Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series > 6 Series DIY
6 Series DIY
6 Series Do It Yourself (DIY) forum.
Old 10-25-2011, 05:52 AM
davids25040 davids25040 is offline
Mein Auto: 2005 645i
How much coolant do I need for a flush?
I know to mix with distilled water, I just want to know proper ratios. By the way thanks to all for info on tune-up. It was still a pain, but all the info was absolutely necessary and much appreciated. Also Yorgi, your brake job DIY is phenomenal!
Old 10-25-2011, 09:47 AM
Yorgi's Avatar
Yorgi Yorgi is offline
Check out this post.
I would HIGHLY recommend you use the blue coolant from the dealer. The dealer coolant is very high quality - phosphate free, very good rust inhibitors, etc.... you don't want to cause a premature rad failure ($1,000+) or even worse, a coolant pipe failure ($2K to $9K).
BMW coolant is cheap insurance.
If you are bored, you can read this big thread on coolant types.
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
Old 10-25-2011, 10:08 AM
ECSTuning's Avatar
Mein Auto: e30
I concur with Yorgi 100% on the use of BMW coolant/antifreeze. If you are going to do a total system flush 2 jugs of the OEM coolant mixed 50/50 with distilled water should fill her back up properly.
If it doesn't look like the photo below then it's not the BMW coolant/antifreeze which we suggest.
ECS Tuning
800.924.5172
OEM BMW Part Number Search
Old 10-25-2011, 11:59 PM
Thanks for all the info. Im changing thermostat and wanted to flush at same time. I'll pickup some at dealer today. Great info owners manual said nothing?
Old 11-07-2011, 07:45 PM
Superhart1977's Avatar
Superhart1977 Superhart1977 is offline
Send a message via AIM to Superhart1977
Mein Auto: BMW 645CI
I have an 05 645ci and I flushed yesterday but used a total of two gallons. 1 gallon BMW blue antifreeze and 1 gallon distilled water, water level is fine.
2005 BMW 645ci
Stratus Grey Metallic/Black int.
20" M6 replicas
2006 BMW 325ci Black
18" RPM rims
50% tints, Black grill, tinted tail lights
Eclipse double din Nav
Retired BMW's
2003 Z4 3.0
2000 323i
1995 318i
1990 318is
Old 11-07-2011, 10:41 PM
Yorgi's Avatar
Did you drain both the rad and the engine block, or just the rad?
'04 M3 - track
Old 08-31-2012, 04:27 PM
pcm888usa pcm888usa is offline
PCM888USA
Mein Auto: BMW 650i
Rad Flush DIY
Is there a step by step DIY video posted to flush a E63 Rad?
Thanks.
Old 08-31-2012, 05:17 PM
Yorgi's Avatar
Thanks.
It's very easy.
Here are the TIS draining instructions.
Refilling is even easier, the system self bleeds.
'04 M3 - track
Old 08-31-2012, 05:53 PM
PCM888USA
Mein Auto: BMW 650i
Thank you so much. Will give it a try. I saw some posting about putting a garden host and back flush the radiator. I guess not a good idea?
Old 09-01-2012, 07:10 AM
Yorgi's Avatar
Yes bad idea. I would not put tap water in my cooling system. Some of the tap water will remain after the flush. The flush is not required in the first place if you stick to BMW coolant, which does not gum up like cheap coolant typically sold in North America.
'04 M3 - track
yorgi
