Old 12-19-2010, 08:54 AM
champaign777's Avatar
E39 Facelift Halogen to Xenon HELLA OEM retrofit
I got these headlights from ebay and I I want to retrofit my Facelift Halogen 2001
They are xenon OEM hella from 2003 530i
last night in installed them on 2003 530i car with xenon
( simple swap just to be sure that all is in working condition ) before Halogen swap
2 questions :
1 I need to do some light correction , right side it down left side is up
As far as i can see adjusters are not broken and auto leveling system is working
How you guys adjust your headlights ?
2. Xenon light is kind of purple . My OEM is white ... is it headlights or bulbs ?
just strange for me , i am kind of new to this staff
thanks
Old 12-19-2010, 10:04 AM
From the bestlinks thread ...
- Headlight aiming DIYs (1) (2) (3) (4) (5)
Old 12-19-2010, 10:09 AM
I like this forum
have clue about purple light ?
thanks !
Old 12-19-2010, 12:02 PM
Jason5driver's Avatar
Jason5driver Jason5driver is offline
Mein Auto: E39 hamster w/ pin-wheel
I like this forum
thanks !
Difference between OEM D2S HID Bulbs and H7 halogen bulbs.
Do you have OEM D2S bulbs?
Old 12-19-2010, 12:39 PM
i have no idea
which one has purple color ?
Old 12-20-2010, 12:29 PM
Mack's Avatar
Mack Mack is offline
Thebizzy.com
Send a message via AIM to Mack
Mein Auto: '02 525i
Lights look like they are in good shape. Hopefully your adjusters aren't broken. If not, adjustment is very simple with the white turnstyle adjusters up top. Good luck~!
Mods: Shark Injected | Magnaflow Exhaust + Resonator | H&R Springs | Bilstein SP Shocks + Struts | TMS Power Pulleys
Eibach F+R Sways | BeastPower Brackets | M-Tech bumpers | Predator ICE V3 + HID Fogs | Eurodyne CF Hood | BSW Sub + Dice + spec dock
[---Quote (Originally by Tex330i)---
You can warranty a turd, that way when you have a problem you can exchange it for a new turd.---End Quote---
Old 12-20-2010, 05:48 PM
yap you right
no they are not broken , no movement at all
Last night i played a bit and adjusted them ( up down movement ) , thanks to bluebee
I need to try left right adjustment as well
Guy told me they are off from 540i and this why they have purple color
If you ask me i like white color more ... which bulbs I need to look for ?
Old 12-20-2010, 07:38 PM
guziran guziran is offline
Mein Auto: 1999 540i 6MT
How much did you pay for the lights?
Old 12-21-2010, 08:23 AM
DHoang's Avatar
DHoang DHoang is offline
Gearhead
Mein Auto: '98 528i, '82 323i
Purple color means the bulbs are not creating the chemical reactions that produces the light. Inside an HID lamp, there's this chemical called halide. WHen voltage is applied between the two electrodes inside the lamp, a chemical reaction takes place because this element is negatively charged and will react to the positive charge. It's this reaction that produces the light.
http://www.bimmerfest.com/forums/picture.php?albumid=4132&pictureid=24642
Old 12-21-2010, 05:41 PM
http://forums.bimmerforums.com/forum...d.php?t=836630
http://web.mac.com/esckoehler/iWeb/S...c%202009-1.pdf
Old 12-21-2010, 05:43 PM
it means i need new bulbs ?
they work great as far as i can see except of color which i dont like
Old 12-21-2010, 05:50 PM
thanks for tips but my case is much easy
i just need to swap headlights and decode them - this is the whole point of buying OEM Xenon Hella set and replace Halogen
Old 12-21-2010, 06:51 PM
The links are also there to help you understand the difference between halogen bulbs and HID D2S bulbs.
Old 12-22-2010, 01:42 AM
Piston_broke's Avatar
Piston_broke Piston_broke is offline
What was that noise??
Mein Auto: E28 M535i, E30 323i
Champaign,
Curious to know how much you paid for those oem xenon h/lights?
GL with sorting out issues.
Old 12-23-2010, 10:34 AM
Originally Posted by Piston_broke View Post
Champaign,
thanks
usually they run about ~1200-2000$ new or ~400-1000$ used
You may need some hardware as well
check ebay
Old 12-27-2010, 09:34 AM
macgy macgy is offline
Mein Auto: E34 M50, E39 M52, M54
I use after market HID on my E39, 5k, 50W set, much brighter than the 35W set, no regret
Old 12-27-2010, 11:05 AM
i try to figure out where auto level server is connected
This yellow triangle is a servo ?
Old 12-27-2010, 11:23 AM
drbergin drbergin is offline
Mein Auto: E39 528i
No you don't need new bulbs. These guys have no idea what they're talking about. The purple color means that your HIDs are a certain K. 6000K tends to be a pure white, and as you increase it goes blue and purple. 8000K would be blue and so would 10000K. When you go higher than this you get into purple and you also get into lights that are so bright they are illegal in some states. Be careful what you buy. I prefer 8000K.
Old 12-27-2010, 11:28 AM
AnotherGeezer's Avatar
Entwicklung 39
Mein Auto: 2003 530i/5
Old 12-27-2010, 11:29 AM
Mack's Avatar
Thebizzy.com
Mein Auto: '02 525i
Ummm, how do you figure he DOESN'T need new bulbs if he wants to change the color?
FYI OP, most on here seem to prefer OEM White which is typically 5000k*. I have my DS2 lights (HID Fogs included) 6000k and I think they all look great. Very bright white with a subtle hint of blue. Good luck.
*Corrected to Jason's post below. 4300k stock/OEM.
Um....
Yeah...
I have no idea...
Says the new-b...
OEM is 4300k.
I am pretty sure you will want OEM bulbs.
Please post a picture of the D2S bulb you have now.
Is your bulb OSRAM-SYLVANIA?
http://www.eactuning.com/parts/produ...ls/63217160806
Old 12-27-2010, 11:35 AM
thanks guys
just point me where I can buy best OEM white bulbs ( Philips ? ) and i will be happy ( i think this link which Jason sent right ? )
can somebody post a picture where auto level server is connected ?
I try to disconnect it on a working headlights mm
Old 12-27-2010, 11:40 AM
thanks guys
Again, what bulbs do you have now?
Pictures?
You probably do not need to replace the bulbs.
You are probably only comparing the halogen light temp. to the HID D2S light temp.
To buy OEM HID bulbs, reference the EAC link I posted above, or look on HID Concept, or on Ebay.
http://www.hidconcept.com/Bulbs-Philips4K.html
http://shop.ebay.com/i.html?_nkw=phi....c0.m270.l1311
Old 12-27-2010, 11:49 AM
Mack's Avatar
Thebizzy.com
Mein Auto: '02 525i
Lighting chart for reference.
Best pricing on your DS2 bulbs on the net. I'm running these and for the price they cannot be beaten anywhere by anyone. Good luck! http://www.jlevistreetwerks.com/5-Se...duct_info.html
Old 12-27-2010, 11:54 AM
Yes, but where are these Jlevi bulbs made...?
I am going to make a wild guess and say not Germany...
Probably China...
