E90/E91/E92/E93 (2006 - 2013)
Old 08-28-2012, 09:59 AM
sdbmw330xi sdbmw330xi is offline
Mein Auto: 2006 BMW 330xi
330XI wont start
Recently I had a engine misfire. I found it was a bad coil. The car was having trouble turning over when I started it for a few weeks now. I replaced the bad coil today and now the car wont turn over at all. Does this sound like a battery issue?
Old 08-28-2012, 10:02 AM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is online now
Flying monkey herder
Mein Auto: Daihatsu Terrios
if it was running before you replaced the coil, i would double check the coil you replaced.
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Present: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Old 08-28-2012, 10:12 AM
I could start it yesterday with the bad coil out of the engine... today it wont start at all... the engine wont turn over...last time I had it in the repair shop the guy told me I was going to need a new battery soon but was telling me it would cost me $350 for him to do it. I was thinking about replacing it myself.
Old 08-28-2012, 10:58 AM
jump start it?
if you didnt drive it around after all the starting and testing you may have a dead battery
Old 08-28-2012, 11:02 AM
ctuna ctuna is offline
Mein Auto: 325xi wagon
How about measuring the voltage ?
If this car hasn't had the battery replaced before you are due.
There is a glass eye on the battery that tells you its condition .
I assume you mean its not turning over.
You can get a batter for between 110 and 200 in the US .
Don't use battery backup when changing a battery in these cars
it blows fuses.
You should register the battery after installation.
The cheapest way is to get a coding setup which will give you diags and the ability to code.
Old 08-28-2012, 11:03 AM
thats what Im thinking the last time I had it in the shop I was told my battery was going to need to be replaced.... about how long do they last?
Old 08-28-2012, 11:05 AM
dealio's Avatar
dealio dealio is offline
Mein Auto: E90 335xi
depends, but certainly less than 6-7 years
Old 08-28-2012, 11:08 AM
how do i read the battery indicator?
Old 08-28-2012, 11:56 AM
It tells you right on it.
green good
black inadequate charge or marginal battery
yellow bad
When mine was marginal I would get long cranks . I tried trikkle charging it but it wouldn't
hold a charge very long . Like from 12.4 to 11.8 volts overnight it had the black indicator.
330xi, battery, coil, engine, misfire
