Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series > 6 Series DIY
6 Series DIY
6 Series Do It Yourself (DIY) forum.
Old 08-24-2012, 01:57 PM
jcskijeff jcskijeff is offline
Mein Auto: 651 cont
Aftermarket wheels
i HAVE A SET OF AFTER MARGET M5 WHEELS THAT THE PREVIOUS OWNER THEW IN ON THE DEAL, WHEN THEY WERE MOUNTED ON THE CAR, I GOT A SHIMMY AT 50MPH, NOW THAT THE FACTORY WHEELS ARE BACK ON, EVERYTHING IS FINE, I REALLY LIKE THE M5 WHEELS, THEY WERE ON CHEAP TIRES, IF I GET GOOD TIRES, DO YOU THINK THEY WILL BE GOOD
Old 08-25-2012, 08:51 AM
gregb's Avatar
gregb gregb is offline
Mein Auto: 2007 BMW 650 vert
The shimmy might be fixed with good tires but most likely it is the balancing. When I swapped out to miro m6 aftermarket wheels, the dealer tried to balance but couldn't get rid of highway speed shimmy. The aftermarket wheels were not hub centric which means the axle size was a couple millimeters bigger, which is ok but much harder to valance b/c the normal tire balancing machine off the car can show perfect balance but the slightest failure to center the wheel on the axle can cause the shimmy.
My advice is to find a good higher end performance tire/wheel shop that does "on car" high speed balancing (I use Butler tire here in Atlanta). The gave done a great perfect job balancing the last two sets of tires for me on my non hub centric aftermarket wheels. Good luck.
Regards, Greg
'07 650i vert, creme beige/jet black, sports & cold weather pkgs, comfort access, premium sound, sat radio, Miro M6 wheels, tint, windscreen, triple resonator delete, 5W bulbs, corner bulb delete and m-tec fogs
'11 Acura MDX Advance with Entertainment pkg for the family - no mod's
Old 08-25-2012, 08:52 AM
gregb's Avatar
Wheel size was a couple millimeters bigger than the axle (not the other way around ...
Regards, Greg
Old 08-25-2012, 05:38 PM
Yorgi's Avatar
Yorgi Yorgi is offline
I would install centering rings on your wheels. They make rings that press into the wheel to make them hubcentric. It's almost impossible to get wheels vibration free at speed if the wheel is not hubcentric.
Any good wheel shop should be able to order the rings for you. They are not expensive.
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
Old 08-25-2012, 05:41 PM
Yorgi's Avatar
Find a shop that can do wheel balancing while the wheels are still on the car or a shop with a Hunter RoadForce balancer. That should help determine if it's the tire or wheel issue.
'04 M3 - track
Old 08-27-2012, 08:39 AM
gregb's Avatar
Yeah - they did put on the hub-centric rings and did the on car high speed balancing. Forgot to mention the rings in my post. Thanks.
Regards, Greg
