Old 03-27-2015, 07:43 PM
Pj740il Pj740il is offline
2001 740i non sport
Mein Auto: 2001 740i
a/m button not showing in the cluster
So I cleaned the a/m button yesterday but I'm still not sure if and how it works. It doesn't even light up in the cluster hut it does light up when I test the cluster. (test no2, I'm looking at you U-Nam). Plus the gear selector never shows what gear I'm in on the cluster. When I start the background light for p/n come on for less than a second so I know it works. What's causing this? The trans button has been stuck in M since I got the car, but I never knew it was stuck until last nite. So I cleaned it with alcohol. It was gross.
ID:	500077   Click image for larger version
Old 03-27-2015, 10:23 PM
u.nanimous u.nanimous is offline
Certifiable BMW Whackjob!
Mein Auto: 1999 740iS, 2008 335xi
This is a difference between yours and mine, I have the steptronic. You will have to check the owners manual to see how the "A/M" part works on yours, but on mine the actual gear doesn't display until I either up or down shift while in sport (that's the steptronic part).
Someone probably tried using the cup-non-holder and spilled pop (that's soda for some folks) on the panel. That will gum up the hazard and central locking buttons too. Something to remember - that A/M switch is the same as the one for the sunroof (IIRC Mayorchuck pointed that out to someone not long ago).
Old 03-27-2015, 11:15 PM
2001 740i non sport
I read about swapping the two a little while on a semi write up/post.
The E38 is like a girl with a big butt.. it's just so hard to walk away.
Old 03-28-2015, 10:35 AM
ebida3's Avatar
ebida3 ebida3 is offline
Society of the 7's East
Mein Auto: 2001 740iL
This is a common problem. Replace the switch they are cheap enough.
