Old 08-22-2012, 07:03 PM
bimmer14 bimmer14 is offline
Mein Auto: 330i
Question E90 Thrust Arm torque settings
I just bought 2 new thrust arms (tension struts) for my 2006 330i (e90). I have the Haynes manual (which is just short of expensive fire starter paper) and it is saying that the ball joint torque setting is 122 ft lbs. This seems insanely high! Its saying the bushing nut torque setting is either 50 ft lbs plus 90 deg or 74 ft lbs plus 90 deg, depending on the nut grade.
Does anyone have a bentley or manufacturer manual that can confirm these settings?
Old 08-22-2012, 07:56 PM
Squidget Squidget is offline
Mein Auto: 2011 335i E90 (MT,Sport)
I don't have a manual, but I've googled some fragments of bentley manuals. As far as I can gather, that does seem insanely high. Typical numbers seem to be < 80 ft lbs.
I am, of course, not a mechanic.
I guess it's dumb to ask, but that number isn't actually 122 NM, right?
BMW CCA Member
Old 08-22-2012, 08:01 PM
Mein Auto: 330i
No, its not dumb to ask. It does say 122 ft lbs, (165 NM) I went to spaghetti coder and looked at the TIS manuals for some earlier models (they didn't have the e90) and I did find a few models that had a 165 NM torque on the ball joint...so, I don't know. Maybe its correct.
But, I sure would like to know before I ruin a $100 part (and potentially the ball joint socket which would really SUCK!)
Old 08-22-2012, 09:58 PM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is offline
Flying monkey herder
Mein Auto: Daihatsu Terrios
this may help:
http://www.engineershandbook.com/Tables/torque1.htm
personally i dont know what the torque spec is for you application, but it looks like 122 ft/lbs is plausible for the application. on the E46 if i remember correctly, the bolts were 14mm.
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Present: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL
Old 08-23-2012, 03:14 PM
Wihelm G Wihelm G is offline
California Über Alles
Mein Auto: 328CiC and 328iT
Tension strut to the swivel bearing (it's an M14 thread) is 165 Nm. The tension strut to the front axle support is 68 Nm plus 90 deg if it is an M12 8.8 thread or 100 Nm plus 90 deg if it's an M12 10.9 thread. I think your hex bolt is M12X1.5X115-8.8.
Old 08-25-2012, 08:21 PM
Mein Auto: 330i
Thanks for the help!!
Old 08-26-2012, 03:47 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
You might want this:
Appendix B - Torque Values
____________________________________ Ft Lb ________ N/M
MISCL
Wheel Lug Nuts..........................89..........120
Exhaust - forward flanges...............15...........21 - turbo engine only
Exhaust - reinforcement plate...........43.5.........59 - +90° -+30° -- 8 Torx Bolts
Exhaust - mid-pipe brace................??...........??
Exhaust hanger - differential...........26...........35 - turbo engine only
Exhaust hanger - wheel carrier..........15...........21 - turbo engine only
Exhaust hanger - rear chassis...........15...........21 - turbo engine only
M3 STRUT BRACE
Bulkhead mounting bolt...............73.75..........100
All other bolts......................25.07...........34
FRONT SUSPENSION
Sway bar end link.......................44...........60
Sway bar mount to subframe..............16...........21....M8 bolts
Tension Strut @ knuckle................122..........165
Tension Strut @ subframe................74..........100
Control Arm @ knuckle..................122..........165
Control Arm @ subframe..................74..........100
Strut Pinch Clamp.......................60...........81
REAR SUSPENSION
Brake line to hose.......................9...........12
Sway bar end link.......................42.7.........58
Rear subframe bushings..................73.7........100
Upper Control Arm @ bearing carrier.....73.7........100....+90°
Upper Control Arm @ subframe............73.7........100
Guide Arm @ bearing carrier.............73.7........100....+90°
Guide Arm @ subframe....................73.7........100
Camber Arm @ bearing carrier...........121.6........165
Camber Arm @ subframe..................121.6........165
Toe link @ bearing carrier..............73.7........100
Toe link @ subframe.....................73.7........100
Old 08-26-2012, 07:55 AM
Mein Auto: 330i
Thanks Calwaterboy.
Quick question. On that Tension strut at subframe. Is it 74 ft. lbs. plus 90 deg or just the tourque of 74 ft lbs? My Haynes and the Bentley had 74 or 50 + 90 deg (depending on bolt grade), BUT your TIM may be a more current revision...
Old 08-26-2012, 09:26 AM
The only suspension bolts needing torque plus angle are at the [rear] bearing carrier.
Spec is: Tighten to torque, then turn add'l angle ammt.
Excellent tool: CLICK HERE -- 1/2" does better at suspension torque values
Old 11-05-2013, 12:37 PM
BB_cuda's Avatar
BB_cuda BB_cuda is offline
Mein Auto: 2011 335D Msport
MISCL
M3 STRUT BRACE
FRONT SUSPENSION
REAR SUSPENSION
CAL,
I sent you a PM asking for standard strut brace torque values but your box is full. I have a 2011 E90 335D with msport package. I doubt the Msport affects the strut torques though. I did a search and it lead me here but you offered M3 values. I removed the strut brace before doing my homework (shame on me). Gaining access to my intake manifold to do the dreaded intake cleaning that the diesels need. I think I'm going in early at 28,000 miles but being proactive before caca builds up too much. Consensus at the diesel forum is between 45 to 65kmiles. Sounds similar to N54 port cleaning but for completely unrelated reason. EGR shooting soot into intake. I need to buy a Bentley manual even though there isn't one made for my D.
thanks, BB_cuda
Old 11-05-2013, 01:36 PM
Originally Posted by BB_cuda View Post
CAL,
thanks, BB_cuda
Dunno! My data's only through 2010....might not be right.
Old 11-05-2013, 01:49 PM
Mein Auto: '06 AW 330xi
Pelican's guide also calls for 122 ft lbs of torque.
Old 11-05-2013, 06:45 PM
BB_cuda's Avatar
Fdriller,
I was thinking there would be two torque specs. One for the central bolt, It felt like it was in excess of 100 ft-lb to break free. The other appreciably lower at the strut towers. I only have one large bolt at the central point.
Cal, i will take my chances. What does your 2010 specs say please?
Old 11-05-2013, 08:38 PM
There was a lower spec for that but I don't recall what it was. I'm trying to find the article I look at but can't find it
