E39 528i 1998 Traction Control Light is On - Bimmerfest - BMW Forums
Old 08-21-2012, 02:49 PM
lpichardo70 lpichardo70 is offline
Mein Auto: 1998 BMW 528i
I have a 1998 528i, which I currently replaced the master cylinder and the brake booster. After replacing these two parts the Traction control light has been on, constantly, indicating that the traction control is shutoff.
I have pressed the ASC button trying to see if it would make a difference, and nothing happens. At this point I can not get my traction control to work.
Any advice on what this may be?
Old 08-21-2012, 03:19 PM
acoste's Avatar
acoste acoste is offline
Mein Auto: 2010 550i MT
Did you disconnect connector to the throttle body? The very top connector. The ASC light will stay on if that is not connected.
Old 08-21-2012, 03:46 PM
@ Acoste ---- No, I did not unplug the connector..... Is there anything that might cause this problem?
Old 09-25-2012, 09:11 AM
pwrdave pwrdave is offline
Mein Auto: 98 528i
Have same conditions w/ my 98' 528i. Noticed a broken cable (see attached) but don't know if related?
Old 09-25-2012, 10:58 AM
acoste's Avatar
It is. The bowden cable going from the throttle actuator to the secondary throttle valve for ASC is broken so the computer has no control over it any more. (It can not reduce engine torque any more)
Old 09-25-2012, 11:23 AM
bkgreene39's Avatar
bkgreene39 bkgreene39 is offline
Very interesting so thats what moves and makes that mechanical noise when i insert my key into position 2.
Old 09-25-2012, 11:39 AM
16valex's Avatar
16valex 16valex is online now
Mein Auto: 530I/Stick Blown
Put the key in position 1 then say abdacadabra 5X turn the key off, the ASC light should go away.
If that didn't work then repeat the procedure but this time the key is at position 2.
Old 11-05-2012, 08:23 PM
TouringinMIA TouringinMIA is offline
Mein Auto: 528iT
Did you find out what's causing the lights to be on? Indy replaced my master cylinder and now my traction, brake and abs lights are on.......
