Old 08-23-2012, 05:15 AM
awarr awarr is offline
Mein Auto: 135 cab
How many mile
I am thinking about buying an 06 X3 with 90k miles to get me through the winter. What do I need to look for? Thanks
Old 08-23-2012, 07:08 AM
UncleJ UncleJ is offline
Mein Auto: '06 X3
I have an '06 with 85K miles (bought new) now and am facing the following things: 90K major service, spark plugs (100K miles), leaking rear end, new brakes, tires, coolant flush, transmission/transfer case/rear end fluid replacement, and I am sure something else -- like Oxy sensors -- will pop up also. The 100K mile mark is a serious benchmark for decision time. Either fix all the stuff for another 100K -- or dump it and let someone else fix it all. The car is probably good for another go around if everything is taken care of, but the cost is going to be staggering -- unless you DIY -- or have a really cheap INDY shop! I just replaced a bunch of things, like both front struts, the MAF, fuel tank return valve, and assorted collateral stuff that goes with all that. Make no mistake these are good cars but they are expensive to maintain, especially out of any warranty and up toward the century mark. Put about $5k aside for repairs and maintentance when you consider the cost of your purchase.
Old 08-23-2012, 07:54 AM
SonicBoom SonicBoom is offline
Gearhead
Mein Auto: 2007 X3
I'm at 95K, and have none of those issues (I'm still under CPO warranty) but even if I did, I could do all those myself.
I was very careful about the X3 I bought. I made sure it was locally owned, and well cared for. It has 85K when I bought is 6 months ago) I would be very wary of one that isn't well cared for.
Old 08-23-2012, 09:29 AM
murderland murderland is offline
Mein Auto: x3
are the 06's the ones with the bad engine mounts?
Old 08-23-2012, 09:44 AM
Mein Auto: 135 cab
Thanks to all three who responded. I have a good idea how to handle now.
Old 08-23-2012, 10:53 AM
X3-terrestrial's Avatar
X3-terrestrial X3-terrestrial is offline
Aficionado
Mein Auto: '05 X3, '95 M3, '89 MkI
We are at 118,000 miles on our 2005, and none of those issues either. Just maintenance items and a couple of small things. Valve cover gasket is starting to fail (cheap). Still drives like new. Just make sure you get the service history and take it to a PPI.
"If everything seems under control, you're just not going fast enough"
-Mario Andretti.
___________________
River City Bimmers Chapter
2005 X3 3.0i ZPP, Htd seats, Htd strng, Black Sapphire on Terracotta.
1995 ///M3 Coupe, Lux, MT, Htd seats, Cosmos Black on Black.
Old 08-24-2012, 07:53 AM
Mein Auto: '06 X3
M-Land, No, the '07's on had the bad bolts. That is when they changed the engine. The '04 through '06's had few if any bolt problems. They did, early on, have a pigtail breaking problem with the springs however.
Old 08-24-2012, 09:55 AM
usaret's Avatar
usaret usaret is offline
Retired
Mein Auto: '09 X3 (MT)
Which I find odd as they are the same bolts BMW used in the older ones (and many other models).
http://www.realoem.com/bmw/partxref.do?part=22110392551
Leads me to believe it's a batch quality or an over torquing issue.
Old 08-24-2012, 10:07 AM
Supercourse Supercourse is online now
Mein Auto: 2004 X3 2.5i
There have been recent reports of 2007 rear springs breaking too:
http://www.bimmerfest.com/forums/sho...8&postcount=69
http://www.bimmerfest.com/forums/sho...3&postcount=70
It's a somewhat common problem across all BMW models, and has been for a number of years.
Not limited to BMW either (I think I referenced this interesting article a few months back):
http://atlanticmotorcar.com/case-stu...springs-break/
A random manufacturing flaw sounds quite likely to me, and gives weight to choosing something other than OE supplier for rear springs at replacement time.
As with most cars, you can be lucky and avoid problems, or you get get hit with a string of repairs despite your best efforts at preventive maintenance.
