Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series > F12 / F13 (2012 - Current)
The all new 3rd generation 6 series coupe (F13) and convertible (F12) forum. The F06 BMW 6 Series Gran Coupe forum is here
Old 09-06-2012, 07:53 PM
mrjoed2 mrjoed2 is offline
Mein Auto: 650 M coupe, Infiniti Q50
650 ground clearance
Read a few posts noting that the nose of the 650 can scrape easily, anybody having problems with the ground clearance in normal driving - not something I want to worry about frankly. And any difference between the M sport vs non-sport in this regard?
Old 09-06-2012, 08:49 PM
southern6er22's Avatar
southern6er22 southern6er22 is offline
Mein Auto: BMW 2012 650i xDrive
I have nightmares about scraping the nose of my car - I wish I was kidding - but it isn't horrible thanks to the sensors. I've had a few close calls with the underbody and nose that have caused me to use extra caution when driving around town (keeping my distance from curbs, keeping a mental list of parking lot entrances/exits that have steep dips, etc.), but I haven't caused any physical damage. The plastic underbody piece may have a few scrapes and there may be a couple scrapes on the underside of the front bumper, but there is no visible damage.
I haven't measured the M Sport vs. the non-M Sport clearance, but I think they are pretty close. I rely very heavily on the front PDC sensors, but they aren't 100% reliable. They offer some guidance, but some curbs are too low to be detected but high enough to scrape the underside.
So, yes, it is an issue but it's manageable.
650i xDrive Coupe (2012), Carbon Black/Black/Gray Poplar, M Sport, Full LEDs, 20" 373M Wheels, ARS,
HUD, CWP, Premium Sound, Nappa Dash w/ Contrast Stitching, Ceramic Controls, BMW Apps, PCD
http://www.youtube.com/user/Southern6er22
http://southern6er22.blogspot.com/
Old 09-06-2012, 10:05 PM
Itinj6's Avatar
Itinj6 Itinj6 is offline
Mein Auto: 2012 650i Convertible
Just go over any curb at an angle, one wheel at a time. Should be fine. The PDC is pretty good at letting you know if you will clear a curb or not. I've tested it extensively. If you have side view cameras, you will get yet another reference point with that.
I've scraped the little plastic "brushers" underneath the bumper like Southern but never anything worse that that. That was transitioning from a descending driveway to an ascending road and going a bit faster than I should have. It's not crazy low IMO. It just appears that way because of the large scoops. Having owned both, I also believe that the M-Sport and standard bumpers share a very similar ground clearance as well. Once again, I think the M-Sport just appears to be lower. If there is a difference, it's very little.
Absolutely nothing to worry about in normal driving.
Old 09-06-2012, 10:11 PM
XZLR8's Avatar
XZLR8 XZLR8 is offline
Mein Auto: X6 ///M
Yes, there's a difference in MSport and non-MSport cars. Another reason I skipped the MSport, frankly.
2016 BMW X6 ///M | DoningtonGrey/BlackFullMerino
2016 BMW 750xi M-Sport | GlacierSilver/BlackNappa
2015 BMW X4 35i M-Sport | GlacierSilver/BlackNevada [wife's ride]
2017 BMW X5 50i M-Sport | SpaceGray/MochaNappa [ON ORDER!]
PREVIOUS | '14 328xiT, '14 X6M, '14 X6 35i, '13 650xiGC, '12 650xi, '11 535xi, '11 X6 50i, '09 750i, '09 328xiT, '08 650i, '07 750i, '07 X5 4.8i, '06 650i, '05 745i, '05 325xiT, '03 745i, '02 745i, '01 325Cic, '01 X5 4.4i, and on...
Old 09-06-2012, 10:23 PM
Itinj6's Avatar
Do you know what the difference is? I'm really curious. From an eyeball perspective, I wasn't able to tell.
Is it published somewhere?
Old 09-06-2012, 10:33 PM
+1. They seemed to find the perfect balance with this car. The long, low coupe styling, in addition to other 6er touches, helps it to drive better than the equivalent 550i, but it's not so low that it is impractical. I wouldn't consider going any lower as my car is a road car - not a track car - so it would primarily be an aesthetic change, which, ironically, would hardly be an upgrade after one run in with a curb.
Old 09-06-2012, 10:43 PM
thom.one.two thom.one.two is offline
Well, it's not as low as a Vette, but it's low. I live in downtown Houston. The streets have been re-paved many times creating valleys where pavement ends and driveways begin. My front end scrapes all of the time. Sometimes on approach, I can enter at an angle, but egress due to traffic will call for me to make a head on approach. In that case, the front scrapes every time. I have had my front bumper replaced once already and I have a scratch on my new one. The sensors do help, but what would be better is just one more inch of clearance. My Porsche can be raised up when you find yourself in this situation as could my CLS. Also, my car is white, so each scratch shows up black.
BTW, my last 6 had a mangled underside when I traded it in, so this is not a new problem.
Parking curbs usually are ok, but when you pull up to a sidewalk that doubles as a parking stop you better beware. The long front overhang adds to the issue stated above, so an Aston by comparison probably wouldn't be as easy to scrape but they have no sensors.
All in all, I'd buy it again but I wish the front end angled up just a bit.
thom.one.two
Houston, TX
2000 328ci White/Tan
2002 330cic Orient Blue/Tan
2004 330ci Silver/Grey
2007 335i Convertible White/Tan
2009 650i Convertible White/Black
2009 M5 White/Black
2012 650i Convertible White/Cream
  • M Sport Package
  • Driver Assist Package
  • Bang and Olefson System
  • Comfort Seats
  • Contrast Stitching
  • Ceramic Controls
  • 20's
  • Active Steering
Old 09-06-2012, 10:51 PM
XZLR8's Avatar
Mein Auto: X6 ///M
I don't remember exactly, but I remember measuring (yes, I'm that guy) before I ordered my initial Coupe. If I recall, it was between an inch or two, particularly on the corners (which tend to droop on the MSport cars).
I don't know of anywhere it's published.
Old 09-06-2012, 10:57 PM
Itinj6's Avatar
I believe what you say but damn if my eyes were that deceiving to me.
I was meaning to take that measurement back in April when I turned in for the M-Sport but it completely slipped my mind.
It wouldn't have affected my decision to get the M-Sport but curiosity was killing me, especially when we were discussing the clearance issues months ago.
Do I dare go into the dealership with a tape measure and risk looking like a serious idiot? Lol.
Old 09-06-2012, 11:00 PM
XZLR8's Avatar
Mein Auto: X6 ///M
Even if you look at the 6er on the BYO site, switching back and forth from non-M to M, I think you'll see a difference at the corners.
I skipped the M-Sport for greater reasons than this, but it was something I considered.
Old 09-07-2012, 07:00 AM
Thanks guys, looks like it could be a issue. Does appear from pics at different angles that the M sport nose does sit slightly lower. Have to take a look when the dealer get a M sport 650 in later this month.
Old 09-07-2012, 07:23 AM
Emilner Emilner is offline
Mein Auto: 2013 SL63
I have yet to scrape the front of my 650 M sport. It seems low but I don't hit in places where my old 2011 550 Msport did...
2015 S550 Anthracite blue, Silk, loaded and doin just fine...
2013 SL63 AMG black....
2014 GL350 The kids chariot.
2012 750IL x drive, imperial blue/oyster, a finely loaded beater car... (gone)
2012 650 Cabriolet M sport (gone)
Old 09-07-2012, 10:28 AM
coolhandshin coolhandshin is offline
Mein Auto: '08 528is, '11 650i Conv.
M sport and non-M sport share the same suspension and spring parts number.
There is no difference of height and the ground clearance (or the rigidity of the suspension, for that matter) between the two.
Also, ground clearance is quite good compared to other sporty cars, and hasn't been a problem for me.
In fact, my 5 series with M sports package sits much lower.
But because the suspension of 6 series with either M or non-M or in sports setting or not, is more softer than a 5 with M package and the 6 seems to bounce up and down a little more on speed bumps and thus the more feeling of scratching on the 6.
Old 09-07-2012, 02:12 PM
xDrive McGee's Avatar
xDrive McGee xDrive McGee is offline
Mein Auto: 2012 Bentley Continental
Never scraped anything in my M-Sport - not yet anyways. I generally free very confident too. Of course, I use the "PBS" (Park By Satellite) feature every time I park as well - which definitely helps.
The Schlepper: 2011 Range Rover Sport Supercharged
Previous Rides
2012 650i xDrive - Loved it! 2010 535i xDrive - Very competent. Too sensible? 2008 Audi S6 - Still miss the V10.
2003 Maserati Coupe - The end of an era. 2002 Maserati Coupe - Gone and mostly forgotten. 2002 MB CLK 430 - Gone but not forgotten.
Old 09-08-2012, 05:57 AM
TopDownInFL's Avatar
TopDownInFL TopDownInFL is offline
Mein Auto: 2012 650 Coupe
Nick / TopDownInFL (sans the "top down")
2012 650 Coupe - Alpine White / Black Interior / M Package / Premium Sound
Previous Bimmers:
2008 650i Convertible
2004 645Ci Convertible - Reverse Sensors / Reverse Camera
2005 545i Sedan
2003 330Ci Convertible
2001 330Ci Coupe
1998 323i Convertible
1995 318i Sedan
Old 09-08-2012, 06:00 AM
Originally Posted by TopDownInFL View Post
LOL. Is that skepticism or a commentary on how poorly I type with my thumbs?
Previous Rides
Old 09-08-2012, 07:36 AM
Neither. Ignorance. What is Park by Satellite?
Previous Bimmers:
2005 545i Sedan
2001 330Ci Coupe
1995 318i Sedan
Old 09-08-2012, 07:52 AM
My guess is the auto park feature....
Old 09-08-2012, 09:37 AM
I assume he's referring to the top view/sensors. I'd be screwed without the sensors. It's a balance between not pulling so far forward as to scrape the front but being close enough that your a$$ isn't hanging out waiting for Granny in her Buick to run into.
Here are some close-ups of the M Sport front bumper that show the relative heights of the three components that you have to avoid scraping.
ID:	340892   Click image for larger version
ID:	340893   Click image for larger version
ID:	340894   Click image for larger version
Old 09-08-2012, 10:34 AM
Yeah, I was making a non-funny reference to the faux top-down view the car stitches together with all its cameras. I like to pretend I have a geosynchronous satellite overhead at all times - as part of the technology package. It's an xDrive, so I don't think auto-park is available. But the "overhead" view is really good for placing the front of your car and making sure you are not about to scrape a low-lying protuberance.
PS - I gave the car a difficult test this morning by pulling into a parking lot rather hot, and with a pretty steep grade. It did indeed scrape just a little, but nothing that made me worry. I was pretty much asking for it.
Previous Rides
Old 09-08-2012, 10:42 AM
Great pics. Thanks!
Previous Bimmers:
2005 545i Sedan
2001 330Ci Coupe
1995 318i Sedan
Old 09-08-2012, 03:06 PM
XZLR8's Avatar
Mein Auto: X6 ///M
I do the same thing. I was recently in my mother's new Lexus GS and felt incapable of even parking the thing without the cameras. Sad, really. Ha.
Old 09-08-2012, 04:47 PM
Itinj6's Avatar
You're a nut lol . Was it the painted part of the fascia that scraped or the panel underneath?
As for parking... I don't even look outside the car anymore when I park. I'm glued to the screen. It's like a video game lol. Love the top-view cams.
Old 09-08-2012, 05:44 PM
It was actually on the painted fascia. Have to get on your hands and knees to notice it, but it's definitely there - a few inches in length near the driver's side corner on the underside. Think my $500 damage allowance will cover it? LOL I am idiot.
See what I sacrifice in the name of auto science?
Previous Rides
Old 09-08-2012, 08:33 PM
lol. I'm the same way - aside from the occasional glance at the side mirrors since I (stupidly) skipped the top view option. It really annoys me that it says "don't rely on cameras alone" (or something to that extent) at the top of the screen as to obstruct the view a little... Lawyers - can't live with 'em, can't live without 'em.
