E34 (1989 - 1995)
Old 08-21-2012, 04:16 PM
dcbeams dcbeams is offline
Mein Auto: 1991 525i (E34) Red
I need to borrow water pump holding tool
I've been beating this bolt long enough and its not breaking seize, looking for someone that will loan me their holder either today (8/21/2012) or tomorrow (8/22/2012) hopefully I won't need it long. I'm in Escondido, CA 92025 so the closer you are the better. Please someone have this tool! lol, and thank you in advance
Old 08-21-2012, 07:53 PM
Mein Auto: 1989 525i M20B25
Tried the square shaft screwdriver?
The oil filter wrench?
vice grip the pulley?
Sorry I don't have the tool.
Old 08-21-2012, 09:11 PM
I've considered vice gripping the pulley, but I don't want to damage the pulley (just in case the water pump isn't the real issue)
Old 08-21-2012, 11:31 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
DONT VICE GRIP THE PULLY
you will damage the rim of it no matter how to do it. if its a plastic pully which come of them are it might even snap it.
Old 08-21-2012, 11:36 PM
^That's why it was last on my list of things to try.
The square shaft screwdriver trick worked for the 'ol M20. Just put it in between two of the four bolts holding the waterpump pulley to the waterpump and brace the handle against something.
Old 08-22-2012, 05:29 AM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
OP, keep in mind that it has reverse threads so you will need to turn the wrench clockwise to loosen.
Steve
Calypso Red 1992 525i with 170K miles
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 08-22-2012, 06:35 AM
SwissCheeseHead SwissCheeseHead is offline
Mein Auto: 08 G37,94 530i,11 328iT
^lol it's all in the small details
Old 08-22-2012, 07:09 AM
Monsignor's Avatar
Monsignor Monsignor is offline
BMW CCA Memeber #445389
Mein Auto: M50 Big Body
I wont lie to you, i think i've earned my cred as a backyard mech here, but i clamped down on one of the four bolts holding the water pulley on with channel locks and it's worked more than once.
Yes yes yes you can damage the bolt and strip it yada yada but you can also do that with a socket and ratchet on any bolt/nut if you're not careful. I just clamped down real real tight on the pliers and applied as much pressure as i could to the 32mm wrench. That sledgehammer trick is b.s. The screwdriver trick didnt work for me, my screwdrivers just flexed.
1995 525iA 250k mi Shifted Performance E34
2006 325i/6 48k mi
2003 350Z 87k mi Shifted Performance 350Z
Garden State Euros
Old 08-22-2012, 07:27 AM
supertech777's Avatar
supertech777 supertech777 is online now
Mein Auto: 1995 525i
Originally Posted by BMR_LVR View Post
OP, keep in mind that it has reverse threads so you will need to turn the wrence clockwise to loosen.
+ 1
Sent from my Desire HD using Bimmer App
