Old 12-25-2012, 02:00 PM
Travel4Surf's Avatar
Travel4Surf Travel4Surf is offline
Mein Auto: Everglades 243
All are aktiv = 1
Old 12-25-2012, 02:35 PM
Ok, got it to work... It only shows-up from using the steering wheel controls, not the Idrive main controller.
Old 12-25-2012, 02:37 PM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is offline
Mein Auto: 2011 535i M-Sport
Originally Posted by Travel4Surf View Post
All are aktiv = 1
And you get nothing in the HUD? No Entertainment, No Recent Call List, no nothing?
What about under iDrive Info Display, is every thing checked off? Same thing under HUD options?
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS, EDC, DHP, & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- Mods - M5 343M 20" Forged Wheels / 6WB MFID / 2TB SAT / 4U1 Ceramic / 6NR Apps / PDV 5k Fogs / Rear Fogs / Euro Tail Lights / Cyba Quad Tips
Old 12-25-2012, 02:39 PM
Ok. Good deal.
Old 01-09-2013, 06:40 PM
What are these hives for:
Kombi & HU_NBT:
HUD_VZA_ENABLE
Kombi only:
HUD_TLC_ENABLE
Minha patroa um BMW
Old 01-09-2013, 07:58 PM
djsaad1 djsaad1 is offline
Mein Auto: range rover
Tlc is lane change assistance on hud. But you need to have driver assistance package for it to work.
Old 01-10-2013, 07:51 PM
harrisfb harrisfb is offline
Mein Auto: 2012 550i MSport 6MT
Convinced my dealer to update my software while I had it in for maintenance! Tonight I was able to add entertainment, incoming calls, recent call list and voice commands to my HUD. Thank you all for the help with this!
2012 550i MSport 6MT - Dinan S3 - Imperial Blue Metalic/Everest Gray - 20" 373M Wheels
Old 01-10-2013, 08:02 PM
marcosg marcosg is offline
Mein Auto: 2016 BMW F15 40d M Sport
Great to hear harrisfb.
What does voice commands do?
2011 BMW F10 528i M Sport
Old 01-10-2013, 08:07 PM
It is just a visual confirmation of your voice commands. Just like it shows in your BC under the speedometer...but cooler because it is in your HUD.
Old 01-15-2013, 04:43 AM
Thanks,
Old 04-08-2013, 10:33 PM
spadae2 spadae2 is offline
Mein Auto: 2015 750ix
That is sweet ride. Love the wheels. I am putting on the 312, put M5 grills, but I may switch back after noticing your 550.
__
2015 750i X-DRIVE, M-Sport, (born 3/6/2015), Moonstone Metallic, Ivory White/Black w/Honey Walnut, ARS, B&O Sound, Escort 9500ci. VO and FDL Coded. BMS Stage 1.
Old 04-13-2013, 12:58 AM
VirtualMayhem VirtualMayhem is offline
Mein Auto: 2013 550i
Hello,
I am picking up my 550i next weekend and am interested in coding the music/phone options into the HUD as described here. A quick clarification - will the title of the song currently playing by your plugged in iPod or bluetooth integrated iPhone show up on the HUD? Does the HUD entertainment option only show stations but not the song/artist info?
Can't wait to play around with this stuff!
2013 550i: Carbon Black | Black Dakota Leather | Aluminum Hexagon Trim| Sport Transmission | M-Sport | Dynamic Handling | Driver Assistance | Executive | B&O Audio | Luxury Seating | Power Rear Sunshade | Heated Seats
Old 04-13-2013, 01:14 AM
YES, it will show the song name only, based upon input selected, IPOD, etc, recent calls (if you press the phone button (the same as it does in the extended display. This is activated by the buttons on the steering wheel.
It will also show incoming call info.
__
Old 04-13-2013, 08:29 PM
PeterC4 PeterC4 is offline
Mein Auto: 535xi,328xiC
Originally Posted by VirtualMayhem View Post
Hello,
It will when you press the roller button on the steering wheel. But it will be active for only 3-5 seconds and then disappears. Phone calls will also show up when activated. They also disappear after a brief display.
2012 535xi M-Sport, Carbon Black, Cinnamon-Alum Hex, Exec Pack, Tech Pack, HUD, Damper Control, BMW Apps, Heated Rear Seats, BMS Tune
Old 04-18-2013, 04:14 PM
Thanks man!
The only thing missing from the entertainment on the HUD is song and artist info when switching satellite radio channels. That would be nice.
You see song names when scrolling though USB/Bluetooth music on the HUD so maybe it is possible to turn it on for Satellite.
Any ideas?
Old 05-08-2013, 06:22 PM
tsvette tsvette is offline
Mein Auto: 750i xdrive
Was reading through this post trying to program HUD for incoming calls, playlist. My KOMBI CAFD file is KOMBI: CAFD_00000069_008_000_042 not KOMBI: CAFD_00000069_009_000_042.
I cannot see the required options similar to others that responded.
Can I rename the required CAFD file (in my folder) to the name read by the SVT? I that doesn't work, how can I copy or update it?
Old 05-08-2013, 10:19 PM
No. You cannot rename CAFD file name. You can try and inject that CAFD into Kombi ECU though, and then VO Code Kombi with it, and then FDL Code as desired:
Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Left-Click on Kombi => Click on "Detect CAF for SWE" => Select newest CAFD => Select OK => Right-Click on Kombi (the ECU itself not the underlying CAFD) => Select CODE.
Afterwards, you can FDL Code as normal.
That said, I don't think simply updating the CAFD will add anything. In order to get the features, the firmware on Kombi needs to be updated to >= 47.1.
Old 05-09-2013, 07:18 AM
ok thanks i thought i checked this and only saw _008 in the pop window of files to select. i'll take another look to see if i missed _009.
Old 05-11-2013, 03:03 PM
sfiermon sfiermon is offline
Mein Auto: 2014 x3 35i
I read this entire thread...what are the settings for a 2014 x3? I have the NBT, HUD, and extended instrument cluster....
Old 05-11-2013, 06:53 PM
For X3, I a not sure if it is identical, but these are the codes to set aktiv in F10:
KOMBI 3000 HUD_ENTERTAINMENT_ENABLE
KOMBI 3000 HUD_SPRACHEINGABE_ENABLE
KOMBI 3000 HUD_TELEFONBUCH_ENABLE
KOMBI 3000 HUD_TELEFONANRUF_ENABLE
Old 05-15-2013, 10:56 AM
I clicked on detect caf for Kombi module and only options that came up were the _008 files. No option to select the newer 069_009_000_042. Any other suggestions would really heLp
Once again, I'm trying to enable HUD_Entertainment and HUD_Telephone on 2011 F01. all other coding functions seem to be available including HUD_turnsignal.
Thanks.
Old 05-15-2013, 11:11 AM
Thanks.
I have repeatedly told you simply changing the CAFD will not add this functionality. The Kombi Firmware needs to be flashed.
Old 05-18-2013, 11:36 PM
stein335i stein335i is offline
Mein Auto: '07 e93 335i
2011 F10 (6/18/10 prod) HUD coding
Just started playing around with coding this weekend. Successfully enabled turn-signals in HUD and mirror close from CA/FOB.
Struggling to understand if entertainment/telephone recents in HUD is even really an option given my production date.
I did have my car flashed last week to 2.49.2 but I do not see the following in the KOMBI module in e-sys:
HUD_ENTERTAINMENT
I have searched for HUD in other modules (HU_CIC) but not seen anything similar.
Any thoughts?
Old 05-19-2013, 04:16 AM
HUD_ENTERTAINMENT
Any thoughts?
You have an early F10 build, (6/18/10 prod), which is pre 0311 production date, so you do not have 6WA Extended Black Panel Display, which means you cannot have the advance HUD Features.
I would seriously consider a 6WA Kombi retrofit. The display is so much nicer, with or without HUD.
Old 05-19-2013, 09:34 AM
Thanks Shawn. Since I already have the latest software, is it just a simple swap of the display (looks easy per youtube video) or is it more involved? What additional benefits do I get besides extended info (telephone/entertainment) HUD?
Is this something i can purchase from bimmertech or does it have to be ordered from dealer?
