Old 09-19-2012, 07:06 AM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is offline
Mein Auto: 2011 535i M-Sport
Just a thought, but has anyone tried changing this:
SCHWELLE_TIPP_RETRIGGER = wert_01 / Werte=08 = retrigger time for turn signal [Value x 80ms]
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11)
- BMWCCA #446923
- flick
Old 09-24-2012, 09:40 PM
FrogmanF30's Avatar
FrogmanF30 FrogmanF30 is offline
Mein Auto: 2012 328i
Originally Posted by AutobahnCowboy View Post
FEM-Body on F30 should be equal to FRM on F10 like chriss88 mentioned
i captured it against with 4 Impulses and both changed/important Values
here the exact path´s for me
FEM-Body
-> 3060 LceMaster, 1C
---> Blinkzyklen_Anzahl_Tipp
-----> einmal, dreimal (not important)
-----> Werte=XX (your wanted Impulses, 0 conforms 1 - 09 is 10)
and
FEM-Body
-> 3064 LceConfiguration, F6
---> Pia_Default_Tippblinken
-----> Einfachblinken, --> Mehrfachblinken <-- (Choose Mehrfachblinken)
-----> Werte=01
if you dont have FEM-Body or FRM try to hit "Read Coding Data" on all Modules and open each one itself and search for "blinkzyklen" and "pia". i got for each searchstring only one positiv hit!
i also checked how the car will react after i uncheck the idrive "3 times blinking" and activate it again
unchecked it blinks only 1 time, after checked it it blinks 4 times like i coded it.
so the checkbox doesnt set the value to "3 mal blinken" but rather only activate the "Mehrfachblinken" with the Werte-Config in Blinkzyklen_Anzahl_Tipp
Hope you can get it work!
This works perfectly on my 2012 F30. Thanks!
Have you tried enabling the turn signals on the HUD? I can't seem to get that working on my F30.
Old 10-30-2012, 09:39 PM
jdco jdco is offline
Mein Auto: 650I
I tried changing the werte and there was no change.. with the amount of blinks or delay in the turn signal blinks. I've spent a while searching through most of CAF and am at a loss.. any other suggestions?
Old 10-30-2012, 09:45 PM
Sorry, but I don't.
- BMWCCA #446923
- flick
Old 11-03-2012, 09:12 AM
SuperSnoop's Avatar
SuperSnoop SuperSnoop is offline
Mein Auto: 2007 760Li
On my E66, I had to code the option for each key.
Old 11-06-2012, 04:39 AM
mrbombastic mrbombastic is offline
Mein Auto: 2012 535i
Supersnoop can you explain how you did that ?.
Old 11-06-2012, 05:23 AM
SuperSnoop's Avatar
In the E65, the one-touch turn signal code is MIND_ANZ_ZYKL_TIPP_BLK. I had to set that, along with MIND_ANZ_ZYKL_TIPP_BLK_1, MIND_ANZ_ZYKL_TIPP_BLK_2, and MIND_ANZ_ZYKL_TIPP_BLK_3. See if there are additional, similar codes for you.
Old 04-24-2013, 07:15 PM
yobimmer yobimmer is offline
Mein Auto: Lexus/BMW
hey, just got a 13 550 and it doesn't have the one touch turn signal option (or I don't know how to activate it?). When I tap/touch the turn signal it blinks once but I thought it was supposed to blink 3 times? Any thoughts or way to change this?
thanks
Old 04-24-2013, 08:52 PM
thanks
This is standard functionality. You have to go under the Options in iDrive and check the check-box for triple turn-signal.
- BMWCCA #446923
- flick
Old 04-25-2013, 03:43 PM
JamRWS6 JamRWS6 is offline
Mein Auto: 2012 BMW 535i MSport
Curious if anyone has any leads on this for the F10.
