tudor
1962 Faclon Ranchero
Old 08-20-2012, 08:53 AM
Mein Auto: 325i e36
Thanks, I had my suspension done end of last year (Dec 2011) so will check the brake heat shield and push everything else around and see, thanks again!
Old 08-20-2012, 11:32 AM
hursh328ic hursh328ic is offline
Mein Auto: 96 328ic
take a look at your exhuast heat shields as well they are held on by small bolts usually the addition of a larger washer will fix that
All the days you don't drive your BMW you don't get back
Old 08-20-2012, 12:04 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
The brake pads on my car rattle a little bit due to being improperly shimmed. I'd check that out on your car. There are plenty of things which can rattle on your car, but if your suspension was recently replaced, I'd put my money on brake pads and/or exhaust.
1998 BMW 328is
1966 Pontiac GTO
Old 08-20-2012, 12:08 PM
ReillyM3's Avatar
Happy to help.
1994 325i (current)
2006 325i (current)
1995 525i
1990 325i
1988 Jetta 8v
1987 Gti 16v
1985 Jaguar Xj6
1984 Jaguar Xj6
1966 Mustang
1965 Falcon Wagon
1961 Buick Special
1961 Falcon Tudor
