BMW Diesel Owners / Enthusiasts
Do you own a diesel powered BMW? Maybe a 335d or a BMW x35d? Come and talk about what makes your car great! |
#26
"ZF emailed me saying that the 335i & X3 get the 6HP21 TU, and the 335d, X3d and all X5 models get the 6HP28 TU" where the 6HP21 cannot handle the torque of a 335d. The 6HP28 is the updated version of the 6HP26, both have a much higher torque rating than the 6HP21. See http://www.e90post.com/forums/attach...5&d=1170985745 for the torque ratings. PL
Rose Castorini: I just want you to know no matter what you do, you're gonna die, just like everybody else. Cosmo Castorini: Thank you, Rose. - Moonstruck Last edited by Pierre Louis; 08-30-2012 at 05:49 AM. |
#27
GA6HP26TU in ST810 - Advanced Diesel Tech.
I believe service information from BMW more than non-attributed sources.
Search for ST810 - Advanced Diesel Technology Workbook. On Page 20, it specifically talks about differences between the other 3-series and X5, and states definitively that they use the GA6HP26TU transmission, and then talks about the Twin Damper Torque Converter used in that transmission. It does say that that transmission is used in the X5 4.8i. Although they have different designations (6HP21 or 6HP19), the same transmission is used in the 335i. I suppose that they could be called different transmissions because of the designation difference, but the same transmission ratios are used in the 335i and 335d and X5d (the final drive ratios are different.) I suppose I'm focussing more on the gearset than the designations. Last edited by floydarogers; 08-30-2012 at 10:47 AM. |
#28
These are all different transmissions because their torque characteristics and capabilities are different. if you care to read my post it is specific to this status. That is why they have different names. if you have something important to say please do.
PL
Rose Castorini: I just want you to know no matter what you do, you're gonna die, just like everybody else. Cosmo Castorini: Thank you, Rose. - Moonstruck |
#29
The 3 main areas where I'm concerned about reliability in my D is:
1. Tranny - knowing that we have the same upgraded for torque zf tranny has me worried as the 7 series ZF 6 speed has a horrible reputation, many owners have had to dump their cars due to the prohibitive >$8000 price for a rebuilt tranny swap. There's also NO known acceptable 3rd party replacement for the ZF lube guard ATF. Some guys have tried other fluids, but no long term follow up yet 2. DEF system - All the frequent fill ups and primary/secondary tank issues leave me little faith in its reliability. 3. Twin turbo system-given the multiple N54 TT failures also has be concerned about ours. I soon regret selling my very reliable E46. That one has had all its bugs worker out
'10 335d Monaco blue/oyster/SP/PP/Enhanced Premium Sound/nav from phillipek SBBMW Click Here for Pics! |
#30
PL
#31
--Aaron |
#32
Pierre, I am probably too hung up on this. The 6hp19 is derived from the 6hp26, they both have the same ratios - I'm willing to bet that many if not most of the internals are the same. Nevertheless, with different designations, I'm willing to concede they're different transmissions. BTW, even Mike Miller says a 60K transmission fluid change interval is "ok". I see no reason to go 30K. My 'd is at 53K, next oil change is also a tranny fluid change. |
#33
--Aaron |
#34
OP you might find this thread informative.
http://www.e90post.com/forums/showth...=609922&page=3 |
#35
Realoem says reman as is expected as our car is no longer made. Considering the amount of integration there is between the tranny and the car, I'd be leery of using an Indy to do a proper tranny swap. When a simple e90 battery change requires DME programming...
In other words, there isn't a cheaper way short of BMW doing a goodwill discount. While having 'fun' changing my rear diff oil without a drain plug, I've come to realize BMW is designing their cars these days to be only be cost effective as lease vehicles.
'10 335d Monaco blue/oyster/SP/PP/Enhanced Premium Sound/nav from phillipek SBBMW Click Here for Pics! Last edited by magbarn; 08-30-2012 at 06:58 PM. |
#36
http://www.bimmerfest.com/forums/sho...1&postcount=12 And interesting enough back then I even thought that the $5400 price quoted there was reasonable. I must been drinking beer when I thought that, I tend to get more willing to spend money under those conditions.
--Aaron |
#37
Loving every mile of it! |
#38
Reference: http://www.e90post.com/forums/attach...hmentid=497359 Regards. PL
Rose Castorini: I just want you to know no matter what you do, you're gonna die, just like everybody else. Cosmo Castorini: Thank you, Rose. - Moonstruck Last edited by Pierre Louis; 08-31-2012 at 05:48 AM. |
#39
Mine is in after 22,000 kms / 14,000 miles. I got the "engine malfunction" message on my idrive telling me that my engine power was reduced. Used my BT scan tool and got a fault code related to "swirl flap actuator" being the issue. Took the car in two days ago and sure enough that was the issue but it's also deeper than that. My air intake manifold needs to be replaced and that part runs for $1,100 alone.
So glad I got the extended warranty a month and a half ago. |
#40
Im at 36K miles on my D and have had no major issues, besides belt squeal and recalls, touch wood. Speaking of trannies, Im at 36K miles on my D and have noticed a soft but distinct whine that seems to come from the tranny and is most noticeable around 70-75 mph. Maybe I should just drive faster!
Previous: 2001 Passat Wagon! |
#41
My 2010 D (in service date 21 Nov 2009) has just past 60,000 miles (97,000 KM) and no major issues other than the recalls & a grinding front passenger rear view mirror which was replaced over a year ago and a cracked windshield from stone chips on the highways.
I'm still on my original tires. I do have Winter tires for the last two years but my RF tires should last one more year. Last month I do hear some squeaks when I exit the car which on troubleshooting I found to be due to the hand brakes as when I release the hand brakes or do not apply it there is no squeaks. The dealer says there is nothing to worry about. On Monday I was at a client's house when he showed me his new F30 335i and when we compare the exhaust tips, his was black on the inside while my D's were almost spotless after 60K miles and almost 3 years. He was impressed! Fuel prices hit a new high today here in Toronto with RUG @ $1.39/litre in most stations and Premium Gas as high as $1.52/Litre! Ouch! But my normal station still sells Diesel @ $1.18 when I went to fill up my ML and D today. At these prices it makes more sense to drive a Diesel vehicle. |
#42
Hey DC-IT. I'm in Toronto too. What fuel do you fill up with?
I've mainly been using Shell V-Power this summer. |
#43
GreekboyD.
The station is Kingston's Pump, 4660 Kingston Red & Asterfield Dr, Scarborough. They said their diesel is from Esso. I've used them for several years and so far all my diesel vehicles are not complaining! I used to live on Asterfield Dr so I started using that station for convenience. If you download Gasbuddy app on your cell you will find that that station has the cheapest gas and diesel and its quite busy cos of the low price so the diesel turn around is fast as many smaller trucks fill up there and unlike Shell/Esso which normally has two diesel pumps there are four here. During Summer this station sells Diesel for $1.139/l when Shell/Esso sells at $1.199/l. So you save. $3+/tank. I do use Shell occasionally. Sent from my Nexus 7 using Bimmer App |
#44
Very interesting. That sounds like a great place for you to fuel up but a little too far for me as Im closer to Laird/Eglinton area in Toronto.
I miss the Sunoco Gold Diesel. I doubt Husky is running the same diesel fuel after they took over. |
#45
People are amazed when I tell them that I did the Math and that over 200,000 miles, my 2005 Mercedes E320 CDI saved me around US $10,000 in fuel costs over an equivalent gasser. This does not cover the extra value at resale that diesels often have over gassers. PL
Rose Castorini: I just want you to know no matter what you do, you're gonna die, just like everybody else. Cosmo Castorini: Thank you, Rose. - Moonstruck Last edited by Pierre Louis; 09-13-2012 at 06:16 AM. |
#46
What I am getting at is that in addition to the better FE of a diesel, I am paying a lot less for diesel ($1.179/L) than premium gas ($1.52/L) at today's rates at the pumps. Now when Winter comes around diesel is usually higher than RUG and close to Premium but even than the better FE still makes the diesel vehicle the overall winner. |
#47
![]() PL
#48
I also have that hum at 70 mph, as well as the sqeaky handbrake. It is a relief to know that I'm not the only one that has a car with so much 'character'.
Sent from my SCH-I510 using Bimmer App |
#49
I had read on this forum that pre 2009 build dates had the hp26 transmission and was replaced with the hp28 transmission.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
