Z4 Roadster (E85) Xenon light glitch - Bimmerfest - BMW Forums
Old 08-27-2012, 05:44 PM
Uber-Fritz Uber-Fritz is offline
Mein Auto: 2006 Z4 3.0i
Xenon light glitch
Hello
I am new to BMW ownership and now have a 2006 Z4 3.0i. I am having some odd behavior from the xenon headlights. Sometimes one comes on, sometimes both, sometimes the other. When I have only one light, the bulb warning is on. I sometimes hear a clicking sound from the area of the fuse box.
My first step is going to be to change the fuse but if anyone has run into this before I would be very grateful to hear about any solutions.
Thanks in advance.
Old 08-27-2012, 05:55 PM
SD ///M4's Avatar
SD ///M4 SD ///M4 is offline
(prev. SD335is & SDZ4MR)
Mein Auto: 2016 M4 Coupe | 2006 Z4MR
Since buying my 2006 Z4 M Roadster about 5 weeks ago I've had the bulb warning twice. The first time I wasn't able to check out what the problem was but when I came back to the car and restarted it the bulb warning was gone.
Second time my wife and I were out one night and the bulb warning came on. She got out and walked around the car and determined that the right front headlamp wasn't on. When we got back into the car and restarted it, the headlamp was working fine and the bulb warning was gone. Since it hasn't happened frequently I haven't bothered troubleshooting this any further.
- Tom
His: 2016 M4 Coupe | Sakhir Orange Metallic | Black Full Merino Leather | CF Trim | M DCT | Adaptive M Suspension | 19" Black Alloy Wheels | ZEC | ZLP | ZDB | MPE | ED 5/13/16
Hers: 2011 335is Couipe | Le Mans Blue Metallic | Black Dakota Leather | Dark Glacier Aluminum | 6MT | ED 5/12/11
Also His: 2006 Z4 Roadster (E85) | Interlagos Blue Metallic | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12
Old 08-27-2012, 07:28 PM
tonywintn tonywintn is offline
Drivin' the dream
Mein Auto: 2005 BMW X5 & 2007 Z4 si
I had the same problem. It was a bad bulb. $300 at the dealer to replace it with a new bulb. Well, at least it is warrantied for two years.
2007 3.0si w/Sport Pkg, Navi, Leather, Strut brace, garage door opener and delete airbag warnings on sun visors
Old 08-27-2012, 08:18 PM
Thanks very much. Was your alternating side to side like mine? I have first one then the other out.
Old 08-28-2012, 01:48 AM
Droptop85 Droptop85 is offline
Mein Auto: 03 Z4 3.0i
It's your ballast. I've replaced two so far. Im running a hid kit from ddm tuning. I bough a couple extra bulbs and ballasts for back up. When ordering from ddm you also need a code eliminator to get rid of the light warning on the cluster. Hid's can be a pain
Old 08-28-2012, 01:50 AM
They have hid kits for 35 bucks. Plus shipping. Plus another 15 bucks for the eliminators
Old 08-28-2012, 04:02 AM
Drivin' the dream
Mine was always the left side. If I flashed the lights or turned them back on a minute or two after turning off the left bulb would not start.
Old 08-28-2012, 10:44 AM
Thanks everyone. I am still not getting my problem. Right now both sides are working and the trouble light has gone out on its own without any reset (the exterior lamp/bulb one). Can it still be the bulbs if they work sometimes? Can it be the ballast when it is first one side out then the other, or does that just mean they are both wonky?
I hate to start replacing parts before I have a better idea what I am dealing with.
Thanks again.
Old 09-17-2012, 12:53 PM
Solution
And the answer was....... both bulbs were defective. Replaced gratis by the dealer. Thanks to everyone who responded.
Old 09-18-2012, 07:53 AM
imz4n's Avatar
imz4n imz4n is offline
Z ENTHUSIAST
Mein Auto: 06 3.0 si Z4R
I had the same issue with 2006. I found that by turning the lights off and then pack on via the switch the lights would come on. I got dome input from the group I run with and was told to do a power reset. Remove the negative terminal from the battery for 20 min. and then reconnect it. Be ready to turn your alarm off if you have one and you will need to reset your radio stations. I do not know why, but, I have not had the issue since and it has bee 2 years. My $0.02 worth. Try it before you spend cash.
failure, intermittent, xenon, z4
