BMW Coding and Programming
Discuss coding options and features on your BMW here. |
#51
also i can select the Efficient Dynamics Picture in the SplitScreen. but is it possible to activate the full ECO Pro Modus? So that it act with ECO Pro.. for the air conditioning and all other ECO Pro stuff?
2010 BMW 535d GT |
#52
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickrŪ |
#53
I'm not sure if it will work because my F07 is from 05/2010... is there any additional Hardware for the ECO Pro Mode?
2010 BMW 535d GT |
#54
http://www.bimmerfest.com/forums/sho...57&postcount=3 I have everything working except I can not get the DEC Switch to go into the ECO PRO Mode. I still do not know why. I am not aware of any required hardware, so I am puzzled for now.
#55
So you have also the Eco pro things showing up in the Kombi? Like in the pictures attached?
I have read on German Site about the Settings that: The Sport+ is available just if you have DDC, due to the fact that you can configure the Things in the Sport (non +). And in the + you can deactivate the driving help things also incl. the sport transmission and Sport suspension. With Eco Pro the: "Normal" changed to "Comfort" "Comfort" changed to "Comfort+" And ECO PRO is New The appereance of the different modes are in JBBF or IHKA as i know.
2010 BMW 535d GT |
#56
My Normal mode changed to Comfort (works fine). My Comfort changed to Comfort+ (works fine). ECO PRO was added (can't engage it). ![]() I don't know why ECO PRO won't enage.
#57
shawn
did you have the Sport + before? I think this things should be in the KOMBI ECU.
2010 BMW 535d GT |
#58
Yes, and I still have Sport+. You can't see it in the picture, as I have to scroll up the DEC list as it is the first one.
#59
for your problem....
could you check what value you have here: HU_CIC / ECO_FDS_POPUP / ??
2010 BMW 535d GT |
#60
#61
I drove a 535 loaner and the only way I could change the modes were from the switches next to the gear shifter. To make this happen, we need the switches and need to know how to retrofit them. |
#62
![]() From my Post # 3: Quote:
So, as previously stated, I have the DEC (Driving Experience Control) Switch, and I can change from Sport+, to Sport, to Comfort, and to Comfort+. I just can't get it to engage the ECO PRO Mode.
#63
hi, I have 10/2011 F07 without EcoPro enabled (4U2) and i coded the car (HI_CIC - 3000 HMI - ECO_MODE = aktiv (Displays Efficient Dynamic Menu in CIC Nav menu, KOMBI - 3003 FZG - VERBER_HISTOIRE_ENABLE = aktiv, KOMBI - 3004 ERM - CTR_HSTY_DISP_KI_APPL = aktiv) and have nice histogram - thanks for that.
yet have some unexpected issues: 1. with DEC switch I still have sport+/sport/comfort/comfort+ - no Eco Pro displayed 2. I have neither EfficientDynamic Info nor EcoTips displays any clues to make me happier than I am after enableing EcoPro histogram? ![]() regards |
#64
I don't know.
#65
if it helps someone in investigation, my car spec is:
223 229 255 2b2 2va 302 316 322 323 3ag 402 423 430 431 441 455 456 488 494 496 4cb 4ur 4uy 502 508 522 524 534 5ac 5ad 5ag 5df 601 609 610 612 614 615 616 620 633 676 6aa 6ab 6fh 6fl 6nf 6nr 6vc 7rs 7sp 8th and N57 engine (3.0d), xdrive, build 10/2011, ilevel F001-11-09-501 (if remember correctly) |
#66
just wonder if EcoPro mode visible (sth Shawn has and I don't) and EcoPro switchable by DEC is written in KOMBI/300C ECO_FDS
I have only FDS_MENUE_TEXT_1 to ..._4 active and ..._5 says Werte=0F while "ECO" should have "06" and "ECO+" should have "07" Also FDS_MENUE_SIGNAL_5 is "0F" (kein text/reserve) while "modus ECO" is "07" I have to gain a little more confidence with coding to change in my car but maybe there are brave ones around here Please note that "06" (SIGNAL) stands for "modus RACE" |
#67
#68
I did not change FA, and no 4U2 added. Just changing FDL. I am a little bit affraid of changing FA/VO at the moment
#69
#70
ok, thought that marcosg's idea with changing 3 parameters is 'better' option that VO+4U2
![]() i am going to search forum for instruction 'how to back up and restore oryginal VO before scheduled BMW Service visit' I would not like to left big fingerprints on my car electronics |
#71
#72
well it seems it is to late for me...
you mean I should code HU_CIC and KOMBI under modified but not programmed (to the car) VO? how 'car' would know that my 'new' HU_CIC+KOMBI are now for 4U2 equipped car? anyhow - I try to do it when I wake up |
#73
Once the modules are coded, the car uses them as coded. It does not compare their as coded state to the VO stored in the car, and automatically recode them based on the cars VO so that they match. If you already modified your VO and wrote it to your car, all you need to do is change the VO back to the original (remove 4U2, and set original production date), and write that one to the car.
#74
hello again,
i'm not sure if i did it correctly but have a .xml file with added 4u2 and build date changed to 03.2012 i can activate FA so it seems to be ok i can code modules (did it with kombi and hu_cic) but... nothing changed - i still have neither ED Info/ EcoPro Tips nor EcoPro or EcoPro+ selection with DEC switch... how can I determine if new coding data are 'signed' including 4u2 and 03.2012? does coding 'flash' module or just adds changed data (I had kombi/hu_cic changed before new VO/FA preparation)... there is also no 2-items engine oil level in vehicle status menu any clues? Last edited by ad2k; 01-04-2013 at 12:48 AM. |
#75
I VO coded KOMBI, IHKA, JBBF, and HU_CIC. Try also VO coding IHKA and JBBF. I do not understand you question regarding "signed". ![]() Coding does not flash a module, it just reconfigures its programming using its existing firmware. In 0312, the oil measurement system chnaged. Since you are using an 0312 production date, when you VO coded HU_CIC it changed OELSTAND_OENS = aktiv. FDL Code this back to nicht_aktiv, and your Oil Measurement screen will be fixed.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
