Vertical travel of the exterior passenger mirror - Bimmerfest - BMW Forums
Old 08-26-2012, 02:01 PM
JEG23 JEG23 is offline
Mein Auto: 550i
It is possible to change by coding the vertical travel of the exterior passenger mirror (Automatic Curb Monitor) when the reverse gear is engaged.
FRM>3020 FRM_SPIEGEL_PARAMETER, 10>ASP_BORDSTEINAUTOMATIK_DELTA>Werte=5A
The default werte value is 3B. This is a hexadecimal value equivalent to 56 (not sure if that defines the degrees of vertical travel). I tried various values and to my taste I can see the curb better with a werte value of 5A (decimal value of 90). Those interested in adjusting the vertical travel of the mirror may want to experiment with various values until they find a position of their liking.
JEG23
2011 550i
Space Gray /Black Nappa, Dark Wood
ZAV, ZCV, ZCW, ZDA, ZP2, 4NB, 5DF, 610, 2VH, 465, 6UK, 5DL, 6NR
Old 01-26-2013, 07:59 AM
meddoo meddoo is offline
Mein Auto: 2011 520d born(08/11)
It's a great code~ thank you...
I like "2D"...
Old 01-26-2013, 12:40 PM
Mein Auto: 550i
I like "2D"...
meddoo,
I am glad to see that this “oldie” has been useful to somebody else.
JEG23
2011 550i
Old 01-26-2013, 09:29 PM
Oldies but goodies!
Old 05-05-2013, 11:08 PM
Some day ago, I had to buy the F20.
I did not apply, but the same applies to the F20.
The help of different coding required?
Old 05-05-2013, 11:21 PM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is online now
bimmerfest Supporting Member
Mein Auto: 2011 535i M-Sport
Er..what exactly are you asking? You lost me.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS, EDC, DHP, & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- Mods - M5 343M 20" Forged Wheels / 6WB MFID / 2TB SAT / 4U1 Ceramic / 6NR Apps / PDV 5k Fogs / Rear Fogs / Euro Tail Lights / Cyba Quad Tips
Old 05-06-2013, 12:35 AM
I'm sorry...
I'm not familiar with the quick reply.
F20 can change the data entry "ASP_BORDSTEINAUTOMATIK_DELTA" like F10, but did not succeed.
F30 did fail too.
Will I have to add some code for succeed?
Old 05-06-2013, 09:55 AM
I'm sorry...
F30 did fail too.
Did you get an error code, or did you successfully code it (e.g. chnage Werte from 3B to 5A), but mirror travel did not change?
Old 05-06-2013, 03:52 PM
I successfully code it, but mirror travel did not change.
This is similar to the case of the F10 turn signal blinks.
Always thanks...
Old 05-06-2013, 07:58 PM
Always thanks...
Well, no one with an F10 can adjust the turn signal blinks, but you seem to be the only one unable to adjust the vertical travel.
I have no idea why though. After you change the value from 3B to 5A, and go back and read the ECU, does it still show 5A, or does it revert back to 3B?
Old 05-06-2013, 09:19 PM
It had not revert to the original values.
The value is changed, but it does not apply.
Thanks...
Old 05-06-2013, 09:20 PM
Thanks...
Sorry then. I am out of ideas.
Old 05-08-2013, 01:53 PM
AutobahnCowboy AutobahnCowboy is offline
Mein Auto: BMW
The switch for the mirror movement must be set on the left side.
If the switch controls the right mirror, it wont go down!
The only thing i can imagine why it doesnt work.
Old 05-15-2013, 04:28 PM
I successfully applied the code F20.
Just does not seem to like the F10 various angles. (I did not proceed the test of times.)
Thanks...
Old 05-30-2013, 09:23 AM
nabego nabego is offline
Mein Auto: 520D F10
This is only for those who have the option or is for all cars not having the call option of vertical travel of the exterior passenger mirror.
Old 05-30-2013, 10:33 AM
Mein Auto: 550i
nabego,
Not sure if I understand your question, but I have to assume that you need the proper equipment to make this work. It only "tweaks" the amount of travel of the mirror. If your mirror does not move when you place your car in reverse (the switch for the mirror movement must be set on the left side for this to be possible), I doubt that changing this code will give you that capability.
JEG23
2011 550i
Old 05-30-2013, 02:00 PM
Mein Auto: 520D F10
Yes, you understood me perfectly, I did not move the mirror when I put the lever in "R", I have no such call option and thought he could make.
Old 07-08-2013, 12:11 PM
deb10042 deb10042 is offline
Mein Auto: F20
Thanks...
Hi!
Could you please explain your personal example of adjustment/values?
I have also a new F20 and tried to change values, but unfortunately without success. I also changed the original 3B value once to a higher value and once to a lower value. Coding was successful and the values were accepted, but there was no change in the mirror position (yes, I had the switch moved to the left )
Old 03-09-2014, 04:40 AM
Bhd1R Bhd1R is offline
Mein Auto: F20 116i
Is there any progress?
Old 03-09-2014, 04:46 AM
Mein Auto: F20
Unfortunately not on my side.
Old 03-09-2014, 04:58 AM
Mein Auto: F20 116i
This is not good.
Old 03-10-2014, 11:39 AM
guillaume.db guillaume.db is offline
Mein Auto: F20 120Da
Works fine on my F20 !
FEM_BODY, 3110 PfExternalMirrorMaster, ASP_BORDSTEINAUTOMATIK_DELTA
Using now "2B" value, it's perfect !
Old 09-07-2014, 11:07 AM
lalamper lalamper is offline
Mein Auto: F20, 116i, 2013
Hi,
Do you have dipping mirror feature by factory?
Old 09-07-2014, 11:54 AM
Yes !
