E36 (1991 - 1999)
Old 08-20-2012, 10:54 AM
Flotsam's Avatar
Flotsam Flotsam is offline
New to this board
Mein Auto: 1995 BMW 325i
Brake Warning Light Switch - check the bracket first
My brake warning light had been on for a while and i finally decided to do something about it. Pretty common problem on all E36s even M3. After reading a few threads and there is even a DIY on Pelican Parts for this repair.
Upon receiving the new switch, i installed it and low and behold I had the same problem. I ohmed out both switches. What i discovered was both switches worked the same way meaning that my old switch was not bad.
Upon further inspection i notice that the bracket holding a small metal piece which makes contact with the brake switch was misaligned. This is hard to explain so I have included a series of pictures to show you what the problem is. This part is behind the bottom dash panel under the steering wheel and i found that there is a metal knee bulkhead there held by 3 bolts that is best to remove as well to get access. So how this gets misaligned is beyond me except it is a slide on type fastener rather than a bolt so it just probably bends over time.
I used a screwdriver to slightly bend the bracket the switch is held by and the metal piece the switch center makes contact with. I just moved the switch bracket up slightly and the piece the switch makes contact with down slightly and now the switch works perfectly. Warning light is gone.
So I would suggest before you automatically just buy the switch you check out the alignment of the bracket(s).
Name:	P7310057 orig sw in place.JPG
ID:	337895   Click image for larger version
Name:	P8150082 brake switch contact piece.JPG
ID:	337896   Click image for larger version
Name:	P8150085 side mount of brake pedal.JPG
ID:	337897   Click image for larger version
Name:	P8150086 bending the bracket.JPG
ID:	337898   Click image for larger version
Name:	P8150087 replacement switch.JPG
Old 08-20-2012, 12:46 PM
jayjaya29's Avatar
jayjaya29 jayjaya29 is offline
Come at ///M3
Send a message via AIM to jayjaya29
Mein Auto: 97 M3
Good tip. My switch actually died, but that metal bracket is really easy to bend.
Old 08-20-2012, 07:41 PM
Flotsam's Avatar
New to this board
UR welcome
