Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > F10 / F11 (2011 - Current)
The new chapter in the highly successful story of the BMW 5 Series Sedan (F10) and wagon (F11)
Old 08-27-2012, 07:07 AM
Ted550 Ted550 is offline
Mein Auto: 550ix
Tire Fit
Hey Guys I have a 2011 550xi base model. I want to replace the runflats with regular tires and buy a cheap rim for a spare. I found a rim that has the following specs. Am i ok with this rim. Thanks again for your help
Offset: 29mm
Backspacing: 5.66"
Bolt Pattern: 5-120
Rec. Tire Size: 245/45-18
Old 08-27-2012, 12:15 PM
1HOT BMR's Avatar
1HOT BMR 1HOT BMR is offline
bimmerfest Supporting Member
Mein Auto: 2011 550i 6 sp Manual+35d
There is a space saver available and I recommend Michelin PSS as a normal tire replacement.
http://www.bimmerzone.com/BMW_Perfor...T-F10-KIT.html
http://www.tirerack.com/tires/tires....r=Base%20Model
Old 10-21-2012, 10:34 AM
bimmerzone's Avatar
bimmerzone bimmerzone is offline
Supporting Vendor
Mein Auto: E63 650i
Thanks for the mention 1HOT BMR
to OP: for the regular tires, i second Michelin Pilot super sports as well!
| Bimmerzone.com | 1-800-357-7797 | info@bimmerzone.com | 833 Lincoln Ave, Suite 5, West Chester PA 19380 |
Video about Bimmerzone: http://www.youtube.com/watch?v=me5pjPS88Bw
We are proud to be Authorized Dealers for: Sprint Booster, Peake Research, Eisenmann Exhaust, Hartge, RPI Exhaust, AutoEnginuity, Bentley Publishers, Zymol, P21S, PowerFlex USA, Brembo GT, KW, Hawk and much more!!
Old 10-21-2012, 02:19 PM
Donm Donm is offline
Mein Auto: '13 M 550i, BMW f800st
Back to the OP's post, will that wheel spec work on both front and back position? I don't know if his car has the same wheel all around. I like the idea of a spare that can go some longer distance than the small spares and has no unreasonable speed limitations which, if you can stand to loose the space and want to haul the weight is a better solution to me.
Best regards to all,
Don M
Best regards,
Don M
It isn't broken yet but I can fix that!
2013 550i, BMW F800ST, ML350
Old 10-21-2012, 04:08 PM
WB&BLUE5 WB&BLUE5 is offline
Mein Auto: BMW 535i
You have a different size in the front and diff in the back. Why do you need a spare. Just call roadside. I put the Michelin pilot super sports on and have the insurance for the rims and tires. I don't care what I hit. I'm just picking up the phone.
Old 10-21-2012, 04:15 PM
Maybe I'm Old School, but I want to change the tire and get on down the road! Life is too short to sit In the boonies waiting on Bubba to show up.
Now back to the question, will it fit?
Regards,
Don M
Best regards,
Don M
