Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > BMW Motorcycles (aka Beemers) and the Competition
Have an interest in BMW motorcycles or just motorcycles in general? Discuss the line of BMW motorcycles and how they may compare to the rest of the competition in this forum!
Old 08-20-2012, 06:43 PM
masseesj masseesj is offline
Steve M.
Mein Auto: K75RT
New K75 owner
Hi all. Just got a '91 K75RT with 13,000 mi. Been sitting in a garage for 3 years. It starts fine. Any advice about initial maintenance I should do besides new fluids and tires? Thanks, I'm psyched to get it going!
Old 08-23-2012, 07:27 PM
C14 Rider's Avatar
C14 Rider C14 Rider is offline
Big Mike
Mein Auto: 1999 328is 2010 Audi S4
ride it and have fun !!
1999 BMW 328is/M Sport Package/5 speed/122k and climbing/
2010 Audi S4 Premium Plus/3.0L Supercharged V6/Quattro/6 speed/25k and climbing/
Old 09-04-2012, 11:13 AM
BeemerMikeTX BeemerMikeTX is online now
Mein Auto: 2001 BMW Z3 3.0i Roadster
I would also change the fuel filter and screen inside the fuel tank. They are probably the originals. Although the tank itself is aluminum (therefore no rust issue), this will also give you a change to clean out and inspect the inside of the fuel tank. When you change fluids, don't forget the brake fluid.
Mike White
2001 Z3 3.0i Roadster
(Topaz Blue, 5-speed manual, Sport Package, CD radio, heated seats and mirrors, non-power top via special order)
"Beemer" is for my BMW motorcycles!
Old 09-05-2012, 04:55 AM
Steve M.
Mein Auto: K75RT
Oil Leak?
Thanks Mike. I had my '91 K75 serviced at the nearest dealer (over an hour away and $1000 later). An oil leak at the "crank case cover" was identified but not repaired. Any idea whether this is something I could tackle myself. I have average home mechanic skills but NO experience with MC or BMW repair. Thanks.
Old 09-05-2012, 10:33 AM
What did the dealer do for $1,000? I hope a lot. These bikes are relatively easy to work on, especially for periodic maintenance, so you can save yourself a lot of money by learning to do things yourself. You only need a few special tools (e.g., oil filter wrench - buy the "factory" Hazet wrench).
If by "crank case cover" you mean the cover on the right side of the engine that says "BMW" on it, this is a fairly simple repair. There is a "rubber" gasket that seals the cover to engine seam. The only difficulty is the water hose the runs through the front end of the cover. You should be able to just:
1. remove the 8 bolts that hold the cover on
2. pivot the cover off the engine using the water hose for support
3. remove the old gasket
4. inspect and clean the two gasket mounting surfaces
5. fit the new gasket (IIRC, the gasket goes on "dry")
6. refit the cover and tighten the 8 bolts.
Done!
Mike White
Old 09-09-2012, 06:01 PM
Steve M.
Mein Auto: K75RT
Dealer Work done
The dealer put on 2 new tires, changed engine engine oil, gearbox oil, fork and final drive oil, brake fluid, gearbox and shaft lube, fuel filter, air filter, spark plugs, safety check, state inspection, replaced rear brake pads and crankcase breather. Sound like a value?
The crank case cover refers to the one in front (not the one with "BMW" on it), which they said is a big job to work on, and has only sealing compound, no gasket. Watching it for now.
Appreciate your advice. Thanks.
Old 10-18-2012, 03:23 PM
Steve M.
Mein Auto: K75RT
Been away for awhile. Looking for advice on K75 preparation for winter storage in un-heated garage in upstate NY. All the fluids are new. Should I fill the gas tank or empty it? I figure fuel stabilizer for sure. Thoughts on the necessity of spraying WD-40 into the spark plug holes and cycling the cylinders? Any other storage prep advice welcome. SJM
Old 10-19-2012, 07:21 AM
C14 Rider's Avatar
Big Mike
Fill the tank all the way full and add stabilizer...Less room for condensation to develope by doing this..
I never bothered with the cylinders, never had any problems..
Pull the battery..
HTML code is Off
