Old 08-26-2012, 09:13 AM
paulo6 paulo6 is offline
Mein Auto: 2008 535xi Mon Blue.
cobb S1 aggressive malfunction
OK, So had CObb installed for the past 4 months or so. Been running S1 Agrressive map from day 1. No issues. I was gone for 2 weeks and when I got back drove the car and I say 10min into the drive and as I was hard accelerating from a stop sign, I felt the accelaration was relatiely normal but I think (can prove that) the car went past redline - - it just felt odd at the end of the accelaration band (Pre upshift). Needless to say, i notice the engine sign pop and says malfunction reduce power. Car still drove fine...I panicked. But I continued driving home with no hard accelaration. I parked..An hour later I drive again and malnfunction is no longer showing and car continues to drive fine since. Any ideas people??
2008 535xi, Monaco Blue
PREMIUM, NAV, SPORT, COMFORT ACCESS, COLD PKG, PARK ASSIST, SAT, COBB S1 Agg.
Old 08-26-2012, 10:38 PM
nickp3 nickp3 is offline
Mein Auto: 08 535i
Plug the accessport into the car and read the codes.
Old 08-26-2012, 10:57 PM
Oceans10's Avatar
Oceans10 Oceans10 is offline
Mein Auto: BMW 535i + 535XI wagon
Probably O2 sensors reading airflow that is above the expected limit, so throws car into limp mode. Just turn it off and restart the car. Everything should be cleared. If this persists you can try to swap the O2 sensors and recalibrate them. Usually takes care of it. New sensors are around $150 each.
Audio: Jehnert Flatline speakers, Mobridge M1000 DA2 prepro, Helix P-DSP, Zapco Z-150.6 amp, CIC iDrive upgrade
Performance: Cobb Pro Tune, AR Downpipes, ER FMIC/CP, DCI, RB turbos and inlets, KW V2 coilovers, Fuel-It Stage 2 pump w Ported fuel rail, Mfactory LSD
Old 08-28-2012, 05:46 PM
TBCWitter TBCWitter is offline
Mein Auto: 2008 535i Sport
Same thing happened to me yesterday with my JB4. The CEL light freaked me out too. I was relieved that the CEL did not come back on after I restarted it. I hope this does not recur because it was slower than a Cavalier in limp mode...
2008 535i Sport, Premium, Cold Weather, PDC, iPod, Nav and Blue Tooth
Mods: 12 and 15 mm Spacers, JB4, BMS DCI, and Black kidney grills
Old 09-24-2012, 09:13 AM
I updated to V4.01 maps last night and read the code...it was H30FF. It cleared upon installing V4.01 of Stage 1 Aggressive Stock throttle maps.
Old 09-24-2012, 03:16 PM
xclone's Avatar
xclone xclone is offline
Send a message via AIM to xclone
Mein Auto: 2008 535iA
The H30FF is a boost leak related code. I can't find the exact definition of it but it's not a huge deal unless you keep getting it. Then you'll need to track down the boost leak code (which can be a pain). I would do a visual check of your charge pipe, DV's and intercooler outlet piping to make sure you didn't pop something off. This is not an uncommon thing when running a tune as more boost will stress the connections and fitting of boost piping.
BMWCCA Member 368765
2008 BMW 535iA | Cobb stg 2+ | FBO | Meth
Old 09-24-2012, 03:52 PM
If car seems to drive fine and no errors are popping you think it is still something I should be looking for from a fault stand point of the things you mention above?
Old 09-24-2012, 04:39 PM
xclone's Avatar
It's never a bad idea to look under the hood of a tuned car every week or so just to check things out. If it does not keep happening then no, don't worry about it but a quick visual inspection is always a good idea.
Old 09-25-2012, 09:40 AM
ModBargains.com's Avatar
ModBargains.com ModBargains.com is offline
Mein Auto: E92 335i, F82 M4
Since you're running higher boost, you are putting more pressure on the stock components. A boost leak can happen and it's never a bad thing to check your engine compartment to make sure everything is tight. All the things xclone listed are what I would check up on and re tighten if necessary.
You might also want to look into getting an upgraded diverter valve. The stock diverter valve is plastic and as you know, plastic does deteriorate over time. This is the one component that causes boost leaks on these cars esp. if the car is tuned. I would recommend that you check out either the Turbo Smart Diverter Valve or the Turbo Smart Blow off valve options (If you’re not a fan of the “wosh” sound from a BoV, then going with the diverter valve upgrade would be ideal).
The Following dyno chart was completed using a 1M, ONLY changing the stock diverter valves to the Turbosmart Diverter Valves. The graph shows the stock diverter valves leak boost, especially down low where it counts. Just by switching them to the Turbosmart Diverter Valves gains in torque are realized throughout the RPM range, with gains of over 25 Ft./Lbs down low.
The following dyno shows manifold pressure, and how just by switching to the Turbosmart Diverter Valves boost pressure is maintained.
Alan Wei | Alan@ModBargains.com | (714) 582-3330 ext. 8006
We Specialize In: BMW M3 Wheels | BMW Brakes | BMW Suspension | BMW M3 Parts | VMR Wheels |
Remus Exhaust | HRE FlowForm
Hours: Mon - Fri 8:00am-6:00pm | Sat 8:00am-5:00pm
Check out the Blog for daily updates!
Old 09-26-2012, 06:57 AM
HPIA4v2 HPIA4v2 is online now
Mein Auto: E60, E71, E92
IMHO, it's not the OEM diverter valve leaks at LOWER pressure but the spring rate on the aftermarket is harder/firmer, thus at low RPM where the vacuum line only asserted low suction per command by DME, here the aftermarket diverter still fully close (no pressure from the turbo goes out to the exhaust, all air volume goes to the engine), this has been done since the ole Audi turbo tuning (i.e. we use to use 911 diverter valve on Audi 1.8T) for better throttle response feel. Usually bad diverter leaks at high pressure, again IMHO.
Old 09-26-2012, 03:02 PM
amit1947 amit1947 is online now
Mein Auto: 2014 BMW M5
Check the Pressure Regulator (also known as Wastegate Solenoid). I had a simliar code and the service department replaced both my pressure regulators because they were not holding boost on the high end.
